Smoke from exhaust when off the throttle ??
At least the compression test might give some indication why oil is being used. 1/4 L in 500 miles isn't too catastrophic, and it may well be the case it will be uneconomic to rectify the problem.
@Ootohere Interesting reaction - Twin-chargers have a turbo as well as a blower.
Blue exhaust smoke on overrun will be burnt lubricating oil - either from worn/damaged oil control rings, worn valve stem seals, or faulty turbo seals. How much lube oil is being used ? The first test should be to get a compression test done.
Either that - or really bad flat-spotting under brake lock-up - which shouldn't happen if the ABS is working correctly.
Cars with nice backdrops...
I'd love it even more in BRG.
- Skoda 1.2 CGPA Rattling Problem
Disabling Car Alarm by Disconnecting the Battery?
I strongly suspect that the alarm operation will be 'Fail Secure' and will sound if the battery is disconnected while the alarm is armed.
The faulty door sensor could well be the cause of the alarm being triggered. as mentioned before, the alarm has its own, integrated, battery, disconnecting the vehicle battery will not disable the alarm.
Battery Change 202 Kamiq SEl
That sounds like you were working in the Jackson Bay area - or Big Bay in the Southland Region - Crays?
So… how long can a battery sit for?
The reason for limiting the charge to approx. 75% is to allow capacity for regenerative charging under overrun/braking conditions (micro-hybrid) Actually, provided they are not subjected to overcharging, lead acid battery life is better if they are charged to 100%, due to reduction of hard sulphation of the plates.
One thing to remember, even if Stop/Start is deactivated every trip, battery SOC will rarely ever be more than 75-80% charged due to the way the smart charging alternator operates.
A recent experience may help serve as a guide. Car - bought new in October 2015 (MY16) Octavia Combi 1.4 TSI, manual 6-speed. 31K miles. Battery, Moll EFB fitted new in 2016 as a warranty replacement - so battery 9 years old. Automatic stop/start is always used. I occasionally charge the battery due to frequent short trips (as evidenced by very low miles) The last charge was on June 1st. Battery was fully charged before trip (Ring RSC608) vehicle was static for 35 days, battery charge state was tested on return from trip and was 53% SAE (12.33VDC) / 66% DIN (12.31 VDC) Test report was Good Battery but requires charging.
2017 1.0 tsi (CHZD MQ250)clutch slipping under load. Replacement guide?
Welcome to the forum. I'd check with seller to make sure this is a M6 gearbox - and not a DSG.
Error lights when towing caravan.
Was the error referring to 'Brake lights' instead of just 'Brakes'? If so, a strong possibility that a dirty connection in the trailer connection was raising an issue where bulb failure detection was in operation. Disconnecting, then reconnecting the plug may have served to clean the connection.
PDF FIlter remove
Hello, welcome to the forum. What filter do you mean? Do you mean the Air Filter, or either DPF or PPF on the exhaust system?
Coolant issue
Unable to read dipstick as image is out of focus, but considering 1 year and more than 12,000 Km, I wouldn't consider that you have a problem. Was the oil level above minimum level? If so, I'd guess only approx. 0.5 litre used. Do you check oil level between services?
Fuel guage showing full all the time? Mk1 fabia 1.2htp
Do you know if your son has driven more than 70 miles since filling the tank? It is fairly common for fuel gauges to not register any movement from full tank for first 50 to 70 miles after fill to brim.
- Octavia 1z5, bulbs and fuses rear lights?
Car lose power and stutters under heavy load (uphill or at higher speeds) Skoda Octavia Mk3 SE TSi Manual Petrol 1395cc
Hello, welcome to the forum. From your description, it sounds as if you have a misfire under load - have the spark plugs been checked? Do you know if they have ever been changed? A DTC scan should show high misfire counts if faulty plugs or coil packs are the cause. Misfires can cause the EPC indicator to light up - Stop/Start will be inhibited when EPC is lit.
Complete loss of power
Post deleted.
Manufacturer of battery is not important and serial number can simply be existing number with last digit changed. Agree with items 1,3 & 4.
The battery adaptation (coding) issue is not unique to Kamiq - it applies to ANY vehicle fitted with smart alternator charging control, which will include virtually all vehicles fitted with stop/start function.
Water temperature
Welcome to the forum. If your question is 'Is this Normal' ? no, it's not - most likely you have an issue with the thermostatic sliding sleeve on the coolant pump.
