DieselMontes BarnFind Subaru Justy
Re the flywheel teeth, they do take a bit of a hammering from the Bendix starter pinion, not usually too much of a problem if only the leading edge. Don't forget to add the mandatory small coil of fencing wire to the spares kit 😄
Nominal charging voltage 1.2TSI ?
Taking a look at OPs profile, has both Mk2 & Mk3 - the voltages quoted would be as expected for Mk3 (with stop-start) but I would be checking voltage regulation if on mk2 and a constant figure. I'd expect to see a maximum constant charge figure of 13.8 VDC and a floating charge 13.2 VDC on a standard L-A battery and alternator.
As this is posted in Mk2 section, therefor assumed not to have smart alternator and EFB/AGM battery, I'd think that the voltage quoted to be a little high - particularly if constant. Off for a little refresher course on old battery tech.
Autocruise retrofit on 2024 FAbia Colour edition
Aperture should receive a flag from my post. Take a look at his project post.
You could try messaging @ApertureS for advice on what is possible retrofit wise.
Replacement engine required Skoda Super 2016 2.00 TDI
Of more than a little concern that OPs garage , unless misreported, is that they do not know correct valve drive of engine.
Can I disconnect the air con compressor to test the engine?
👍of course, I forgot about the TDI setup.
What were the symptoms of the recent break down?
Doesn't the serpentine belt also drive the water pump and alternator? There would be no issue in removing the belt to manually check the AC compressor, but obviously, the other ancillaries would be disabled if you were to actually run the engine.
- Skoda superb mk2 car battery bem coding
Superb Mk2 Estate boot doesn't open fully
Most likely that the trunk gas struts have lost pressure. Usually a pretty easy DIY job to fit replacement struts - make sure you get correct pressure replacements.
Power steering issue
Hello, welcome to the forum. Unfortunately, they will likely ignore anything you tell them. Hopefully you haven't cleared the DTCs, see what they say. If they claim that no DTC had been recorded, show them a screen shot of fault recorded.
I'm confused - you say you have Mk2 estate - video clip appears to show notch back saloon.
Battery issue or something more serious?
A decent DMM need not cost much and is a useful addition to the toolbox, also useful for testing fuses, lamps, etc. - in car and around the house. Something with a resolution count of 4k to 6k and it's certainly not necessary go to the heights of a Fluke.
Hello, the BEM code is not critical - just use any code available, or leave original as is. The only critical data to update the BCM is - Battery chemistry (AGM/EFB) Battery capacity (A/hrs) Alteration to last digit of existing battery serial number to flag that the battery has been replaced.
Yes, I was referring to stop-start - it is often a good indicator of low battery SOC when it fails to operate.
Very likely that the low current draw, if sleep mode inhibited, will have incremental effect - my understanding is that even a very low current draw from an unexpected source is sufficient to inhibit.
Petrol Engine Particulate Filter
It depends on driving conditions - as I pointed out in my last post. We have no way of knowing your normal driving conditions. If you do a little searching on the internet, there is information out there.
Battery discharge - fuse 39?
The overnight voltage drop you are currently seeing will be normal - especially given the current battery is faulty. Fit the new battery, carry out correct adaptation (coding) if required - E.G if vehicle has 'smart' alternator, then test again to check if there is any parasitic drain - which I think will be unlikely. Provided the new battery is not discharged below 30% - below approx. 11.8 V for AGM/EFB (or 11.6 V for standard L.A battery) and the battery is recharged immediately after discharge, the battery will suffer no damage.
I'd suggest trying that procedure on a longish down hill section. Get the engine fully up to temperature first. The GPF regen should happen in normal driving - but it appears that frequent slow driving in traffic can inhibit it. Apparently some makes are able to do both passive and active GPF regens - but I haven't found if VAG vehicles can do this.
Hello, welcome to the forum. Have you used the correct method? - it sounds as if you have confused DPF and GPF regen methods. GPF regeneration is done on closed throttle engine overrun.
A battery in good condition will be 75% charged at 12.4 VDC - agree, the only reliable way to test a battery is by imposing a known load and measuring the voltage drop. OP appears to be chasing a possibly phantom parasitic load, while admitting the battery is 'goosed'
Important, the control modules will not go into sleep mode with a door open. You have repeated that the vehicle struggles to start when the battery voltage drops to 12.4 volts - the battery is still 75% charged at that voltage! Unless either the starter, the wiring connections to it - or the battery has a fault, there is no reason the engine shouldn't crank at normal speed - even down to around 12.0 volts (50%) It is critical to know what the voltage falls to when the starter is operated, I suspect that the voltage is dropping critically low due to a battery fault.
What is this camera for?
Flag to @ApertureS Can you advise?
