Gaz
Everything posted by Gaz
  1. Hello Simon My first Skoda was a Superb V6TDI 😎 As a first port of call, have you checked for water ingress? In the plenum chamber and under the carpet in left side (UK passenger) footwell - wet in these areas can cause a host of odd electrical issues. Gaz
  2. Sadly not my day 😕, but I remain ever the optimist… somehow…. Someday…. Someone 😁 We’ve got a Tipo for sale in a garage I cycle by. Tbh I didn’t realise what it was, but I thought it looked a nice enough little car 👍 G
  3. That’s not my understanding. Can you elaborate please, as I thought they are allowed, in the right circumstances for them to be used correctly. Gaz
  4. It’s item 27 (and quite possibly 64) on their Approved Used inspection checks: Appalling service indeed. I’d certainly be updating the review to (factually) downgrade it if it were me. Gaz
  5. Gaz replied to davoxx's topic in Tyres & Wheels
    What’s your current wheel and tyre sizes? Gaz
  6. Power steering unit or steering rack? There’s obviously more pressure on the power steering when turning at low speeds. Can you detect it when stationary with the bonnet up? Gaz
  7. Currently £3.30 Clubcard price for 2.5L at Tesco until the end of the month: Gaz
  8. Is the hose long enough to cut 1/2” off the end and re-seat it as a makeshift repair? If not, could you cut it and add a section of copper/metal pipe on jubilee clips so you can get a clean inner section of the hose reseated? Again as a makeshift repair? Is the hose straight (ish) and simple enough that a generic coolant hose of the same bore could be suitable? But before any of that, if the hose isn’t damaged, have you tried releasing the clip, getting the hose moving, and then putting the clip back on, but rotated from its current location? Might provide an easy fix. Gaz
  9. Stone the crows! 😁 You'd done well to escape it for so long. Think I've had it four times now - it gets easier (IME). Hope you're feeling better. Gaz
  10. I'm 🤏 close to pulling the trigger on a Nextbase 622GW front and rear, for all our cars. Currently at £299 for the full package. Was looking at Road Angel and the Viofo A229 too. Gaz
  11. Very broody sky about 40 minutes after sunset up Beachy Head tonight. Proper windy too: Gaz
  12. End of an era indeed. Healthy old mileage too 👍 It’s ten years since I replaced my 2005 Mk1 with an Octavia Mk3. Hope the new one does you proud. Gaz
  13. I realise it's not a photo, but I got buzzed 😎 (Needs sound): IMG_2972.mov Gaz
  14. I was outside the front of my house this afternoon, saying hello to my 18 month old neighbour and his Mum. He's very cute, and although he'd just eaten a banana, I let him play with my phone When I went back indoors to finish my cuppa tea, he'd somehow managed to activate my camera. And on the photo's he took, there were a couple of bright red things in the sky over our houses: Like I said, I was only outside being neighbourly 😇 No other reason Gaz
  15. Buy it, buy it!!! 😁 G
  16. Whopper of a Hoverfly on our Buddleja earlier: Gaz
  17. I had a 2015 vRS Estate and loved it. Might not be as comfortable as you think as a family wagon. With our worsening roads, I’d be more tempted by the 1.5 which will have a bigger sidewall on the tyres, so a bit better on potholes and duff road surfaces. Gaz
  18. Made it to Beachy Head just in time for a smashing sunset: Got home to see the moon emerging from a distant cloud base: Gaz
  19. The V70's 15 years old - so it's averaged 2,667 a year: I bought it last year at 33k miles, so I've put 7k miles on it. 1200 of those were the trip last May up to Edinburgh. Gaz
  20. Mrs Gaz's Polo GTI (1.8TSI) had a barely discernible misfire, which turned out to be a failing coil pack - a diagnostic scan revealed which one. It was an easy fix once we knew what it was. It flagged up as it got worse, triggering the EPC light. The car is rarely under any load, with usually only one person in it, but I could see it being far more noticeable had it been loaded up like yours. Our petrol cars are run pretty much exclusively on Momentum 99 👍. I've seen so many people say it doesn't notice whether 95 or 99RON is used, but I'm darn sure I can notice; moreso when giving it the beans. Gaz
  21. Hello Chris, welcome along Gaz
  22. And with some aplomb 🙄 With the use of my yuckygreaseometer and aspectratioviscometer, and using AI to measure the runs on your sidewall, it looks like it let go at 37.832mph. Time of death 0912am, 17 July 2025 😁 Gaz
  23. Absolutely right. But you've lost me a bit; in your previous post you said it looks like a Discover Media unit: So I was pointing out that it doesn't look like my Discover unit. It takes very little to confirm 3V0035820H is an MIB3 unit: And that the unit in the glovebox doesn't come with two SD card slots. Interestingly it appears this unit can come both with, and without Satnav. Gaz
