JR RS
Everything posted by JR RS
  1. @mtl , @Bap33 - I've never seen that message in the 7 yrs I've owned the car. Mine is MY17, with KESSY. I know my battery is low when it doesn't lock/unlock when it should, or open/close boot when it should. So far I've replaced my key battery 3 times, maybe 4.... The scan clearly indicates that it "knows" the battery is low, yet there is no visible user notification. Strange.
  2. Turns out the car knows when the key fob battery is low, so why is the owner not informed via the infotainment in the Vehicle Status screen, along with other warning/errors? Or do some model years actually show it? The mk3 Octavia displays a low key battery warning message. Is there a way to enable it to show on the Superb? Below is wat shows up when a scan is done.
  3. thanks n ur welcome. i still love the factory 19" Trinity rims, but it was time for a change after almost 7 yrs - hence why i switched to the dark side!! lol
  4. I used to have hub-centric spacers before when I had the factory rims, but not anymore since I got my aftermarket rims. With the aftermarket rims the wider rim and offset combo make it sit almost the same as I had with the spacers. Before Spacers:- 12mm front, 10mm rear Rims:- Factory 19x8 ET44 Tyres:- 245/40/19 Now Spacers:- None Rims:- Rotiform 19x8.5 ET35 Tyres:- 245/40/19
  5. ...and a radar which requires a particular front grille (with radar cover). Then the associated wiring and control module.
  6. Yes, it's on all the time, however it is not clearly visible during the day time.
  7. Dynamic Chassis Control - in another words Adaptive Suspension. https://youtu.be/1f2uG_cuYC4?si=Ftf-BN7wYzUR-5V_ With DCC, u have Comfort, Normal and Sport settings. There is considerable differences between all 3 settings. If u get the DCC mod, u have 15 settings.
  8. Again, read my post on the new discussion u started!! The one u've shown here is Option #2.
  9. Simple answer - no. Read my answer in the discussion u started.
  10. Retrofitting the Facelift Superb headlights to the pre-facelift model like urs is possible, but it's a big job. Ur options r:- 1. Keep ur existing headlights, get better performance bulbs 2. Retrofit pre-facelift Bi-Xenon version headlights. This will however require new headlight units, D3S xenon bulbs, levelling sensors, AFS modules, power ballasts, light control modules, upgraded BCM, parameter files and coding. 3. Retrofit facelift Bi-Xenon version headlights. This is even more complex, but doable. In addition to the above, u will also need a completely different wiring loom, new gateway and BCM modules, facelift headlight units, facelift bumper, and possibly facelift front qtr panels. I would stick to Option 1 unless u have deep pockets.....very deep.
  11. @Tankdave - I've used the following Fuse locations for my dashcam and TPMS retrofit. #16 - Phonebox (permanent) #30 - Boot 12v socket (permanent) #47 - Rear Wiper (switched)
  12. U can use the same fitting points, however u can't use the existing Torx screws. They're too small and not wide enough. U need an Undertray Fitting Kit. It comes with:- - 10x Extra long Torx Screws with washers - 3x WHT 000 729 A - hexagon socket head bolt, self-locking,(M8x20mm)
  13. Location of the build plate...
  14. Only the TDi and Scout models got the full length front undertray. The VW All-track models also use it. It goes all the way to the sub-frame. All other models get the standard short length cover that doesn't cover the sump. I recently changed mine for the full length version. I had to get the DSG version as it requires the two cutouts to allow airflow directly onto the DSG transmission. In addition, I also got the centre exhaust tunnel cover. Mine came with all other underbody aero covers, minus 6a & 6b as the 220 has dual exhausts. Comparison:- Centre Exhaust (#2) + Full length cover (#1):- Underbody Aero options:-
  15. Assuming u have the A5 camera, this is the coding for activating on pre-facelift Superb.
  16. Ah yes, that would make sense for it to b power only! That would make the retrofit a whole lot easier then 👍
  17. I would b very surprised if u have the wiring for the USB port location on the rear view mirror. In theory, in order to add an additional USB port, that can b seen/used by the MIB infotainment unit will require a USB hub module. Hence u would need:- - a USB hub - additional USB port - USB hub wiring - USB port wiring
  18. Correct. I've now updated my post so it's less confusing. 🙂
  19. U should take a closer look at the pic. I don't have 2x permanent supplies for the dashcam.
  20. My Blackvue Dashcam's Night vision stopped working, after 5 yrs. So I decided to replace it with the 70mai Omni 360 Dashcam, and whilst I was hardwiring it, I tidied up the fuse wiring too. I've used the following fuse locations for the dashcam:- #16 - Phonebox (permanent) #47 - Rear Window Wiper (switched)
  21. @enoktakenokta - Traffic Jam Assist and Adaptive cruise both work by "following a moving object". It needs a reference. Hence in traffic, if ur behind a moving car in ur lane, and it comes to a stop, ur car will stop too. If it moves off, urs will follow. That's wat ACC does. If however there is no one in front of u, and ur approaching traffic already stopped at a junction, then YOU have to brake. ACC will NOT brake for u!! Reason being was that it didn't have a reference point (car to follow) before the stopped/stationary car suddenly appeared.
  22. Definitely not! They're Skoda OEM mudflaps. Never been painted/treated, nor wiped down. The Superb writing is just a vinyl sticker. Nothing fancy.
  23. I bought Skoda OEM mudflaps from Kopacek and fitted them myself. Very very easy to do. I don't know of any Skoda models that come factory fitted with mudflaps.
  24. @glv - i've seen some Superb 280 owners "upgrade" to Audi TT RS rotors and callipers. @Carlston - reckon i can use the Kodiaq's 314x30 rotors, as a suitable upgrade for my 220 Superb (which currently uses 312x25 rotors, PR Code 1ZA), with the existing callipers? or will i have to change the callipers and carriers too?
  25. i don't mind being old then as I like flaps on Gandalf 😁 ads
