Everything posted by bigjohn
Road Tax on 6 months old Karoq
I don't think the Karoq 1.5TSI DSG SEL that Logiclee has bought would be in the £40k+ list price new category. Saying that my mate fell in that trap buying a nearly new Volvo S90 a few years ago - tax was a surprise as it's original list was just over £40k, ouch. Fortunately it's over the first year ( or less) + 5 years now.
You can't pay monthly when new - From Gov.uk:- "You’ll pay a rate based on a vehicle’s CO2 emissions the first time it’s registered." & "This payment covers your vehicle for 12 months." then "Rates for second tax payment onwards"
Are the higher spec seats more comfortable?
It's just a figure of speech - I've used the same statement in the past to describe good condition cars when middle aged. I wondered if it was a regional phrase, but possibly not as I'm from Yorkshire and OP is shown as in Suffolk.
As far as I know the extra £40 is paid by the original owner at point of registration and that part wouldn't have been refunded. That's why the wording was changed to "First licence rates for cars". So £190 thereafter , well unless the original list price was over £40k.
It's classed as "First licence rates for cars" payable on registration so thereafter I would suggest it'll be £190 for the year.
Service book replacement?
Even my older 2014 mkII Superb didn't come with a service book but a dealer electronic printout. When I stopped using the main dealer post warranty by a year or so I bought a blank Skoda service book and inserted the latest printout at the beginning, since then my great local independent garage has filled in / stamped it for any servicing / repair work.
Nextbase rear dashcam Installation
Thanks, you are indeed correct!!!! I've removed the A pillar trim and relocated the wires.
Mine is a poverty spec mkIi and as far as I know if doesn't have A pillar air bags - no plastic "airbag" badge as there is on the B pillar. Cable is routed around the top to the door seal. Obviously @numskull has a mk iii so it's an important note but hopefully that shouldn't be an issue as that car already has wiring for a dash cam so the route is already known. I was mainly trying to show how the rear camera was mounted / cables routed for the rear hatch. I've deleted the A pillar photos as clearly not relevant.
Opening bonet with dead battery
Good point - I myself thought I had a fault when I first got my Superb II and asked the dealer - doh! As far as I remember my 2001 Octavia and 2003 Superb didn't have such a message when they were deadlocked.
Deadlocks were introduced in the 90's along with immobilisers to combat rapidly increasing levels of car theft. Generally this was successful - well until KESSY introduced anyway. You get a dash warning on turning off when about to leave the car - it is however usually possible on many VAG cars to lock doors without deadlocks by double pressing the lock button, this usually disables most of the alarm as well.
New 24 Scala Ordered today
Actually the 4 speed gearbox as fitted to rwd cars back in the day was pretty efficient in 4th gear. In a way you effectively weren't using gears to pass drive as the input shaft was connected to the output shaft directly 1 - 1. With older rwd Fords / Vauxhalls I rebuilt many an engine but never a gearbox. That changed as 5 speed boxes arrived eg Sierra. Saying that though cars back then were screamers at motorway speeds. Back to the original thread has anyone had delivered/ driven the 24 model car yet? I'm looking with interest but am waiting to see how the new evo2 engine performs. Theoretically it should be more economical etc.
I've fitted one to a Superb mkII twin hatch where the rear camera is mounted at the top of the hatch window just below the high level brake light with the wire passing over to the top of the hatch opening / top of rubber seal with just enough wire length to allow the hatch to open ok without disturbing the camera. The wire is then hidden following the top rubber hatch seal , the around the top of a trim panel (drivers side behind rear seat) and then down behind the rubber rear door seal down to the sill trim and onwards to the front drivers door rubber seal eventually finding its way up the drivers side windscreen pillar and behind trim all the way to the windscreen mounted Nextbase dashcam. Pretty straight forward with no brittle clips disturbed. It has worked well for quite a few years now. Hope this helps.
mpg
Likewise re 1970 Ford Zodiac 3.0 (also circa 1980) - 19 gallon tank that didn't last long. I don't think it ever managed 20mpg even on a run, around town it wasn't even managing double figures. Fast forward to today with my ageing 1.4tsi Superb which is still a barge of a car Overall of 46 mpg with 50 mpg on a steady run - wow! Currently thinking of downsizing to potentially one car so Fabia/Scala/Kamiq in focus. Octavia ruled out as some basic functions (eg heating) on the touch screen.
- mpg
mpg
I have some friends with a 1923 Morris Bullnose which was new before leaded petrol was available (was invented in the 20's) - great but you were suppose to re grind the valves every 1000 miles!
mpg
Funnily enough I had a Moggy Minor 948cc but that was more economical than 35mpg - more like 40+ but it did a lot of longish runs . Various Fords were awful though MKII Cortina 1300cc(pre crossflow) was mid 20's mpg and with a mkIv 3.0l Zodiac you had to turn it off filling up to stop gaining on them! One surprise was a 76 Datsun 100a which did over 50mpg on a run - it was a great car except for the dreaded rust.
1.5 Tsi Power Cutting Out
Evo 2 now. Is this the reason?
Clutch and flywheel failure. 2.0tdi cffb
Could this be an engine/gearbox mount issue rather that DMF? Typically (er not always) DMF failure shows initially at tickover in neutral with clutch pedal released and quietens when clutch pedal depressed and / or revs are raised - unless DMF really really bad. I think the original clutch gubbins fitted to the 2.0 diesel was Sachs - there were many reports back in the day of the Sachs pressure plate failing and machining through the gearbox case - all long gone these days I suspect:-
Driving in Europe with standard LED lights
I've just commented on the Scala forum as I've been considering a Scala or even possibly a Kamiq (boot size might be an issue for me) but looking at recent manuals for Scala and Kamiq I think the new 2024 models do not need Eurolites etc stuck on the headlights:- https://manual.skoda-auto.com/004/en-com/Models - Look at "Lighting, windscreen wiper and washers"/ "exterior Lighting" / "settings". So no stickers needed as far as I can see in the 2024 manual. "With adaptive functions engage travel mode feature. Without adaptive functions. The headlights meet the requirements for driving in countries with opposite traffic direction. No headlight adjustment is necessary. " I looked at the 2021 manual there is no mention re non adaptive headlights - so no idea.
Driving abroad headlight adjustment
Bringing an old thread up to date as I'm re investigating the Scala and I drive into Europe a few times a year:- https://manual.skoda-auto.com/004/en-com/Models So no stickers needed as far as I can see in the 2024 manual. "With adaptive functions engage travel mode feature. Without adaptive functions. The headlights meet the requirements for driving in countries with opposite traffic direction. No headlight adjustment is necessary. " I looked at the 2021 manual there is no mention re non adaptive headlights - so no idea.
Octavia low beam peoblem
Not legal in the uk
Another high oil consumption Octavia!
Reject the car - https://www.theaa.com/car-buying/legal-rights
So Scala owners, what do you think to your car ?
Trend - Currently SUV attracts buyers like a flame attracts moths. From afar I'm eyeing up the Scala possibly a year old one, problem is my ageing Superb II is still too good to part with. I'm slightly concerned re major infotainment & SOS bugs as reported on this forum though, I might wait until the 2024 model has settled as the SE then has climate control with buttons and I prefer the look of the interior upholstery. The 1.0 will also be available as 116ps.
clutch pedal sticking
Why? I think the 1.6 diesel is fitted with an external slave cylinder so not a gearbox off job and cheapish to do - especially if you are doing it at the same time as other clutch hydraulics. The 2.0 diesel has a concentric slave - now that's a big gearbox off job.
