PetrolDave
  1. My bad, too early in the morning!!! If start/stop only works for a few hours then that suggests the battery charge state isn't being maintained. How old is the battery?
  2. PDF files only. If you download everything to your local device then you only need to pay once.
  3. Removed due to early morning brain fade 🙃
  4. erWin has the factory repair information, so it's probably the most complete information you can get. Just buy the shortest subscription (1 hour in Europe), enter your VIN and download every file available as PDFs.
  5. The DQ200 has a mechatronic that is sealed to 3 bar, it's only the gearbox oil that should be considered for changing.
  6. But on a DQ200 it is suggested to change the gearbox oil at 40,000 miles.
  7. The electronics and software in a 2016 Mk3 are completely different to any model year Mk4. Also the attitude of VAG and the regulations regarding ADAS systems have changed a lot since 2016 meaning that many systems cannot be disabled or have their settings changed without some "trickery".
  8. You might be best approaching a specialist broker dealing with imported vehicles?
  9. Try again, I've changed the video to the correct one.
  10. As I said VARIABLE displacement, see from about 1:31 AC Compressors
  11. The AC compressor doesn't have a clutch, for many years VAG have fitted variable compressors that permanently run.
  12. Steel hub + aluminium alloy wheel = corrosion
  13. AFAIK Auto Hold requires an EPB, which no Mk3 has.
  14. A 2013 Mk1 will have a MIB1 Bolero, no MIB1 unit can have CarPlay enabled. If you want an OEM solution then you need to replace your MIB1 Bolero with a MIB2 unit from a 2015 on Mk3. Best person to ask is @pab567 so I've tagged him.
  15. It will be WiFi, BT is only used to establish the initial connection to WiFi.
  16. Interesting - so she always needs glasses as one eye will always be out-of-focus?
  17. Brighter bulbs won't have changed the headlight beam pattern so the Picanto still having better spread is to be expected. The best headlights I've had was the Xenon ones on a 2003 B6 Audi S4 Avant, they had better illumination both spread and distance than any headlights since on Audis or Skodas (even those with Bi-Xenon). Your experience with the need for specs following cataract ops is exactly the same as both my fiancee and brother; no specs needed for distance but needed for reading etc. Apparently they are supposed to ask if you want to have corrected close vision or distance vision - but I've not met anyone who was asked this question and they just assumed that corrected distance vision was wanted.
  18. Interference from a strong outside radio signal, especially in the 2.4GHz band, is the most likely cause.
  19. Sounds like the wiring to the drivers seat or the heating element(s) are too high resistance or open circuit. You need to physically and electrically check the wiring and the resistance of the heating element(s).
  20. Cylinder On Demand - when the ACT kicks in/out and switches the engine between a 2 cylinder one and a 4 cylinder one.
  21. I've had VCDS for well over 10 years and it's paid for itself many tmes over with £100 in garage fees saved everytime I (or friends) have needed a fault diagnosis.
  22. I'm also a hobbyist, and I don't know where you get 800 Euros from, the real price for a 3 VIN licensed cable suitable for a hobbyist is GBP222 which is €255.
  23. Don't expect any help from Ross-Tech or on here when using your illegal rip-off clone of VCDS.
