Everything posted by Kenny R
Rear wiper blade 2022 VRS?
New blade from EBay delivered today and have fitted will update on performance etc. New blade on left original on right.. And on looking at receipt, blade supplied by Heyner UK
Windscreen wipers.
RHD Kodiaq’s here in the UK have a 25” blade on the drivers side and 21” blade on the passenger side from the factory. Bosch recommends AP24U and AP21U and that’s what I’ve fitted to my previous and current Kodiaq.
Still no sign of a Bosch replacement blade for facelift models, and the replacement from dealer is both expensive and rubbish so having spied this one on eBay I have ordered one to see what it’s like. Put it this way it will be hard to be worse than the Skoda effort.
Correct Rear Wiper for Karoq Sportline 2023
If the Karoq Sportline wiper has changed, the same as the facelift Kodiaq the blade changed from 13” with a square locking button to 11” with an oblong button. As mentioned above no Bosch replacement has been made available and only option was from dealer. Today I found this on eBay and have ordered one to see what it’s like, put it this way would be hard to be worse than OEM
Any idea what this represents?
Driving mode
Using the DSG sport mode disables coasting but 2cylinder mode still operates on my 2022 Kodiaq.
Driving mode
If it is the eco symbol similar to the one in photo attached, then it shows that the engine is in 2 cylinder mode that occurs on light throttle on a flat surface. https://youtu.be/yoohR8sar5g?si=wPNmfLBd1DheMGyN
Wheel Identity
Part Number: 5E0601151FOD
Total coolant loss
If it has had a new cam belt and water pump, the coolant would have been drained. It could just be the coolant finding it’s level after being re filled and any air bubbles released. I would fill to correct level and monitor closely for a few days.
Light Assist Package
According to the owners manual, “ the system function can be restricted in unfavourable weather conditions “ . I presume fog snow etc could confuse the camera.
EPC and Emissions control lights clarification ?
These two, as they are linked to engine systems will stay on with only ignition on till the engine is started.
Problems, problems after battery change - Kodiaq 2018 5-seater 20 TSi 4x4
When you are charging the battery are you connecting the -ve from the charger to the dedicated point on the bulkhead and not to the battery -ve terminal.
Dash cam fitting
- How to attach a BM2 battery monitor to a Skoda Karoq battery?
Yes, and with a bit of luck the secondary nut you remove will fit the connection on the bulkhead.- Accidentally locked in the car🙀
The deadlocks operating when you lock the car is standard across all skoda cars I’ve had not just KESSY either.That’s why a warning comes up on the dash when you turn off the ignition and open the drivers door, so you don’t lock passengers in the car. Also it’s strange that if you were locked in the car that the alarm didn’t go off.- Cruise control buttons
What model and where are you located. In the UK ( according to the brochure) even the basic SE spec has cruise control.- How to attach a BM2 battery monitor to a Skoda Karoq battery?
Can’t see the -ve from the charger cable, but it should be connected to the dedicated connection on the bulkhead and not to the battery -ve post.- DQ381 coasting
My Kodiaq with the DQ 381 dsg is exactly as described by the OP, in that coasting occurs in normal and eco mode, putting the dsg into sport mode it doesn’t coast. My previous Kodiaq with the DQ500 dsg only coasted in eco mode.- DQ381 coasting
I like the coasting, but in rural up down twisty roads I just pull the gear selector back into sport mode and no coasting and engine braking when lifting off as required.- Switch on screen
- Car won't select a gear
Sounds like clutch stuck to flywheel due to driving through puddle. . Try selecting gear start engine when car lurches forward press clutch and slam on foot brake or handbrake and clutch should release- TPMS
As above, sounds like you have the direct TPMS as in photo below. It is normal for tyre pressures to go down when the temperature drops, but if as you say the rears are loosing pressure every fortnight the tyres/ wheels need checked for leakage.- Rear fog lights only?
Surely if it’s foggy you need front and rear fog lights on, that’s why it’s designed to work that way.- Cheating at battery specs
As you know the battery only tends to charge on the overrun ( regenerative) and the battery is normally kept at around 80% charged to allow capacity for the alternator to dump charge when required on the overrun. The chart attached shows that 12.4 V is perfectly acceptable. I believe if you fitted a different battery without coding the change in capacity then the system would not take any advantage and continue thinking capacity was same as original battery.- Disable auto rear wipers
I believe the Octavia is the same as the Kodiaq, and the only way to stop the random rear window wiper operation is to untick the rear wiper in reverse option. If you untick the automatic wiping in the rain option as in above post it turns of the front windscreen automatic wiper option. - How to attach a BM2 battery monitor to a Skoda Karoq battery?
