Everything posted by AGFalco
Coolant temperature sensor and thermostat
This was in relation to the 1.2 TSI 4 cylinder engine not to the 1.0 TSI 3 cylinder one. This means the thermostat's are fitted in the water pump but note there are two thermostats in the water pump. Quote from, VW The New EA211 Petrol Engine Family:- ''A dual-circuit cooling system is used for engine cooling in all EA211 engines. With this system, the coolant is channelled separately through the cylinder block and cylinder head at different temperatures. The temperature regulation is controlled by two thermostats in the thermostat housing. The respective coolant temperatures differ according to the engine.'' I don't know where the coolant temperature sensor is but I have found this image:- ''Coolant temperature sender G62'' appears to be attached to the back of the engine in between the turbo and the water pump. The water pump is fitted to the cylinder head on the gearbox end of the engine. This image is looking at the engine from behind, as if you were in the left hand seat, passenger seat for UK. Have you asked a TPS depot? Thanks, AG Falco
Fabia Mk3 Bonnet release with flat battery
In the UK the manual door lock is on the drivers side of the car / right hand side if you are sitting in the car. If you have deadlocks then opening the drivers door manually will NOT unlock the passenger / left hand side door. Thanks, AG Falco
Tail light warning light.....
Been there, Not seen it, done it. Glad it is sorted. Thanks, AG Falco
Have you removed all of the light bulbs to look at them. You are looking of one which might have a dark stain on the inside of the glass. Thanks, AG Falco
You have more than one tail light bulb, make sure they are ALL working. Look carefully and compare side to side. Mine has four tail light bulbs per side. Thanks, AG Falco
Battery low warning
The alternator does not produce a charge all the time by design. The car tries to keep the battery charged from about 50% SOC to 80% SOC. It wont want to charge the battery fully so that when you are braking the alternator will kick in and fast charge the battery at 15 volts. This is using the kinetic energy of the vehicle which would be wasted by using the brakes more. Micro hybrid charging system. Look here:- https://www.yuasa.co.uk/info/technical/micro-hybrid-hybrid-vehicles-explained/ ''When the alternator is running it can typically consume up to 10% of the power produced by the engine.'' If the battery was already fully charged you would be over charging it. The idea is that on a long journey the alternator only works when required. This can help with both fuel economy and low brake wear. My own car I have had from new in 2016 and is now above 50000 miles. The brake pads and disks are all original and are only about 1/2 worn. After swapping the car from a diesel I was hoping to hit 50 MPG in the summer with the petrol Fabia. I am actually achieving more than 50 MPG during the winter and above 60 MPG during the other seasons. This is worked out using actual miles travelled divided by the gallons filled to the brim every time I fill up. My original Battery is showing no signs of low charge and the stop/start system still works fine. I don't charge the battery with any external charger at all. It works for me. Thanks, AG Falco
Battery low warning
Don't assume that driving the car will charge the battery. The alternator will only cut in if the voltage is at its low point or there is a high demand. Smart charging is the way to go. Thanks, AG Falco
- Projector Halogen H7 Headlight Bulb Replacement - don't do it!
I would suggest doing the main beam inner ones first and only do them one at a time. You can then still compare side to side if you get lost. After removing the round rubber rear cover on the back of the headlamp unit take a photo of the bulb holder. Also note which way the wires go. The bulb holder is held in in two places by the two tabs on the bulb holder that slot in between the frame and the two small screws with the torx heads. You can see these screws in your photo, but this is with the bulbs already removed. To remove the bulb holder twist the bulb holder anticlockwise less than 1/8 of a turn. Note this anticlockwise if you are behind the headlamp unit not when standing in front of the car. This is very stiff the first time you try. You want to grip it on both sides as per your photo below. You then note which way the tab on the H7 bulb is fitted to in the bulb holder. You have a 50 % chance of refitting this wrong as there is only two ways to fit the bulb to the holder. The H7 bulbs have a tab around the metal outer ring. If you look at this photo it is at 9 o clock. Remove the bulb by pulling both apart. Push the new bulb in to the holder without touching the glass, you can use a new tissue / kitchen roll. Refit the bulb and holder the reverse of above. Look at the photo you first took to help you line it up. Push in and twist clockwise. Look at this topic for more help:- Thanks, AG Falco
I replaced all four H7 bulbs on my Fabia III with the Projector type headlight units back in 2016. These have all since been replaced by me as well. I didn't remove the battery, lower skirt, front bumper, inner wheel arch liners or the indicator bulbs. It is possible to do if you understand the process and use the correct technique. The photo in your third post is the one people need to look at and understand. Thanks, AG Falco
Strange osf wheel wobble and brakes jamming on
Tends to be fine when cold but gets worse after a drive when all the brake bits get warm / hot and expand. It might not be the calpier. I would check the brakes first including that the pads move freely in the carrier first. Thanks, AG Falco
Sounds like a seized brake caliper which can induce a brake pulsing when hot. This is where the brake is seized on tighter at some point every revolution. This can create a wobble where the suspension is pulled down further at the tight point. This might not be due to any pothole impacts. Thanks, AG Falco
Boot Locked
Check the switch first. Thanks, AG Falco
Boot Locked
Have you removed the boot switch / lock / catch and tested it? Does the MFD know when the boot lid is open / closed ? Broken wire from the body to the boot lid in the black rubber tube near on of the hinges? Thanks, AG Falco
Drivers Door Window
Door panel off time then. Has the glass jumped out of the carrier at the bottom? Thanks, AG Falco
Boot Locked
With the boot lid open but the boot catch in the locked position does it work using either the key fob or the outside boot push button? Thanks, AG Falco
Drivers Door Window
Does it work using the switch on the passenger side if there is one? Is it stuck up or down? Thanks, AG Falco
Boot Locked
Did the method suggested work? Have you checked that power is getting to the switch in the boot lid? Keep us updated. Thanks, AG Falco
Rear Drum Brakes sticking.
If you have rear drums then it helps if you go forward first after leaving the car overnight. Thanks, AG Falco
Tyres
Quite normal on most cars, especially the camber. To stop the sawtooth build up you can try this:- Don't fit directional tyres. Fit new tyres to the rear if you are buying two. If it is fronts you are replacing then move the rears to the front. Rotate your tyres from side to side twice a year. Thanks, AG Falco
I am assuming you have rear Shoes / Drum brakes. Yes. All cars, especially when it is cold and damp. Try drying the rear brakes off just before you end your journey. I do this by gently applying the handbrake while slowly moving to dry them off. Thanks, AG Falco
Do you brake firmly or gently? Do you do long or short journeys? Is this getting worse the damper / colder it gets? Thanks, AG Falco
Fabia Mk3 won't move when first starting
Drum rear brakes also do not like going backwards first as well. Thanks, AG Falco
Mine is doing the same. It helps if you go forward first to unstick them. You can also apply the handbrake gently while driving just before finishing the journey. This will dry them off before you leave the handbrake on for the night. Thanks, AG Falco
Skoda Kamiq TPMS (Tyre Pressure Monitoring System)
Perhaps 3 Bar, then with a 2 Bar loss they would be at 1 Bar. If there is anything less than 1 Bar in a tyre then the tyre pressure is in a state of vacuum. Thanks, AG Falco
