Ventilation problem
Don't rely 100% on the accuracy of the fault code description - follow what isn't working. I would check the output test options on the HVAC module, these can 'exercise' all the flaps. SOmetimes the output test is sequential (i.e. one flap after the other) and sometimes you can choose which flap to operate. Run the test and listen - you can hear the motors move if they are OK.
Ventilation problem
There are servo motors that control the positioning of the temperature flaps on each side, seems like the one on the passenger side is (like the fault code says) jammed.
Junk mail intermittent
I've recently started getting nearly 100 spam emails every day to my hotmail account, they all go into the Junk folder. But this is the problem since the web version of hotmail only runs the Rules I have defined on Inbox! ... and I'm loathe to allow the spam into my Inbox. I can't just use the Mac Mail app as I also use 2 windows PCs during the day, so I need a solution that works on the web version of hotmail - any/all suggestions welcome.
Tipping point?
According to Quote Investigator the original source is
2021 Octavia VRS iv driving mode default (please explain)
I have the ACC set to the second distance setting, when on sections of the M4 with the chevron"keep your distance" markers it follows at that distance, and when a passenger times the gap its following the "2 second rule". I think we've all become so used to following too close that when we use ACC we think it's leaving too big a gap.
Problem with starting the diesel engine the day after a long journey.
- Infotainment System Restarting endlessly
Reboots don't cause any harm to the module - the only harm done is to the owners patience and Skoda's reputation.- Infotainment System Restarting endlessly
CP & AA have to be designed for the worst case user, so you needing less bandwidth isn't going to change how CP & AA work.- Infotainment System Restarting endlessly
The Octavia 3 does use a WiFi connection for CarPlay and Android Auto - in fact every vehicle that has CP & AA has WiFi, try looking for active WiFi with another phone when you have a wireless CP or AA connection. Maps, music, etc. all active at the same time would be stretching Bluetooth and cause unacceptable latency hence the use of WiFi. Sounds like a bug, several people on here have reported AA problems with some phones.- Infotainment System Restarting endlessly
Wireless CarPlay and Android Auto use Bluetooth to establish the connection and then switch to WiFi to carry the amount of data. So using a cable connection to a smartphone means that WiFi can be turned off.- Android Auto
Simple answer, yes.- Speedometer problem
Maybe only on vRS?- Speedometer problem
No, needle sweep is not standard - neither of my Octavia 3s (a 1.4TSI Elegance and a 1.8TSI L&K) have had needle sweep enabled until I did the VCDS coding change I posted.- 5G Download Speeds - What Can you Get?
5G - what's that? Large areas of Wiltshire I drive in still only have 3G coverage on Vodafone (no 4G or 5G) - and they've started turning off 3G this month which will leave some areas with no usable mobile data at all (I'm not counting 2.5G GPRS or 2.75G EGPRS as usable mobile data). Vodafone is switching off 3G from June 2023- the truth about electric cars
But especially in inner cities there are large numbers of properties that only have on road parking, not necessarily outside their own property. So unless there is a significant increase in cheap charging away from homes that will cap the number of people able to charge an EV at an affordable price.- TMC traffic events no longer being received...firmware update required?
That covers only whether the data is up-to-date or not, not data suddenly lost due to VAG not subscribing to a service. So if they try to use it as a get out then it's open to a challenge.- the truth about electric cars
But according to reports not as fast as the rate of increase of EV sales, which is why some EV owners are finding it so difficult to charge they are switching back to ICE or PHEV.- TMC traffic events no longer being received...firmware update required?
Pierina from Ofcom is ill informed when they say: as the Octavia 4 has sat nav - oh and not everyone has a smartphone with Waze, Apple Maps, Google Maps etc. or a separate sat nav device.- Speedometer problem
I agree the needle sweep sounds a good idea to try.- Stage 1 remap for better fuel economy
I've been thinking about a similar remap (but not for economy reasons!) - I have a 2016 L&K 1.8TSI with DQ200 and am concerned about the torque increase on the dry clutch DQ200 where unlike the wet clutch DSGs the option to increase the clutch clamping force isn't possible.- TMC traffic events no longer being received...firmware update required?
Does it not also affect pre 2015 MIB1 units as these also rely on Trafficmaster TMC for traffic data?- Speedometer problem
I doubt VCDS coding will solve what sounds like a sticking or jammed stepper motor in the speedo.- TMC traffic events no longer being received...firmware update required?
... and as said many times previously in this thread it is NOT VAG specific.- Glow plugs
Bad assumption - as said in your other thread. MODS - please lock this thread.- TMC traffic events no longer being received...firmware update required?
Exactly, we were sold cars with TMC for the built-in sat nav which has been removed without warning. There IS a solution which is for VAG to pay to subscribe to INRIX and issue new maps (they only need to update the UK section of the maps as this is a UK specific problem). And equally importantly for Skoda UK to issue advice to ALL UK Skoda dealers and their call centre staff so they stop telling us we need to pay for diagnostics - Infotainment System Restarting endlessly
