Everything posted by HeavyMetalRich
Humming noise
Well done you for getting 20000 miles out of them!
Recovered Stolen car… now it gets hard..
Can you not fashion something to pull the bonnet release through the open window? @StevesTruck's aforementioned fencing wire or a decent length of 8/10mm metal pipe could do the job. Of course if there is a block on the door preventing the pulling of the lever then ignore all I've just said. It's been a few years since I had my Octavia and I can't quite remember the setup.
What to do with the fuel cap…?
You'll have the slots cut in the edges of the cap to sit over the flap as demonstrated perfectly by @toot's pic. My previous Fabia was the same age. 👍
Or if you have a facelift ('18 and on) then you might have a pin sticking out of the bottom of the cap which fits nicely into a hole on the "arm" of the fuel flap.
Paintwork.
It won't just be iron contamination on the paintwork, you'll have tar and possibly tree sap as well. If you use some kind of tar remover and your iron off before using the clay, the clay will have less work to do. From my experience with the Roomster we had, the paint was pretty good so hopefully it won't take you too much work to get your car looking decent again.
Cruise control availability on 68 SE
It's possible it might just have a speed limiter. That was standard on SE until at least '67 plate. But yes a pic of the left hand stalk will tell you for definite.
2019 Fabia SE TSi with no apparent means to switch between cruise control and speed limiter
If all of the appropriate wiring is present and the correct stalk fitted, reprogramming shouldn't be too much of a bigger step forward. It's amazing what can be done with the VCDS program. I'm sure there would be a few more knowledgeable sorts around the forums here that would be able to help get something to work. I have a '21 plate Monte Carlo now and haven't paid much attention to what it has fitted in the way of cruise or limiter. I will check tomorrow if I remember.
All Season Tyres for Citigo
+ Another 1 for Goodyear's. Got my Dad Ultragrip 9s for one Citigo and the the Vector 4 Season Gen2s for the other. Both lasted well for about three/four years until both cars were sold in January still with decent tread. Both used 14".
SE Number 816
Did you trim the mudflaps or your bumper Pete? 😁
SE only came with the speed limiter as standard. I would say that you don't actually have cruise control. Front assist is merely to give you warnings that you're too close to the car in front and the braking assist system.
More handbrake issues
Unless that they're not following the routing they need to take correctly, I would think that they're not the right parts.
The aluminium tubes should be available separately, I've replaced ones on a Golf before that completely disintegrated in my hands as I removed them. Can't remember any part numbers or anything unfortunately.
DoctorBoostalot's Mk1 Fabia VRS Sill Repair - Rust Corrosion Part Two & FINAL
Seeing your work has inspired me to get mine done. I think mine is a bit worse than yours' was to begin with but still seems to be solid enough. I am considering doing all of the underpaint work myself and getting one of the body shops up here to do the colour and lacquer as the car is Black Magic and it would bug me if I just painted over with black as I have been told to do many times.😄
Great job Rich! Were you not tempted to go higher up the sill with the stonechip? Also can I book you to do mine?!😂
Brake bleeders ??
You should be able to see them through the wheels. However, they are not expensive you could buy one or two of each kind. They are usually one kind for the front and the other for the rear and so getting two of each should do all of your calipers eventually.
Help needed
The N/S is different as it doesn't have the hole to feed air to the intercooler.
Some questions
The dipped beam "lights on" indicator is on the light switch itself. No tell tale on the dashboard.
Removal of Fabia 3 washer jet nozzles from water hose for cleaning.
To clean them out better you'd be worth getting some compressed air and blowing it back through the nozzles while the pipes are disconnected.
Trevorb33’s Citigo Vrs 148Bhp (Up gti Conversion)
Just do what they do with the diesel engined ones and have the o/s one a fake!😂
Just looking at that rear end pics again Trevor, I wonder if the strip reflector off the Octavia could be made to fit along the edge of the bumper under the number plate and could you get a more squared off tail pipe finisher to make it a bit less VW and more vRSy?😂 Not suggesting you must do anything with it, just wondering out loud!😁
CV joints
What you get up to with routers and dinners while your car is stripped down is nobody's business but your own!😂 On a more informative note, is there any brand/supplier that folk have had really good experience with? I think I'll be needing ones for my vRS this year and will probably go genuine but am interested to hear if there are maybe any stronger made joints out there?
Rear mudflaps Fab Vrs
It looks like these are just for standard cars the top option being for the hatch, the lower being for the saloon and estate. I don't think the vRS ever had an option for the rears. Someone more knowledgeable can correct me if I'm wrong though. I trust the OP is therefore aware that the mudflaps themselves or the bumper will require a little modification to fit?
Fabia 2008 1.9 tdi sport rear back box
Yeah that skin isn't stainless for whatever reason, but underneath that should be stainless and should still be in good condition. Just take that outer bit off if it's becoming detached.
Rear caliper carrier
Getting the old disc off and the new one on with the carrier still attached is very possible with the smaller rear brake setup. I have had to do it plenty of times for the same reason the OP stated as their problem. The carrier contact points for the pads are also just as easy to clean up as of you'd taken the carrier off too. You just have to be careful not to get brake grease on the new disc as you put it back in.
Undertray and new sill weld patch
Ah right, with you now. Originally there would have been a stud with an open thread the same as a self tapping screw sticking out from the bottom of the car that a plastic nut would go on to secure the tray. However, the cars don't actually need the extra undertrays, many don't even come with them from the factory. If you still feel you'd rather have it on though, a self tapper with a big washer will do the job, just watch for possible wiring harnesses etc inside the car if you use long screws. Hope that helps!
