Octavia iV Estate - flat 12v battery
I think it would be more accurate to say 'maximum charging voltage for...' Lower voltages will just be slower, lower current into the battery.
Once again, a fuse question
24, 26-30 inc, 32, 38, 39, 41, 44, 46, 48 and 49 are all listed as terminal 30 (permanent live).
Speed sensor location bky engine vw polo
which mk1 fabias came with remote locking?
If it is an important buying criterion you probably wouldn't want to get involved in the palaver of a retrofit, but it is possible to convert 'vanilla' Central Locking to radio remote C/L with all OEM bits and pieces, as described here: https://www.clubpolo.co.uk/topic/204921-guide-how-to-install-oem-remote-central-locking-in-a-polo-9n-with-original-parts/
VIN Interpretation Query
The year in the VIN is the Model Year (MY) which isn't the same as calendar year, in a similar way to how magazines always seem to be a month ahead of reality. Model year - Wikipedia
Brake pad sensor connection - how to separate?
Watch this
Injector wire colour/ecu pin number please?
I think you'll find the 12V feed is the same volour on all four, and comes from a fuse rather than the ECU. The wire colour of the switched return from each injector will be the same at injector connector and engine ECU as it's a direct run. Will confirm in a few minutes, with ECU pin number.
Door Electric Issues
There's a communication wire that goes (only) from front right to rear right door modules, which I think may be broken. It connects pin 10 of the 20-way connector at each module, via pin 19 of each 28-way door disconnect. Ideally you'd disconnect that 20-way at each of the right side door modules, and check continuity from pin 10 of one to pin 10 of the other.
Egr vacuum pipe
You can test the solenoid part of the valve using the 'output tests' option while connected to engine ECU. Not sure on best strategy for problem solving beyond that, as I've not had personal experience of it. Lots of threads on here with that fault code over the years though, I believe.
Egr vacuum pipe
There's supposed to be a tiny air filter on the end, and that's the only place it goes. Item 30 here https://skoda.7zap.com/en/cz/fabia/fab/2001-225/1/133-133035/
Master Cylinder Cap
One of those boa strap wrenches normally used on oil filters might help if you can't get a hand fully round the cap.
Fabia door display fault
Do you mean the door card, when you say door panel? The motor module doesn't need disconnecting to take that off, I don't think?
One module per window. Sounds like you've already proved that idea wrong, sadly.
Could be worth testing the effect of disconnecting the window motor module to see if that makes the fault disappear. I think the microswitch output wire goes there, as well as to the vehicle voltage control module, so if it was getting shorted to earth by a fault at the window motor module, it would appear the same as door being permanently open.
Maybe the microswitch is mechanically stuck? Have you tried hitting the door hard near the lock to see if it will unstick?
Intermittent electronics error fault, when cold. Engine runs fine.
In your photo of the BCM on Thursday morning, the connector pins don't appear to be very clean. I expect it is just the light/contrast/reflection of the picture, as you say in words that 'it looks really really clean'. Do have any other photos that maybe show connector pins more closely?
Diesel leak - perished fuel hose on 7yo car
I have had a very young fuel hose look very old and dodgy, though on a petrol car. It was sourced at a local motor factors under two years ago during an engine change, when I couldn't get the original to reseal at one end. I spotted it looking cracked and horrible this summer, only 18 months after it was fitted. Will nip out and get fresh piccies to compare with ones taken then. I 'kinda' convinced myself that it was just the outer layer, and that it wasn't in any great danger of leaking. Pic from summer:
Speedo dropped to 0 while driving! (ABS woes?)
I doubt it will, but bear in mind the possibility.
I can VCDS it if useful. Try sep's idea first though.
Are you anywhere near Radley?
- Window motor repair service
Best battery for 2016 stop/start 2.0 superb
68 and 70Ah batteries will be indistinguishable in practice.
Are there some standard blade fuses near those strip fuses?
No heating
It's not the clearest post, but he does mention thermostat as one of the things already changed. Is this a DSG gearbox car?
