2009 Fabia wont start
Good morning Gabriel, welcome to the forum. Has your battery become discharged - do you have any way of checking battery charge state and condition?
- Hydraulic power steering or Electric?
Parking sensors for MK3 Superb.
I was under the impression that the front assist radar is already fitted as standard, I thought this became mandatory sometime before MY16 model.
For ACC, I believe it can - from my understanding, it involves replacing the left-hand stalk and an adaptation made to the control module. I'm sure Aperture will be able to confirm.
If your budget can support it, recommend considering ACC instead of standard cruise.
Hello, welcome to the forum. Try flagging @ApertureS for this query, I'm pretty sure the retro-fitted parking sensors will operate through the existing infotainment system.
Set Time With VCDS
I'm not sure about the Mk2 - but IIRC the Mk3 has an option to source time from GPS signal.
Clutch pedal hits the floor
I'm afraid so - It is a well known issue, try a search on the forum for sticking clutch pedal.
Assuming brake/clutch fluid level is correct, failing slave or master cylinder.
Flood damage write off
Hello, welcome to the forum. Very good of your garage to let you know. Clearly the loss adjuster is looking for a reason to refuse your claim. My advice would be to just relay what your garage has told you. Don't offer an opinion on anything other than that.
VOTE NOW - the UK decides - rubber mats or carpet in your Skoda? Take part in this important poll...
..... And the rubber mats currently in the lead by more than 2 to 1.
ESC, TPS, Start stop, Front assist, resistance light
If the vehicle has automatic idle stop (stop/start) - and therefore a smart alternator, battery adaptation is required when fitting a new battery.
Hello, welcome to the forum. Was the battery adaptation (coding) carried out when the new battery was fitted? I strongly suggest that get get the battery tested, especially with a load test.
Front assist problems
@Rachaellh Is your Fabia DSG (automatic) ? Are you able to say if the engine had stalled before you lost power steering assistance?
1.4 TSI CZDA fuel rail leak
I'd consider having the injector rail securing bolts checked - especially number 1.
What model year? The North American recall was for MY16 to 18. It seems that VAG Europe has done nothing!
Slight wobble when in motion and roasting hot front wheel
Hello, welcome to the forum. Most likely to be a sticking calliper, if you can, jack the affected wheel off the ground and check for drag when rotated - you can also check the wheel bearing for excess play or damage at the same time.
Collected the car this morning, failure was due to failed injector seal caused by loose securing bolt on number 1 injector. There has been no work done on the fuel system of this vehicle from new. Report of this failure submitted to DVSA.
I voted carpet - but if I was going to be wearing muddy gumboots a lot, it would be be one for the rubber fetish 😁.
Major Fuel Leak - Due to bolts shearing on the fuel injector rail assembly
Got a call from workshop this afternoon, car ready to be picked up. I've not seen the report yet, but initial findings are - securing bolt at injector 1 loose and fuel leak from the sealing ring. There has never been any post delivery work done on the inlet manifold or injectors since new. I will report this fault to DVSA.
Engine Locked Up
I'm wondering if the engine has become hydro-locked (cylinder/s filled with fuel or coolant) - I guess the techs will soon find out when they pull the injectors.
What is this and where should it be put????
That is the pawl that damps the glove compartment as it opens. It fits inside the stay lever on the left side of the glovebox. I suspect it got displaced when the pollen filter was changed - or the fuse board was accessed.
Bodyword, paint warranty
I'd suggest a thorough trawl through the exclusion clauses in the used approved policy for any mention of the supposed bodywork. In your circumstances, it is difficult to see how the supposed bodywork was not known to the dealer.
Hello, welcome to the forum. From your description, the steering did not actually lock - it sounds that what you experienced was loss of power steering assistance. Front assist only operates the brakes and is not connected to the steering. Is your gearbox DSG? Was your engine still running when you lost steering assistance - or had it stalled? When this happened, did you find that you had to press the brake pedal really hard too?
