Sudden clunk sound and loud vibration afterwards - from AC ?
Surprisingly, the compressor still operates at a low duty cycle even when A/C is turned off.
Car won't start.
Check connection to starter motor solenoid isn't broken.
Your A/C compressor is driven by the engine, so can do nothing to produce any cooling at all when the engine is not running.
Intermittent and multiple electrical issues
What are the other problems?
Fabia 1.6TDI engine issue
You'll probably get better advice if you describe what your 'warm running problem' is. Any fault lights and/or fault codes?
- Fault code P2455
- Fault code P2455
- Fault code P2455
- Fault code P2455
oil pressure switch
Find it yet?
Power Steering Issue
Sounds mechanical to me, not electrical/electronic.
Can you clarify what you mean by this, please? A little bit of working OK or a little bit of not working OK?
Don't suppose you still have the original module either?
Doubt it would be different enough to notice. Do you have the coding from the old pump available on a VCDS scan?
That sounds really very unlikely. The PAS system is pretty self-contained. Angle rate sensor plugs straight into PAS module; permanent power wiring; an ignition-on wire and a pair of CAN data lines is the totality of the system electrically.
01333 & 01331 Driver resp. rear left door module, no comms permanent
VAG 3T2971120CN wiring set for door Škoda genuine OEM part (oemwolf.com) Not showing as having been superseded by any other number in the above link. Also skoda-parts.com page for that number shows a bunch of equivalent numbers that doesn't include a suffix DF variant: Electrical Wiring Installation Bundle for the Door Škoda 3T2971120CN (skoda-parts.com) Why do you think it should be DF? Parts catalogue for 2012 Superb doesn't seem to offer DF either? There are a couple of other options for RHD cars though, CJ and CS, not sure what's different between those two. single parts whitch are not included with the par... - Superb(SUP) [EUROPA 2012 year] (7zap.com)
1.9tdi accelerator dead, glowplug flashing, engine fault.
VCDS lite can be used on a 2007 mk2. Get a suitable cable for £10-20 (e.g. this one) and download the free software from ross-tech.com onto a laptop. Minor faff getting it talking to car then really good diagnostic capabilities. Can you ask the garage that said "throttle body sensor" exactly what fault code number they saw, and exactly what they replaced?
1.2htp high engine rpm on cold start
If the engine ECU thinks the alternator is heavily loaded, it might increase idle rpm to help. How old is the car battery? Can you inspect the signal wiring between alternator (terminal DF) and engine ECU? Unplug the two-way connector from the alternator and measure volts relative to battery negative on each contact of the loom plug, with ignition/contact switched on. This should prove neither wire is broken, if you see voltage on both.
Knock sensor is on rear of engine block under inlet manifold. Oil level/temperature is close to lower end of dipstick tube I think.
Locking wheel nut key
Might be this one, but I couldn't be sure as I don't know how many with very similar patterns there may be. SKODA LOCKING WHEEL NUT BOLT KEY MASTER KEY REMOVER - LETTER N 772 Code | eBay
1,5 Business Edition - Muffled exhaust, stalling, heavy vacuum when removing the oil filler cap.
To investigate, there is no need to completely remove the oil filler cap, just turn it to the point where it can be removed, then pull upwards gently. If there's a little resistance to lifting, that would indicate slight negative pressure in the engine at idle revs, which is as designed (on petrol engines at least). If there's strong negative pressure resisting removal there's probably something wrong, please let us know what the garage find, if anything.
Drop-in 6-speed manual gearbox replacement for a 5-speed 1.2 [Fabia MkII]?
Strong winds make a big difference, always worth taking notice on a single journey computation. Whole tank brim to brim averages are much more reliable.
Self-impose a 60mph top speed limit and you'll save a fair bit of fuel.
Problems with fuse 49
If the 'cooked' BCM is heading for the bin after you've fixed the issue, would you look into what it would cost to send to the UK please @Jackieeeeeee? I'd be curious to do a post-mortem on it, to see what burnt. It might even be repairable; if so I could send it back fixed, perhaps.
See if the brake lights work with fuse 49 not fitted. After you've repaired the various cut wires!
