VCDS Adaptations. How do I ..........
 :( i just remembered, a few months ago i've driven a vw passat 2006 or 2007 with maxi-dot and on the bottom left of the maxi it showed the speed.The car was automatic, but i don't think there is a difference between automatic and manual for this kind of thing.
  • Replies 255
  • Views 239.8k
  • I picked up my Yeti this week after a long delivery delay and while waiting I have been amusing mself by pulling a lot of VCDS info into one document for my own use. Well the Yeti came Wednesday and t
  • Needle sweep - absolutely no practical use at all but still makes me smile!
  • How do I enable 'staging'? (needle sweep when ignition is turned on, needs the latest white MFD on newer cars) go to 17- Instruments and click on "Adaptation - 10" On the drop down list find "stagin
That was for the Cruise Control
Thought I'd add a few for the MQB Platform Octy III, that I have posted in the Octavia III section. I have enabled mirror dip on reverse, needle staging, rain closing and gallons consumed so far.
I couldn't get the comfort indicator flashes to work, and haven't tried the headlight washers yet. I've seen the option to enable lap timer (as per the new VRS) but didn't bother.
One thing i do need is the security access code for Module 5F to enable adaptations if anyone knows what it is - I am trying to enable the MIB Columbus to display the speed limit data embedded in the map.
I can't take credit for these, most have been taken from
stemei.de .VCDS Codierungen .Codierungsservice .Webdesign - Stefan Meier - VW Golf 7 - VCDS Codierungen, Webdesign
GolfGTIforum.co.uk - An independent forum for Volkswagen Golf GTI enthusiasts.
  Passenger mirror dip on reverse
  1. Select STG 52 (Türelektr. Pass.)
  2. Long STG coding -> function 07
  3. Byte 04
  4. Enable bit 2
  5. Enable bit 3
  6. Select STG 09 (wiring)
  7. STG access permissions -> Function 16
  8. Enter Unlock Code 31347
  9. STG adjustment -> function 10
  10. (15) Select Access control 2 Spiegelabsenkung bei Rueckwaertsfahrt auswählen
  11. Set value to active (active) Additionally possible: Hide menu item in Radio-/Navigationssystem, so you are even viable in the future to enable the feature on or off
  12. (20) Select Access control 2-Menuesteuerung Spiegelabsenkung auswählen
  13. Set value to active (active)
Enable Needle Sweep / Staging
  1. Go into [17] Instrument
  2. Coding -> Function 10
  3. Byte 1
  4. Enable Bit 0
Rain Closing
  1. Go into [09] Central Electronics
  2. Go into Security Access and enter 31347
  3. Go to adaptation channels and set the following:
    • (15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active
    • (16) Access Control 2 - Regenschliessen_art (Rain closing Type) set to Permanent
    • (28) Access Control 2 - Menuesteuerung Regenschliessen (Menu Control Rain close) – Set to Active (enables the menu in the infotainment screen)
Adjust Comfort Turn Signals
  1. Go into [09] Central electronic
  2. Go to Security Access and enter 31347
  3. Go into Adaptation
  4. Select (2) - Turn Signal Controls-Komfortblinken Blinkzykien
  5. Type 5 in New Value (Default is 3)
Display Gallons Consumed
  1. Go into [17] Instruments
  2. Long Coding - (Function 07)
  3. Go to Byte 10
  4. Enable bit 4
Headlight Washer Frequency
To extend the interval cycles that the headlight washers will activate to:-
  1. prevent the front of your clean car being sprayed, and
  2. to reduce the amount of screen wash usage.
  1. Go to [09] Central Electronics
  2. STG access permissions -> Function 16
  3. Enter access code 31347
  4. Go to adaptation channels (Function 10)
  5. Select channel 1 - Select "Number of operations front windsceen wiper washer per SRA activation" (in German - Frontscheibenwischer Anzahl Betätigungen Frontwaschanlage pro SRA Aktivierung auswählen)
  6. Adjust value to preference (no of times you can operate the windscreen washer stalk before the headlight washer activate).
  7. Select channel 3, and adjust the activate time for folding the switch to enable headlight washers in the first place.
Rain-closing *still* has to be activated on a III? That's pretty bad :(
How much is it as a manufacturer option?
I think it was activated TBH, it just wasn't in the menus on the MIB Columbus
Those codings were taken off of a Golf/Leon list, so may not be 100% accurate to the Octy III.
EDIT - it isn't enabled by default. And the RLS needs coding, which VCDS can't do yet, but VCP can.
  • 4 weeks later...
HI!
When I did this to my 2014 FL Superb it didn't work until I did a reset to factory defaults in the Maxidot "Lights..." menu. I did all this while dark outside and after the reset to factory defaults it all worked. The day after, while in day light it was all back to three turn signals again ... I haven't tried it in the dark again, maybe that will still give the four signals again as I entered. Any idea to this behavior?
Have a nice Sunday afternoon!
HI!
... and no, did not work when dark either ... It is back to three signals again ...
Any suggestions?
Sorry for spamming this thread but this setting is connected to the key fob inserted when the reset to factory setting is performed ... so switching keys made it break. So make sure to test every change with both keys ...
Like a lot of settings are, they only apply to the key you are using when you make the change
Sent from my phone so please excuse brevity and spelling
Enabling cornering fogs on a O3 - tested today on a vRS and works fine
http://www.briskoda.net/forums/topic/298170-enabling-cornering-fogs-with-vcds/
Works fine, but indicating doesn't enable the respective cornering fog. More research needed on this.
Both fogs do light up on selecting reverse, and turning the steering wheel enables them as well.
If you cant get the large speedo read to work, try with the engine running. Couldnt get a car to take, had the engine running and went straight in.
Seems they do come on with indicating, but on a O3 vRS it seems to only illuminate the inner fog light bulb of the two.
Found the additional 2 adaptation channels for the extra 2 bulbs, original post in the O3 section updated with screenshots
Octavia III VCDS tweaks being tracked and docmented here.
Dimming the LED Daylight (one side)by Turnlight
Leuchte2SL VLB10-Lichtfunktion G 2 auf "Blinken links aktiv (beide Phasen)"
Leuchte2SL VLB10-Dimmwert auf 35
Leuchte2SL VLB10-Dimming Direction GH 2 auf "minimize"
Leuchte3SL VRB21-Lichtfunktion G 3 auf "Blinken rechts aktiv (beide Phasen)"
Leuchte3SL VRB21-Dimmwert GH 3 auf 35
Leuchte3SL VRB21-Dimming Direction GH 3 auf "minimize"
LED Daylight off (one side) by Turnlight
Leuchte4TFL LB4-Lichtfunktion A 4 auf "nicht aktiv"
Leuchte4TFL LB4-Lichtfunktion E 4 auf "Blinken links aktiv (beide Phasen)"
Leuchte4TFL LB4-Dimmwert EF 4 auf 0
Leuchte4TFL LB4-Dimming Direction EF 4 auf "minimize"
Leuchte4TFL LB4-Lichtfunktion G 4 auf "Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)"
Leuchte4TFL LB4-Dimmwert GH 4 auf 127
Leuchte4TFL LB4-Dimming Direction GH 4 auf " 4 auf "maximize"
Leuchte5TFL RB32-Lichtfunktion A 5 auf "nicht aktiv"
Leuchte5TFL RB32-Lichtfunktion E 5 auf "Blinken links aktiv (beide Phasen)"
Leuchte5TFL RB32-Dimmwert EF 5 auf 0
Leuchte5TFL RB32-Dimming Direction EF 5 auf "minimize"
Leuchte5TFL RB32-Lichtfunktion G 5 auf "Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)"
Leuchte5TFL RB32-Dimmwert  5 GH auf 127
Leuchte5TFL RB32-Dimming Direction GH 5 auf "maximize
Edited by triumph61
Any suggestions?
You need to reset ligths on your nav unit, then it will work
Probably a repeated question but can't find the answer :wonder:
Have just taken delivery of my second Yeti 2014 1.2DSG Elegance in black, Anyway not wanting to pay dealer price I have got a Columbus RNS510 with DAB. Every thing works radio, dab, navigation etc and the steering wheel controls appear to work too.
My problem is the MFD display is no longer showing audio or any navigation display. I know it needs to be enabled but cannot find the codes. I have used VCDS on my car and have the following error codes
19-CAN Gateway -- Status: Malfunction 0010,
37-Navigation -- Status: Malfunction 0010,
56-Radio -- Status: Malfunction 0010
Any ideas please?
Andy
Are 37 and 56 ticked in the gateway installation list?  If not they need to be.
But I suspect you also need to code something in 37/56 (which is the same thing for a Columbus).  My guess is the BAP protocol setting, enable that and you might be good to go.  If that doesn't do it, can you post the whole scan for 19/37/56 please?
Adam
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 080214F1002915
   Coding: 356303
   Shop #: WSC 33361 790 00056
   VCID: 79F3F5A4F02793D6D3D-802C
2 Faults Found:
01304 - Radio
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 239 km
                    Time Indication: 0
                    Date: 2001.14.04
                    Time: 16:58:18
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 28
                    Reset counter: 255
                    Mileage: 239 km
                    Time Indication: 0
                    Date: 2001.14.04
                    Time: 17:06:59
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 686 H    HW: 3T0 035 686 H
   Component: RNS-MID       H21 6270
   Revision: AB001001    Serial number: SKZ6Z7N1103755
   Coding: 00000400000000000000
   Shop #: WSC 00000 000 00000
   VCID: 3B7F2FACBA9B61C6811-806E
   Subsystem 1 - Part No: 3T0 051 859 Q
   Component: EU West V10  8048
7 Faults Found:
01042 - Control Module; Not Coded
            000 - -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 20
                    Mileage: 232 km
                    Time Indication: 0
02877 - Digital Radio Antenna (R183)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 12
                    Reset counter: 20
                    Mileage: 232 km
                    Time Indication: 0
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 232 km
                    Time Indication: 0
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 10
                    Reset counter: 20
                    Mileage: 232 km
                    Time Indication: 0
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 19
                    Reset counter: 20
                    Mileage: 0 km
                    Time Indication: 0
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 0 km
                    Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 16
                    Reset counter: 60
                    Mileage: 5763 km
                    Time Indication: 0
                    Date: 2002.14.11
                    Time: 03:35:59
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
7 Faults Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 20
                    Mileage: 232 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 12
                    Reset counter: 20
                    Mileage: 232 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 232 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 10
                    Reset counter: 20
                    Mileage: 232 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 19
                    Reset counter: 20
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 16
                    Reset counter: 60
                    Mileage: 5763 km
                    Time Indication: 0
                    Date: 2002.14.11
                    Time: 03:35:59
Hope this means something to you?
Looks like it simply needs coding using the long coding helper. Have you done any coding for the new unit?
Clear all the codes first and see what comes back - some of those are likely from when the unit was swapped over
HI there, any one knows how to keep the DRL STAY ON while the headlights are on? thank you!  :angel:
Edited by racncarboy
Not possible through coding on mk2 it should be on mk3 though :-)
