Everything posted by Danoid
SKODA SUPERB HEADLIGHT MELTING PROBLEM
Hmm raise it with them and Skoda customer services if you have to. Last thing you want to do is fork out loads in the future
Rear seatbelt
You’ll need to remove the seat, unbolt the lock, then when it’s removed shake it about until whatever is in there comes out then refit. When you put the lock remember to torque it correctly. There was someone on here recently who found an old bit of glass which fell in and stopped it locking, so it’s fixable for you too hopefully
Battery drain - Columbus update?
When you replaced the battery was it done correctly by changing settings using vcds etc?
Rear nearside vent glass replacement
Go through insurance, £30 or so excess and jobs a goodun. I not long had a replacement windscreen through a claim, auto glass fixed the stone chip which didn’t help, so whole new windscreen but I insisted on genuine, two times they turned up with non genuine and 3rd they did, I didn’t have to pay more than the £10 for the windscreen chip and insurance didn’t go up (in fact it went down this year). if your back window is tinted I’d insist on genuine part too as non OEM is bound to be slightly lighter or darker
Skoda Superb Rear vs Front emblem
Weird how they have front but not rear in your colour, that’s a bit… thick
Scorched discs?
Check they were fitted the correct way as they’re directional pads too
Replacement brake dust shield?
Oh didn’t realise they were that cheap tbh, was expecting treble what you said at least
Get them off and do an Edd China special*, be cheaper, unless they’re too far gone * Satin black spray
What are your thoughts
If you’re only going to do short miles do you really need such a large car and pricey? I guess you won’t always do roughly 4 miles but have you considered an older and much cheaper car? I’m hardly one to talk only doing 3k a year but if you can save loads of money might as well, if money isn’t really a problem then no problem paying to fix things if they go wrong
IMO everytime a service is done you should at least take the air filter out and give it a bash and vacuum, but as they’re cheap no issues replacing as well
EPC error
What was up with it?
GPS Issue - is it Aerial, Amp or connection? Superb Mk3 2017 Estate/Combi
Also have you had it checked for codes? One other thing which is worth a shot, if your maps aren’t update to date, update them as it does a proper reboot of satnav, I guess you’ve updated them before? If not there is a guide on here I can point you to
Not sure tbh, someone’s bound to have made one even if it’s for a golf or so as it’ll somewhat similar speaking of golf, have you searched for something like “vw golf mk7 gps position incorrect”, there’s a few posts with similiar problems to you, someone’s got fixed after changing head unit completely eek. He had it in with VW who changed antenna etc but didn’t help. So if I were you I’d try disconnecting and reconnecting antenna and connectors to head unit (I believe some of them go to the unit in glove box) Another thing, is your compass showing correctly?
EPC error
Is it a courtesy car they gave you? Looks alright to me. I wonder what the purpose of that cubby hole is hmm Saying that the pockets on the superbs seats, anyone found a purpose for them? Is the driver meant to put something in the passenger pocket and passenger in drivers? 😮
It would be best to remove the shark fin and check part number. You’ll be able to check the connectors whilst there.
Dampers. I know, I know.
If it helps I know people who have fitted B4’s to Fiat 500’s as will I be soon. They say it’s a slightly firmer ride which is a good thing. One of my friends has Koni actives on his beemer and loves them, he does a lot of miles a year and been on there the last 5 or so years
That’s true but insurance companies like to get out from paying anything so better safe than sorry
B4 is meant to give you OE comfort plus a little better B6 is more harder and would require insurance to be informed I suspect If it was me I’d go B4 as I prefer comfort to bang crash hardness
Coasting & ECO Mode
Eco mode gives you the ability to coast but acc deactivates this feature because it’ll slow the car down using engine braking and brakes. With acc disabled and you go down a hill your car will just free fall Basically your car is fine
Wasn’t aware you could get them separately, make sense you can though
Yes but you can’t buy them on their own https://www.amazon.co.uk/Skoda-Genuine-Alloy-Covers-Locking/dp/B08PL6HVHD/ref=asc_df_B08PL6HVHD/?tag=googshopuk-21&linkCode=df0&hvadid=500890667741&hvpos=&hvnetw=g&hvrand=2143506665368710700&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9045795&hvtargid=pla-1276197924917&psc=1&mcid=351b6f41c156336ca8927618564ff01d by the way they may or may not fit, just random quick search to show you
Rear seat belt wont click in.
Nice result that from an unfortunate circumstance 😞
Shake it to death
Have you tried looking inside with a torch? Might be something has fallen inside
12v cover in boot
Cover didn’t come off, but I must have pushed it back somehow when I had the fan plugged in so the cover was open as such
