- 7317 - Load Signal from Alternator Term. DF
Correct oil type/spec for 1.6 TDI 4x4 (2015)
- Lambda sensor testing
Wiper relay replacement
So you need to start a new thread in the general mk1 Fabia subforum Skoda Fabia Mk I (1999-2007) - BRISKODA, this thread is just about wiper relay replacement.
That is bank 1 sensor 1. 👍 You only have 1 bank of cylinders and sensor 2 will be further from the engine. The heater may be a positive temperature coefficient (PTC) type, and if so its resistance will vary strongly according to the temperature it is when measured. So it may well be OK. If you can tell me your engine code (or VIN) I can look up the wiring information. One side of the heater is usually directly from a fuse, the other side to an engine ECU pin.
Fabia Mk2 1.2 HTP - Uneven idle / occasional difficulty starting / running rich
Yep, pretty sure that's correct. Not sure on compressions, maybe a bit on the low side especially on 2 & 3. Maybe worth repeating and trying in different conditions, cold engine and warmed up, to see if that reveals anything?
Have you got a compression tester? Can you have a look under the car and check what bar rating is stamped on the end of the fuel filter? (Just in front of rear right wheel)
How to find out the what is my gearbox model (Octavia)?
DQ200 on this car.
Wibers doesnt work
Possibly a relay failure: Wiper relay replacement - Skoda Fabia Guides - BRISKODA
DPF Regeneration advice
Ah, OK, I missed that the sensor was replaced.
Clearing fault codes rarely fixes faults. What other ones were there?
engine oil viscosity change.
It is a petrol engine, right?
Not unless you want to worry that engine oils are just getting too good. Toot will be along before long to (correctly) tell you you don't need to use longlife oil for yearly servicing at those sorts of annual mileages (as long as it's a petrol engine?), and possibly get in a shouting match with another guy about whether 5W40 to 502 00 spec may be better in those circumstances. Brace yourself.
0W30 will get round the engine quicker at a cold start, so is better.
Brake discs / pads replacement part numbers
Visit counter or use the phone to call them, offer your VIN number and ask them to tell you which are the correct versions. Then order them on the website.
50+ weeks delivery quoted for VRS at the start of May, just got the build week...
... symbol in the top right corner of your post gives you some options including edit.
VCDS Cable for the "new to us" 2016 Fabia III with a 16V 1.2l "CJZC" engine?
I would suggest photographing it and starting a thread on the VCDS and diagnostics subforum. Unless it was a generic 3rd party lead using VCDS Lite software I'd be surprised if it doesn't work. Others will know better though. I have a feeling that it's only 2018- onward cars that need the latest lead??
I wonder if the info from Skoda UK is any more reliable? Time will tell.
What variant is the old cable? Have you tried it?
@djorous message me with your VIN and I may be able to find out something for you.
