Everything posted by Cairus
Replacement instrument cluster
I have the Tools die Change Immo but Austria is "far" away 😅
BCM Removal?
I never Take it Out for Retrofit Trailer electric.
Can you Change only the Broken parts? Without Immo Chip
LED replacement
If this is the version of the headlights where daytime running lights and indicators are in one, there is a control unit and a repair cover
Drivers heated seat not working
Read the Error Log.
VCDS Coder near me
Which Car? Which Model year?
LED replacement
Which Type of Headlights you have? PHOTO?
LED replacement
Warrenty or you have To Pay?
- Replacement Climate panel issue - ventilated seat retrofit
LED replacement
But the daytime running light works?
Fault codes after changing battery
You can trigger the dynamic ACC calibration drive with any good diagnostic tool. However, this only works if the sensor is adjusted within a certain tolerance. Otherwise, you'll have to do the static one. But before doing that, check the mechanics.
Mark 3 steering wheel to mark 2 fl
Yes
LED replacement
The LED Indikator realy dont Work?
You need the steering Wheel Button from Superb 2 Facelift
Amundsen MIB2 Firmware Update
You have the latest Firmware for this Firmware Train
Do I need beam converters on my headlights
You have no travel Mode in the Multimedia System?
Torque Settings Required Please
Scout Haldex Differential Noise
In series production, it is measured that the pinion to the ring gear is in the position determined by development.
Power drivers seat wiring
Why No Can-Bus?
Error Codes Lights Mulfunctioning
Check the fuse's in the engine compartment
- Obd eleven
Question about Brake upgrade Superb iV Sportline
Also here the note, when upgrading the brake, if you do it correctly, the new brake Hardware must be coded in the ABS
What say the Error Log when you Check this with OBD11 or something Else?
- Facelift Crystal Style taillights in the VFL
