1756 or 1752? And other things
I strongly suspect that if you take the engine output to anywhere near the figures you first suggested, you will very soon be looking for a replacement engine.
Not a true Fabia question
It's not unheard-of for new batteries to fail prematurely, definitely the first thing you need to do is carry out a load test on the battery. If you do not have a load tester available, the easiest way to do this is with a fast-response DMM on the battery terminals while someone cranks the engine. The near-fully charged battery dropping to around 8.0 VDC while only loaded with ancillaries and glow-plugs strongly suggests your battery is faulty.
Hello, welcome to the forum. I cannot see that an attempt to increase the power of a 20 year old engine by more than 60% will end well - especially on a low budget!
^^^ True for batteries with removeable cell plugs - pretty rare now, mostly sealed type.
What voltage are you reading on the meter at the terminals when the alternator is operating?
Not necessarily, the bad cell will still be in circuit (series), but drop its voltage when its on load.
Happy New Year. I'd suggest first checking the battery terminals for tightness, then having the battery load tested - dropping to 8 volts strongly suggests a faulty cell in the battery.
Replacement Battery
I assume that you actually meant you changed the settings FROM 70 AH to 90 AH for the new battery?
- Front Assist not working, but no error messages appear.
Charging ever bigger batteries
Interesting - does that Synchronous Compensator operate in the same manner as a Rotary UPS?
Misfueled Petrol engine with Diesel
@LukeWarmWorm What was the cost of the misfuelling specialist callout?
ESC error car won’t start.
I don't drive a diesel, but isn't there a start delay holdoff to allow the glow plugs to reach ignition temperature?
ACC Retrofit for Scala
Be very cautious if you intend to use 'One Click' coding - it can result in unwanted, and difficult (or impossible) to reverse changes. You would be strongly advised to download all existing settings before making ANY changes.
Hello Ian, welcome to the forum. It is highly unlikely that the ESC error indication will be the cause of the failure of the engine turning over and is probably coincidental. Has the vehicle been scanned for any DTCs? Are the glow plugs working correctly? Did you have the alternator output tested?
Hello Luke, welcome to the forum. If the tank and fuel lines were flushed, I'd be inclined to leave the filter as it is - unless the diesel was badly contaminated too. Any remaining diesel fuel will be flushed out of the filter almost immediately. Petrol through a diesel fuel pump might have been a little worse though, but I'd still think the possibility of damage to be pretty low. I think I've seen references to the filter being integral with the pump.
Cruise Control fitting
...or would demand unreasonable price to do.
Clutch issue? Help?
Does this 'whining' noise happen just as the clutch starts to engage - I.e. before the vehicle actually starts to move?
Is My FABIA a belt driven or Chain driven car
Hello, welcome to the forum. MPI or TDI? Please check and post here your engine code - this can be found listed on the vehicle registration document at the beginning of the engine number (3 or 4 letter characters)
New to me Superb IV: central locking set up?
Not sure for the MkiV, MIB3 but on the MIB2 infotainment there is an option (tick-box) to select automatic door locking in the Convenience section.
Yeti 60l saddle tank, twin sender units??????? also fuel guage calibration
I just reported another of their posts on a different subject. Seems to be a troll.
warning in stop start system
Assuming you have the MIB2 infotainment system (or possibly MIB2.5 if yours is a face-lift model) working from memory, if you touch the fault icon showing at the lower left of the screen, you should be able to read a brief description of the supposed cause of the fault - 'Load too high' while stop-start is unavailable is what mine flags if battery SOC is low.
The first thing to do is get the battery tested - preferably with a high-rate load test. There is usually a date stamp on the top of the battery negative terminal (the one furthest from the front) the code format is WW,YY. E.g. 0116 will be first week in 2016.
What Do We Think?
Has the front subframe misalignment you mention in the 3rg para. of your original post returned? You posted that the subframe 'popped back into place' when the bolts were loosened - a little concerning, I thought.
