Gees RS Wagon
Clive, can u get me some Blue catch can Union Elbows that are 19mm? ill let you know my thread size?
  • Replies 2.1k
  • Views 306.2k
Ooops sorry Gee :( im fowling your journal
I'll carry on with my crap cluelessness in a pm or sumin :D im so crap its unbelevable !!! But i have somehow ended up with one of the more known octys lol
Along with certain ones with crazy rims lol
lol lloyd its cool bud.. Keeps the thread a good read dont it!
im just about to PM you all the pipes i replaced so you know what to get.
Umm :D i dont know what i need lol
I just like Gees colourfull purddy engine bay lol
I was thinking blue n matt/satin black all over the place :D umm ??? Blue end thingies ???
Id like a catch can like stevie wonders too that saiko michi moto moto or whatever they r called ( that matt black one that i cant think of the name )
But that may have to wait due to my work hunting :(
do you want me to do you a quote buddy ???
yeah shouldnt be an issue get me he thread size and i will hunt then ;-)
Yeah mate, feel free to pm what i need £££
Was easier to do when there was more work lol
And 2 munchkins not attacking my wallet lol
I know i have to build enough bits to make it worth the drive :D
I keep lookint at those parking sensors but the thought of holes drilled and not level make me want to go curl up in the shower and rock :(
But yeah.... Once i know the kinds of bills i'll owe u mate :) as i dont wana run a tab i cant sort and look a proper ****weed :(
i will get you a price the full engine bay clean up
pm coming to confirm things
Hes a con man Lloyd, dont do it!
and word on the street is he has sex with pies!
:D
Dont joke Gee :D i freak when i have stuff done to my car :( i always worry it will get broke and cost money i dont have ............
Ooooo a engine bay clean up ????? Whats that lol spit n polish :D
I need a lotto win.... I can ship you both to brizzle then to sort my octy :D
ha ha ha chicken and mushroom pies its not lies lol
lloyd your car will be in safe hands i have as much if not more ocd than most lol
its a passion for me more than a job so i treat all cars like it was mine getting ready for shows
im doing a car in the next few weeks thats having the full monty on the engine bay so will get pics up once done :-)
LMFAO! na clives ok honest.. i cant be sure about the pie rumour tho! lol
EDIT: no, Rumour confirmed! lol
Is that daves mate ??? Always chatting to him :D someone else who no realises how odd and strange i am
yep dave is dropping his car to me soon ;-)
Will be good to see it decked :)
After a sneak preview of Gee's pending lambo part :) i beleve i will have to somehow get one !!!!!
I have to have one !!!!
I NEED ONE !!! :D
This used to be a sleeper hahaha
G
I NEED ONE !!! :D
I'm intrigued...
I did this today, done a how too so will copy that into here to save me typing loads again. Ill pop a few more pics up of the other bits i have done also..
a few members posting threads about there servo pipe split ect, i thought i would do a little how to as i replaced all this with Braided line.
Needed...
1.3 meter of braided line. (i had to buy 2m)
Jubilee Clips to clamp 20mm line. x2
Braided line finishers x 4 (20mm) AN-10
Hack saw
7mm mini ratchet or screw driver
Spec of the line i used..
Hose ID: 12.7mm
Hose OD:
19mm
Wall Thickness:
3mm
Reinforcement:
Textile & Stainless Steel Reinforcement
Working Pressure:
15 Bar
Bursting Pressure:
60 Bar
Temperature Range:
- 20°C upto + 80° C
Colour:
Stainless Steel Silver
This is avaliable From Autosiliconehoses.com
Braided line finishers are from Ebay.
http://www.ebay.co.u...9#ht_500wt_1086
Ok here goes.. Remove your old Pipe from the bulk head. This mite be pressurized so be aware is mite make you jump! Remove from here..
if you follow the line from your Manifold to the bulk head you will find it. It just pops off. Just be carefull not to damage the line thats on the bulk head as that a a ball ache to replace!
Once you pipe is removed you will have a long solid pipe with a Y piece 1 end, and little 90deg plastic elbow the other, and 2 x non return valves on it. You need the 90 deg plastic elbow and the non return valves.
these (i think) heat are heat wraped on so you cant just pull them out. I used a standly blade to carfully cut 2 lines down the solid pipe enough to pull them out. Dont go to deep to cut the valve tho as these may be expensive.
Heres what the 90deg elbow looks like,,,
be aware of the spongy bit in it, dont loose it!
this is one of the non return jobbies..
Mine had the word "motor" with arrows pointing 1 way showing what way round they go, make note of what way yours are incase you aint got motor written on them .
once all removed, in short.. you need to make this..
i have put the non return valves in roughley the same place they were on the OEM pipe.. Gotta be a reason theres 2 spaced that way.
i made the first section from the manifold to the Non return Valve about 4.5" long. to cut braided line i done the following..
clamp down a jubilee ton the pipe and use a hack saw to cut it.. i done only 1way strokes to keep it neater. once cut it will look like this...
Grab ya braided line finishers..
pop a Non return valve in one end, (the right way)
and you should end up with somthing like this.
Repeat process with other valve, and 90 deg elbow and fannys ya bob!! I used normal jubilees after the second Non return valve as its not see, so it dont need to look pretty.
Heres how mine looked when finished.
Hope this helps anyone else wanting to do it.
I take no responsibility for anyone messing up there car. Just be aware, if you do it wrong it will affect your brakes and mite not be pretty. i have given no measurement to the longer bits of pipe as mine goes around a catch can so will be different to yours. :)
Thanks to Clive for telling me about the reinforced line shizzle a while ago... i would of just used silicone otherwise.
I also removed the silicone pipes that were running along my fuel rail. they been bugging me since i put them there. instead i got some over braid and ran it under then manifold via fuel lines. I used over braid as it saves me changing all the boost gauge piping and Oil pressure gauge wiring as thats what the pipes were for.
Boost gauge is plumbed into to the FPR (which i turned round a bit too) with a T piece.
DV is vac`ed direct into the manifold so should be alot quicker to respond as its right next to it now.
The braid following the other ones..
I also had to relocate the Fuse/distribution block that normally sits on top of the battery as i got a pretty cover for mine. After toying with the inner wing, side of battery i opted for this..
i had to go find some more loom that attaches to the box so i had enough to play with.. The loose loom that normally goes up the back of the battery now sits under it. The box sits all snug in the battery blanket and the cover slides cosy on top..
I also moved my Digital Fuse box on to the cowling and will wire it up to light up now it can be seen!
made the vac pipe for the Carbon cannister all a bit funky as i didnt like the "L" looking way the pipe sat with the non return valve in it. So i hid the valve under my pipework.
Cunning eyed of you will see i have Clipped up all the pipes, i tidied up all the catch can piping so the TIP sits higher, as the pipe from the "hockey puck" was pushing it down as it was to short!!
Other than replacing all the Earthing points, thats the bay 99.9% done!
Sweet :D "CLIVE" lol
He will hate me when i have money to **** away :D and he will blame YOU !!!!!!
thought id give him a mention before he sends an invoice for advice he gave! lol The geezas in every thread atm.. 10 out of 10 to him for getting his name out there!! lol
I want my bay like yours :)
Just cant deside on rocker and inlet ????
I was thinking matt black but then i see crazy green and think yellow or sumin lol
I think he will do very well mate....
I just wish i had the guts and skill to do it myself
Edited by Lloyd55vrs
Ooooo i spy a hose coming up from your turbo :)
I dont think that was in my kit...
Im going to...... Have to look under my cover eeeeeeeeek :D
hahaha, you see more under the cover mate!! dont do it!! it will cost ya!
I have not done this for a few years, but we found the best way to cut braided hose neatly was to wrap some electrical insulation tape around the hose then cut through the middle of the tape, there is no need to remove the tape afterwards as it will not be seen as it is in the clamp, this will also stop the braids from fraying. :thumbup:
he he always nice to be mentioned every now and again but have to say my advise is free as always ive been around the forum a long time aswell modding cars and its all what i have learnt over the years from people that did it all before me !! so its good to share info you never know how things happen in future you may just work for me one day gee ;-)
im hoping my names out there with me having done 4 of these cars to show spec lol the joys of splashing money and time and trying new things lol some good some not so good lol
gee you deserve big respect you have done this all yourself and made the car how you wanted not just how other people think top bombing always welcome at mine for a cuppa ;-)
