Moving from an ICE vehicle to an EV - my first 1000 miles and observations on The Good and The Bad
That's a bold statement which I don't believe is correct of the majority of car drivers in the UK - yes current EV drivers either knew or have learnt it, but I strongly believe that the vast majority of the public have no understanding that battery capacity and hence EV range will be reduced when it's colder - and will not be pleased when they find out the hard way!
This is what needs to be solved before owning ONLY an EV will be a viable option for many people especially those living 'out in the sticks' - it's all about range, range, range (apologies to Phil & Kirstie of Location, Location, Location).
Dreaded water pump issue
Petrol vRS has a timing chain, 1.4 & 1.5 petrol have a timing belt.
- After changing DSG clutch slip
Any way to fit a CD player to a 2015/'65 Plate Octavia?
I always found the anticipation on the drive home before I could rip the CD to MP3 made it more enjoyable listening to the ripped version next time I was in the car.
Sunglasses holder
I was replying to FlyingGecko who commented on the size of the roof cubby - when one is fitted.
A 65 plate Octavia is almost certain to have a MIB2 infotainment unit (depends on production date not registration date) and hence no CD player - which IIRC was only in MIB1 units.
Just an 'idle' thought.....
Oil slick spreader Boudica like wheel slashers (both a la James Bond DB5)
AM missing on Bolero?
Remember the manual covers all variants and options often in more than one country, so just because something appears in the manual doesn't mean your car will have it. You have to check the spec advertised by the local importer...
AM has been gradually disappearing from OEM radios for several years, I'm pretty certain it wasn't on the Octavia 3 I had until recently and it's not on my current Toyota.
Car time doesn't change automatically
Worked for me on the Amundsen I used to have? If you know how to use VCDS or OBD11 those instructions tell all you need to know - BTW no security code is needed.
See https://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/page/2/#comment-4021330
Sunglasses holder
We used to fit both our sunglasses in the roof cubby.
Instrument cluster removal
Be aware that when you remove the instrument cluster it is VERY likely that the ABS will lose its coding, so take a full diagnostic scan (e.g. OBD11 or VCDS) BEFORE and be prepared to have to recode and redo the basic settings on the ABS afterwards. "My ABS has lost its coding after I removed the instrument cluster..." is one of the most common requests for help on the Ross-Tech forum.
Timing belt
On which the water pump is on the opposite end of the engine and not driven directly by the timing belt, and for which there is no evidence of premature water pump failure (I can only remember one example being posted on here). When the Skoda dealer in Barnstaple offered to replace the water pump at the same time as replacing the timing belt I reminded them that the water pump is on the other end of the engine and declined.
Dealer software update - advice
For me the phrase I have highlighted is the important thing that hasn't happened in this case. The customer can only properly agree if they are informed what the firmware update is expected to achieve, which the dealer clearly hasn't done here, and then choose whether (or not) to give informed consent.
Water pump kit Skoda Octavia
Don't always believe the dealer, they often get confused between the many different engines fitted to the Octavia.
Skoda Servers will be down from 25.1.2021 until 29.10.2021.
I presume they mean from 25.10.2021 ???
Dyno test
Unless the dyno operator correctly applies the expected transmission loss figures specific to the car then what will be measured is WHEEL bhp/Nm plus a guessed correction for transmission losses. Manufacturers specify FLYWHEEL bhp/Nm so unless the transmission loss figure is correct the numbers seen on a dyno will be wrong. A decent dyno operator will firstly do a run powered by the dyno to measure the actual transmission losses on that specific vehicle and then apply them to run(s) powered by the vehicle - this data should be shown on any graphs you have received.
Park Assist
For Park Assist to work it needs to be able to detect the vehicles alongside, hence the need for 4 extra sensors - 2 on each side by the wheel arches. I only rarely used Park Assist on my Mk3, but it did frighten my ex-SWMBO when I took my hands off the wheel and the wheel started whizzing round which made it worthwhile!
is it hard to change my octavia mk3 from key ignition to start / stop button
As you correctly say a momentary push button is required. Many owners of VW Golf Mk5 & Mk6, Audi A4, etc. without a start/stop have done exactly this using the start button from those models (when I owned a B7 RS4 this was how it was equipped from the factory i.e. key switch for accessory and ignition plus a push button for start).
Do you mean going full keyless start or keeping the key to turn the ignition on but with a start button? First complicated (additional module, lots of recoding), second just needs a switch in parallel with the start position of the ignition switch.
Hybrid 1.4L Skoda Octavia 2021
Depending on the spec it may not have those features., they are not standard on all variants. You need to verify what the spec is of the exact model that you are leasing. What headlamps do you have? Automatic high beam isn't standard on all headlamp types. Does it have keyless start? If not then it won't have keyless entry - even if it does that's no guarantee that it has keyless entry.
Near side door lock
Is the child lock physically set on the door, that disables the interior door handle? Check by opening the door and turning the child lock setting device using the key.
Amundsen Mib2 Map Updates 2022/23
That's a shame it was a great way to avoid having to buy newer larger cards on earlier MIB1 & MIB2 updates and worked well on both 8GB and 16GB Skoda SD cards. I've personally used it successfully on Skoda 8GB, Skoda 16GB and Audi 16GB SD cards.
