Superb 3 2.0tdi Crank no Start. Fuel Pump Not Running
Unless they are typos, I am still seeing three reported temperatures between 2 and 3 thousand degrees C, and one (heat delivery temperature in cooling system) of minus 273.1 C! If sensors are in fact sending impossible readings such as these to the ECU, they should be looked at.
Brake Fault Codes
@SKFABM What country are you in?
Will I get away with it?
Longer runs with the engine fully up to temperature are much better for it, you will be fine.
You wrote that 'this will be its second service' - was the vehicle serviced regularly before you purchased it?
Brake Fault Codes
Unless those DTCs are unique to Skoda (unlikely) I don't see any of the three reported having a connection with brake performance. What year is your Fabia? That is a very serious defect, have the brakes been inspected by a competent mechanic? Is the brake fluid level correct? When the brakes do operate correctly, does the pedal feel 'spongy' at all - which feeling then improves if the pedal is pumped?
Brake Fault Codes
Hello, welcome to the forum. It will help others if you post engine code and fuel type. Would also help if a description of how these reported faults affect the vehicle (symptoms) is given. A quick search online found - B116829 = Steering angle sensor fault. C102DF5 = Power steering fault (possibly excess resistance to movement). The first two faults may possibly be connected. U042300 = Invalid data from instrument panel control cluster.
Dodgy fuel filler pipe
So presumably, the internal coil spring is part of a check valve? That's going to need a pair of very long-nose pliers to get out.
Is it possible to post an in-focus, close-up exterior shot of the copper tube with the endoscope?
Nothing like that in the Mk111 filler, but might be best waiting for confirmation from Mk11 owner before attempting removal.
Hello, welcome to the forum. That does rather look like part of a flexible spout similar to the type fitted to 'dodgy' Jerry cans. I'll just check my Mk111 filler. Looks too high in the filler to be an anti-syphon fitting.
Oil pump on 1.4 v 1.8
Perhaps, if you had been chancing your licence with a WOT blast around the Road to Hell - then come across its more usual car park conditions, it might be reasonable to allow the engine to idle short period before shutting down, but it's normally not necessary.
= Wide Open Throttle. Though wasn't a typo.
Sump Replacement
From other posts it appears that OP has Mk3 Superb, 1.4TSI - therefore EA211 with cambelt.
Quite possible, I've seen at least one other reference to hard to start TDI being resolved by replacing a faulty temperature sensor.
I believe that VAG state that this procedure is no longer necessary due to the turbo being water-cooled and the fitting of the auxiliary coolant pump. Probably still not a bad idea to follow the old shutdown procedure for 30 secs or so following a WOT blast though.
1.4 TSi Air Filter replacement - Harder than it should be
Hello, welcome to the forum. I found no specific removal order of the hoses necessary. Tip 1 - Make sure the hose clamps are completely clear of the internal spigot of the air induction ducting, the convoluted hose will come off reasonably easily once you do this. Tip 2 - definitely recommend in investing in a proper set of hose clip pliers as shown in Silver1011s post, they are not expensive and make removing the clips so easy. Get the type that will lock in open position so that the clip can easily be moved up the hose, clear of the clamping area. Tip 3 - for the push-on breather hose, gently twist with your hand before pulling off elbow. Tip 4 - Don't be mislead in thinking that it's only the sprung clips holding the airbox lid to the body, there are screws (pozi-drive I think) hidden on the underside of the airbox too - only accessible from beneath! If you think that's a stupid idea - so do I!
Oil usage
With the original issue of using (or losing) 2 litres of oil in just over 1K miles - while not reporting loss of coolant at the same time, I'd say the possible HG failure is probably a symptom, not the cause. Almost a certainty that, at the very least, the piston oil control rings have failed.
IIRC, there is an auxiliary coolant (not oil) pump to alleviate risk of excess heat transfer to oil on engine shutdown.
Sump Replacement
Just reflecting on your query about the cambelt - there just might be a date stamp on the outside face along with the manufacturer brand marking.
Sump Replacement
I wouldn't buy the 'It's NOS from 2015' story if that's what they say - even if they did try it, did they charge you 2015 price? 😆
Sump Replacement
I'd challenge your garage if they charged you for an air filter change that clearly was not carried out. Is this an official Skoda garage? At the very least, I'd be looking for a trusted independent specialist for any further work.
Sump Replacement
Practically impossible to tell visually, were you supplied with an itemised invoice for the work? Other than the non-replacement of the air filter, do you have a reason to suspect it wasn't? I had my belt changed at 6 years, although at less than 1/2 your mileage - this was when Skoda UK were still stating replacement at 5 years - the belt and tensioner looked in practically new condition. Apart from the potential fraud, there is no need for particular concern, Skoda UK are now quoting timing belt as 'lifetime' with (I think) replacement at mileage well in excess of 100K miles.
Engine help , cracked mount.
@WorkHorse what was the cause of your damage, collision?
Sump Replacement
That is what VAG say, although I believe it's too long when you consider how many cubic metres of quite polluted air will be drawn through it in that time. If TSI, do you know if the spark plugs were replaced at 4 years/40k ?
Sump Replacement
VAG do have what I believe to be an unrealistically long air filter change interval - I made a post quite a few years ago regarding this. I'll need to check what VAG schedule is, but I consider it to be too long.
