Breezy_Pete
Sponsor
  1. Have you tried this today, i.e. very recently? The status of the key position microswitches in the lock go via the WM. As you're just down the road, maybe pop up one evening with door card off to try a known good WM and see if that helps the situation?
  2. Might also be worth acquiring another fob* to try. I helped a fella recently who'd been told by VW themselves that his RF fob was working correctly, only to find that when I sent him a spare I had, the problem he was having went away. *just the electronics half, not the immo chip + physical key bit. Oh, and also make sure the battery contacts are clean, to ensure it's operating at full power.
  3. There's stuff about key pairing in this thread on clubpolo https://www.clubpolo.co.uk/topic/204921-guide-how-to-install-oem-remote-central-locking-in-a-polo-9n-with-original-parts/?do=findComment&comment=1812092 I think you'd need to get another (lock) key cut to be able to do it though. It sounds a bit like the primary (recent) failure may be with the window motor module though. When you use the key to unlock drivers door, do the other doors unlock, or not?
  4. Not sure whether you have a CUS or a CUT code engine (what is the engine number on the V5c?), but this listing for a CUS engine block shows some stamped info on the first and second photos. SKODA FABIA VW AUDI 1.4TDI CUS CUSB ENGINE BLOCK 04B103024T 04B103011T 2014-2017 | eBay This one is upside down, and I think of the gearbox end of the engine. Will be a shedload of stuff in the way of seeing this area, no doubt:
  5. Breezy_Pete replied to a post in a topic in Skoda Octavia Mk2 (2004 - 2013)
    Not too pricey then. Could probably get genuine for only a couple of quid a litre more, judging by this, but probably just repackaged same stuff: Volkswagen / Audi / Skoda Transmission Fluid G070726A2 - LLLParts
  6. Breezy_Pete replied to a post in a topic in Skoda Octavia Mk2 (2004 - 2013)
    Item 2A by the looks of it: gearbox, complete; 6-speed manual transmission - Octavia(OCT) [EUROPA 2004 year] (7zap.com) (ignore the misleading page title)
  7. @DariusFabiaestate please let me know if you're interested in selling me the old broken loom if you still have it.
  8. I think the module that controls most or all of those functions is the one above the accelerator pedal (on RHD cars). Might be worth taking that out and having a look inside if possible. See if anything looks cooked.
  9. Good advice ^ It's probably likely to last longer without intrusive 'surgery' than with, I'd say.
  10. If you do replace the loom/harness rather than repairing, please consider selling me the broken one you remove, instead of binning it. PM me when the time comes. 🙂
  11. Skoda Workshop Manuals > Octavia Mk2 > Drive unit > 2.0/110; 147 kW FSI Engine > Engine lubrication > Parts of the lubrication system - Part 2 > Testing oil pressure and oil pressure switch F1 > Checking oil pressure and 1-pin oil pressure switch (workshop-manuals.com) Some test info with some pressure numbers here This is with precondition of fully warmed up engine. Seems to relate to previous generation of engines, but doubt the numbers will have changed much. In case link can't be seen, key phrase appears to be: " – Start the engine and increase the engine speed. Given an oil pressure of 0.12...0.16 MPa (1.2...1.6 bar) the LED must light up, otherwise replace the oil pressure switch. – Increase engine speed further. At 2000 rpm and 80°C oil temperature, the oil pressure should be 0.27...0.45 MPa (2.7...4.5 bar). At a higher engine speed the oil pressure must not be greater than 0.7 MPa (7.0 bar). If the measurement is less than the specification: – Check the strainer in the oil suction pipe ( → Chapter, Pos. 9) for contamination."
  12. Maybe I can help with a rather good photo from an ebay listing: I would say it doesn't matter at all which one is removed to check the oil pressure, they appear to connect into the same gallery.
  13. Whereabouts in the UK are you? I'd happily repair that for you by post if you can remove/reinstall, for a lot less than a new loom.
  14. If someone reminds me tomorrow, I'll try to do a 'decoded parts list' post with all the different part numbers and which engines they suit.
  15. I think non-freedom members can edit, but only for a limited window of time after their post was made; 30 mins or an hour or similar. Tons of other benefits to freedom membership though that make it very worthwhile.
  16. Seems to mainly point the finger at the angle sensor or its wiring/connections.
  17. Not the best made fastener I've ever seen! There's a seller on ebay with username vagbolts who does a lot of common ones, new genuine, for reasonable money and dispatches rapidly. I avoid buying from the Berlin based websites because it's always going to be more grief if stuff needs to be returned.
  18. A multimeter set to volts dc will tell you the state of charge of your battery. You just need to disconnect it from the car for a couple of hours to get an accurate number.
  19. The loom connections I mentioned are splices on the way between ignition switch and airbag module for its power feed, irrelevant to your issue. If there was a power feed problem to the airbag module, you'd have far more fault codes. The two way connection to the ignitor for the pretensioner is probably behind the b-pillar trim, as you mentioned.
  20. Yeah, they often take a bit of brutality the first time they're ever removed.
  21. No fuse, just an ignition 12V power feed (to the airbag module) straight from ignition switch via a couple of loom connections. Two way connector to ignitor for pretensioner, check for water ingress, I suppose?
  22. That code usually correlates with the battery having been disconnected. If it hasn't been, a low battery voltage is very, very likely to be relevant.
  23. Can you open this page? Skoda Workshop Manuals > Fabia Mk2 > Body > Body Work > Trim, noise insulation > Pillar and side trim panels > Removing and installing top trim panel of pillar A (vehicles without head airbag) (workshop-manuals.com)
  24. Apparently it goes via pin 4 of a four-way connector pair on CAVE engines, 'front left of engine bay' (right as you look in from front bumper) CX1 is your alt. Blue wire is what helps it start up correctly, which it seems not to be doing. Alternative to visual inspection is to measure voltage at pin 1 of the two-way at the alt, with connector disconnected, ignition on. Should be about a volt below battery voltage.
