How to keep our Roomster on the road
What was the reason for vehicle not being recovered to home address?
The 'prongs' in the expansion bottle refer to the coolant level sensor - low coolant warning on instrument panel would be correct if level is lower than minimum mark. When was the last time you checked the coolant level?
Dashboard "Check Left Stop Light" warning.
Check for voltage with meter at the lamp holder contact, if correct voltage present, gently tap bulb (if filament type) while testing for continuity.
ABS sensor removal. Any tips?
There are much better release fluids available - Plus Gas is one of them. WD40 is primarily a lubricant.
Dashboard illuminates like a Christmas Tree!
Can you explain how the battery was tested? Was the battery fully charged before being load tested at a high rate discharge? Alternatively, checking battery voltage with a DMM while cranking the engine can give some useful idea of condition.
- Engine temperature does not go above 55
Clutch issue
AFAIK, brake fluid level that low should be flagging a warning on the instrument cluster. Can you see a sensor on the reservoir?
Advice - high mileage Skoda Octavia with limited service history.
I can't advise on the 1.0 95PS TSI - but SWMBOs 110PS Fabia pulls well and comes with the 6M gearbox.
From that indicated 127 f from the OBD, it does seem that the engine is running cold - unless the sensors are faulty and sending low readings to the ECU. Are you able to take a temperature reading of cylinder head with (say) an IR thermometer? If head temperature is broadly similar to the one from the OBD, the only way I can see engine temperatures remaining as low as indicated is the thermostats remaining open all the time (or the cooling fans running constantly) - even then, the engine should eventually reach normal temperature.
Superb 2.0 TDI SCR 190 4X4 Laurin & Klement DSG - Potential purchase - PK17 EBZ
Sorry to hear of your write-off. I don't see any reference to service history in the description. Ask for print out of electronic history, including DSG services. Be aware of common problem with Pan roof water leaks.
Lego / Rocks sound coming from the front of my car
Hello, welcome to the forum. What makes you think there is no pollen filter fitted to the Mk3 Fabia?
Loss of all brake fluid….
Calliper or flex hose failure wouldn't leak brake fluid onto the front carpet - suggest checking the master cylinder too.
front park pilot automatique
I would translate 'Park Pilot Automatique' as self parking - although specifying 'Front' somewhat confuses things. My understanding is that Automatic Parking normally involves driving slowly past the proposed space, bringing vehicle to a stop when confirmed that the space is suitable and engaging the function - the vehicle then reverses into the space.
What's the difference in 1.5tsi 115 and 150hp engines (DXD, evo 2 family)
Most likely just a detuned version for the 115 - less fuel injected and lower boost pressure.
Glowplug failure and Ticking noise from the engine
Hello, welcome to the forum. Very possibly a faulty fuel injector, a VCDS scan should show the cause of fault.
Obviously DSG doesn't have a driver-operated clutch cylinder.
Cold start noise; 2011 VRS 2.0
@Crasher can probably advise, I have seen estimated prices of £1500 posted on two separate VAG websites. One site was VW Audi Forum (VWAF). Try googling EA888 camchain replacement price.
I believe the Mk3 brake master cylinder reservoir shares the fluid with the clutch, with the brake fluid being taken from the reservoir lower down than the clutch take-off. It sounds like the master cylinder has failed.
No turn light (flashers) when locking
To test if any door is not actually locking when it should, try locking with the fob - then check each door and trunk.
New engine needed…
Is the probable reason for engine seizure known - was it seriously overheated or run without oil?
Clutch replacement
Have you checked for a comparative quote from a clutch specialist? Almost certain to be considerably cheaper, as some stealers charge up to £200 an hour. You could also try one of the mobile specialists. 😒 Just noticed that I misread OP, I missed the 'Charged' - read it as Quoted. Clearly too late to get a comparison price. Should have gone to SpecSavers!
New engine needed…
You need to check, you can find your engine code as the 4 letter prefix to the engine number on your V5 registration document - it is also often on a label on the B pillar.
