Danoid
Everything posted by Danoid
  1. I did hear drivers side there’s more room, but not sure if I’m imagining it
  2. I’ve almost made my mind up on which new bulbs to go for, almost… Do both wheel arch liners need to be removed to get access to the bulb, or is it just the passengers? Thanks
  3. If you were to put that in the arches make sure it’s 100% waterproof. Passats use to have foam inside probably to lesson sound, but it was made of foam and when it got wet it had no where to go other than out, which caused rusty wheel arches
  4. Watch this I’ve personally used the ac bomb, but next time I’ll follow this video Also get a new pollen filter, the Mann one which has the charcoal etc What he does is done on an octavia but I’m sure that pipe is present on the superb too
  5. Ah I see, I don’t have the issue but sounds like I probably will at some point so good to know
  6. How are people greasing them if you can’t get to them? Any pictures would be handy
  7. I almost said to my neighbour “I’ll do your car next” after I watched her cleaning her car with Cif noooo
  8. It should be 3v9 861 411 F @ £337.64 today No guarantees this is the correct p/n for your vehicle
  9. Pop in and ask the shop if they picked it up
  10. Which year? Estate or saloon? (Not sure if it’s only available on estate) I’ll have a look later when you tell me but don’t take it as 100% accurate but I’ll try my best
  11. Get some pictures on here, I’d imagine at such low miles you just need to turn eco mode on to brings the tears back to life and some heavy (when safe to do so) some 70ish mph to 0 stops to bring the fronts back to life
  12. https://www.tayna.co.uk/car-batteries/?gclid=EAIaIQobChMIjt2Cw_H4-gIVh7btCh1ang2SEAAYASAAEgKtZPD_BwE I believe that’s where I bought a battery for my old Passat from, or it was battery mega store. Tanya whack in your reg and it should already know if your battery is EFB if not make sure you click the EFB tab Once you got the model number you can do more searching if anyone has it cheaper. I’ll be honest I’m not sure if it’s only stop start that needs coding, hopefully someone else can clarify
  13. Very likely to be your battery, it’s around the right time for batteries to start dying with colder evenings. Have a look at your battery and see if it’s still the OE one as that could be the same battery it’s had all its life. What year is your car? If it is the original make a note of what battery you have, they’ll be a sticker saying AGM or something else B?? Then buy a direct Varta replacement. If it’s not obvious to you post a picture on here You’ll need it coded to your car
  14. I believe I read it on here that when you change the battery you need to start the car and do full steering lock left and right a few times, and yes get it coded in, as long as the battery size is the same you’re good the other code can literally be any value, just something different to the previous value as I believe not all batteries have the correct stickers https://youtu.be/IJAScg6JrYI
  15. If you know German give this guys channel a watch, some of its English aswell I’ve linked the very bulbs I’m decided whether to get but watch his others as he does light output and on a Skoda albeit a octavia https://youtu.be/EKVgD2TYMUI
  16. I played hardish to catch when I bought my car from a main dealer. In the end I got £2k off, four free services and free MOT for life, which is what I asked for straight away I went in saying I don’t want to play the fake ping pong of salesmen going to the manager then back and forth, I said I want to deal with the manager only, they accepted my request straight away so they probably still made plenty off me, but I did PCP so probably thought I’d get a new car when my deal ends but I paid the balloon payment
  17. Nightmare, mine was like a pond too but only issue I ever had was the alarm going off on all hours which turned out to be corroded grey connector in the passenger kick panel. Why VW decided to use a foam gasket by the pollen filter I’ll never know Glad to know the same issue isn’t present in the Superb 👍
  18. I was once a Passat b5.5 man, the ccm placement still gives me nightmares. If you are asking because of anxiety, the scuttle area should still be cleaned on the Superb apprantly, but it’s even harder to get to because you need to remove the wipers 😬
  19. My habit is starting the car and literally saying “turn that @“£&@“ off” So OP if you can get into a habit of turning it off it’s much cheaper and easier
  20. What do your rear discs look like? Upload a picture if you can as it’s always a laugh This was mine before I replaced, ignore the red line. This was at around 37k miles the outer section was never used 😂
  21. Haha I had exactly the same with stalling, I was like how on earth can I stall an automatic. I went with Brembo coated discs as I got annoyed with the rusting, and skoda OE pads fitted by my local Skoda dealer, stops, it was still like £180 but the time I’d bought a battery maintainer and VCDS it just worked out cheaper to let them do it
  22. The DSG gearbox can be a little jerky and it’ll be something you get use to. Its worth mentioning the gearbox oil and filter should be changed every 40k miles, but check if it’s ever been serviced as dealers don’t seem to mention it, at least not mine and some others on here 😞 Also check the condition of your rear discs and pads, OEM is a bit of an Achilles heal. My car is smoother and quicker at releasing the handbrake since changing them
  23. They do indeed, I just like the peace of mind knowing mine still over reads by design incase there’s a speed camera van fishing, as the more the tyre wears with 245’s your going even more faster. That shouldn’t matter much unless you live on the 10%+2mph edge all the time
  24. I only do about 3k a year so don’t listen to me for a long term review 😬 My friends probably covered about 5k since May and recently went to Wales on what he called rough roads, when he got back is when he said how much of a difference the 5 and 6 is
  25. That’s possible, I doubt I’ve put more than 1k on them since sometime in May so time will tell but so far so good These are EV rated so I’d like to think they’ll stay quiet
