Frenchtone
Everything posted by Frenchtone
  1. you can pick a new(recycled) switch up for £15 - £ 20 fleabay
  2. The pcbs are at the back, you need either a small allen key or a small torx, the rear then just lifts off to reveal the boards more key work to remove them and the you shou be able to see the drive shaft etc may then a squirt of wd40. I have had mine open as i suffered burned out copper tracks on the board, used very fine insulated wire to jump the leads, it worked fine. You can buy a replacement on ebay not the cheap chinese jobs a second hand yeti/octavia gof passat etc some ar not white lighted but red. I have a red one, as a spare, it is out of sight when night driving!! Good luck
  3. Switch off, gentle turn on pushing and it releases the holding pins, gently pull out, nothing else to do apart from dismount the plug, just a pull as I recall!!
  4. ^ ^ ^ Well done that man!! ;-D
  5. no could have been info by 'the plumber'
  6. There was also a suggestion of placing the spare in a vertical position strapped to one side of the boot space, a scottish guy did that mod, again a long time ago, in fact I bought the strappings off him when he sold on the yeti
  7. I vaguely recall, a long time ago there was a yeti for the Chinese market which had the spare mounted on the rear door externally. It might of course have been a mock-up!(or a c**k up)
  8. What if the wheel is upside down, I can't remember the format?
  9. What diameter pin? maybe a screw and nut might work, I am probably talking thro' my fesse though
  10. You could say its possibly associated with Thatcher's view of society and the lack of need for community ---- just my bent and twisted view!
  11. naw it is christmas!!! ;-))
  12. 80km/h?
  13. Could be a thermocouple in the control system not working --- I had a similar sounding problem with my first Yeti, said piece replaced and no further problems. Good luck!!
  14. Maybe a registered letter to the head of the UK operation as well!
  15. I eventually had a chat here a la frog with an independant , ancient, VW specialist, he said it was the sensor and just to replace it, found one on ebay for about £30. replaced it and as they say that solved the problem, took about 10 mins in total! General view is that they should be good for about 80k-100k, mine failed at about 35-36k, No subsequent probs.
  16. And here's me waiting to shout out AT LAST!!!
  17. Another suggestion, drive short distances with the handbrake gently applied, it worked for me!
  18. rear brake disc removal is a problem on the 4x4 because of the drive etc the others can be manipulated off
  19. think it needs locking with a torque wrench NOW!!
  20. should be fine, think it took about 2 hours on mine!
  21. but was it an amundsen + or a later model?
  22. Sorry Graham, that is not an option, you do need to buy the sd card update!!
  23. V12 works fine with firmware 0407 -- I have an Adventure and recently carried out this map update!!
  24. History repeating itself, behind the bike shed at playtime it is then, see you all there!!! :-()
