tombee
Everything posted by tombee
  1. Thanks, that makes sense. Found these, which could work, they seem to have the ports but then use cable from the other as they sit in the middle of the cig lighter socket and USB to provide power. https://www.aliexpress.com/item/1005006871500034.html?UTABTest=aliabtest125094_24785&src=google&src=google&albch=shopping&acnt=494-037-6276&slnk=&plac=&mtctp=&albbt=Google_7_shopping&gclsrc=aw.ds&albagn=888888&ds_e_adid=&ds_e_matchtype=&ds_e_device=c&ds_e_network=x&ds_e_product_group_id=&ds_e_product_id=en1005006871500034&ds_e_product_merchant_id=107799086&ds_e_product_country=GB&ds_e_product_language=en&ds_e_product_channel=online&ds_e_product_store_id=&ds_url_v=2&albcp=17859500389&albag=&isSmbAutoCall=false&needSmbHouyi=false&gad_source=1&gad_campaignid=17190468917&gbraid=0AAAAADznYb-0j620LkO-W9rdqyaMif53i&gclid=Cj0KCQiA4eHLBhCzARIsAJ2NZoLmeDqnDWtr0Bgh13IRc_Zg9rdPYWFWZtCDXrbpN-FJeKVk24mmkY4aAk1qEALw_wcB&aff_fcid=83685b43fced42949a2f376be85ddc5f-1769506356085-04032-irey5Th&aff_fsk=irey5Th&aff_platform=promotion&sk=irey5Th&aff_trace_key=83685b43fced42949a2f376be85ddc5f-1769506356085-04032-irey5Th&terminal_id=aa933f27ba7d4e3dbd2407601450c3c0&OLP=1116833308_f_group2&o_s_id=1116833308&afSmartRedirect=n https://ebay.us/m/1r1wiN I have replaced the rear cig lighter along with using the car's wiring for a usb unit, so thinking the cable to sit in the middle of the cars wiring the USB's in the arm rest for a clean look
  2. Ok will do the tops mounts also then Ahh that’s true might leave them out of it for now Thanks
  3. I am thinking of doing the USB port in the arm rest. Would only want power, would use Wireless airplay dongle at the front and just keep the ashtray shut. In using the 5G0035222E, this is the unit that fits the blanking plate under the arm rest? Do you use the USB Hub as a splitter so true feed that currently connects to the front usb port in the ash tray would then feed the hub with then the 2 outports going to the usb A ports? Is that correct?
  4. Did you notice the difference from the oem shocks?
  5. What front splitter i that?
  6. Hey David, Just fitted one to my 2018 Estate last week, ensure that yours is the fully square edged handle, if so which mine was then yes it is option A for the car. No water connection. Just take your time in fitting, took me around 3 hours, taking apart, fitting and then putting back together. I ran the cable from the boot down the sill's and then that way to the glove box, the yellow connectors can be hard to push in but they do go in. I taped mine up so they didn't come apart again etc Oh if it doesn't work after fitting it, hard reset the stereo - Hold down the power button Hope that helps
  7. Going with B6's, these are the part numbers - Bilstein Rear B6 Sport Shock Absorber - 24-229890 Bilstein Front B6 Sport Shock Absorber - 35-229872 Should I do the top mounts at the same time, also do the rubber boots etc too. Wondering due to a front bush going if I should do a the SuperPro, are these arms worth it and also which ones?
  8. Yup, just been out with a Skoda Tech and he said yup feels how they feel, he did work at VW and said that the Passat's feel more planted than the Superb So B6's will be ordered, will get new top mounts also and been thinking about getting the arms too, might as well do everything I can at this point. As speaking about the worn bushing on the front, whereby you could hear it on the test ride. Then was told that is has to completely fail to be warranty also. so might as will replace that at the same time too.
  9. Sorry to drag this old thread up, after googling a few different results. Just wondering the same if anyone has put B4’s on their Superb I am leaning more towards these due to them being black so less likely to show when a technician is under the car due to extended warranty on the car. I have read where the B4 is supposed to be slightly updated but not seen anyone have these on their car as yet, currently have Sachs rear shocks
  10. Right I am almost decided to change the shocks on the Superb Now I have seen some have gone down the B4 route over the B6, with still having warranty I am wanting to keep within specs but I understand that the B4 is still 10% stiffer Is this correct and is it worth it or should I just spend the extra and do the B6?
  11. Does the car not switch off when you open the door, I remember my old Tarraco did that after pressing stop, everything still on until you opened the door. My Superb is a key so as soon as you switch off and take the key out of the ignition very goes off with a message on the radio saying bye My Wife’s Mini does the radio stay on until yo lock it
  12. Went full on doing all the prep stages before applying it, first using the product and I am very happy with the results.
  13. Cheers, the end of my fingers hurt today haha. My heart did sink before doing the reset on the head unit, I thought great here we go, but like you awesome that it works. I not sure the image overly is as good as factory but for something so cheap it's all good. I had to keep going back into the car to test it out, my wife thought what a loon. Funny how you get used to things or not having them, going from a Tarraco with camera's
  14. I have recently updated my headunit, I have the mIB 2.5 version from when it was produced, 2018 to the latest version with no issues. I followed the MIB2 to MIB2.5 upgrade doc which was done by @JR RS You have correct link for the map update, I went there and did mine from 2018 to 2025/26
  15. Done mine today, arrived mid afternoon and have been able to do it, had prepped the car before the arrival of the kit. Used a bike outter cable to help route the cable, they ends were tricky to get all the way in, but I used cloth tape to help ensure they don't come back out, went down the sill route and then up into the back of the glove box. Putting the unit is a pain and also had to hard reset the stereo for it to work,
  16. I am not sure, but a new shiny bolt and nut would lend itself, but then again the other side seems to have the same type or grime/dirt etc but that bolt/nut is old It's a 2018 plate with 75k on the clock
  17. I maybe just take my car in for this, in theory I shouldn't have to pay as it's not working. Tried all sorts to reset it and it doesn't do it how the videos show or how people mention
  18. Didn't take the car to the dealership today due to the costs that might of been involved for the suspension review. Anyway, been reading again the posts about seats and the memory, I have tried loads of all the say forward, back, up and down etc with still the same result, setting with then locking and unlocking the car and the seat moves up slightly. Now what I did notice that at each end of each movement, all the way forward or back, up and down that it would require me to press the movement button again to go past that point to the true end of the allowance. So I am not sure if that has something to do with it.
  19. I have been under the car this morning, just to have a look myself. The rear shocks appear to be ZF made, so possibly Sachs based? With the near side having a new bolt and nut at the base of the assembly where it attaches to the wishbone. Part number for both are 3Q0513049FN which look up to be the correct for the rear of a 2wd. Not able to see the spring colours on the rear but the front has Blue and White rings
  20. I have cancelled the appointment for tomorrow as found out I would be charged if its out side of the extended warranty (£165) which just after Christmas is a little much. Had a good chat with them over the phone whilst cancelling and seems I will see if i can check the state of the shocks before going further with them, as they wouldn't have a car to compare against to get a true understanding of what is happening. When I mentioned about the Bilsteins then this would of course means everything is then outside of their extended warranty, as they don't have anything to compare against nor have heard of this before I think I might need to confirm the issue a little better before hand, shame really as not had the car that long which they were fully understanding with and wouldn't charge me until it was deemed that the extended warranty didn't cover or there wasn't an issue.
  21. Mine from the above has just cleared customs, should arrive tomorrow I am hoping and then can get this installed. The true Skoda retrofit is very involved with Skoda quoting £500 then fitting also looking at nearly £1000 be the time it would be done.
  22. Yeah I know as it didn't work the day before but might of needed the car going to sleep before hand.
  23. Was able to sort it in the end with the restart of the headunit
  24. Tools from Amazon didn’t seem to work but holding down the power button on the stereo seemed to work today
  25. Just has the SOS Emergency call restricted. Workshop error message now, which appeared almost straight away when doing the update
