No Power Steering (PAS)
Thanks sepulchrave :)
I will order this one then: 6Q0 423 156 AB, but its off a VW Polo... but same OEM nr, so it should be fine right?
Yes that's fine  :)
Oh wait, is the car right-hand drive?
Edited by TMB
  • Replies 60
  • Views 55.9k
  • Thanks Avalon for your input. I did actually check the fluid level of the PAS the day after it stopped working, I forgot to mention that in the startpost. The level was below the minimum. When I'd put
  • So, this easter I've spent my days in a dark garage while the weather outside was phenomenal. The result: a disection on the pump. The good news is that I found the problem but the less good news is
  • Are you sure the link is right? It leads back to my own post. How do I program the pump? I have a VAG cable
It`s a LHD car... is that a problem?
EDIT - gave wrong info by mistake.
Edited by TMB
Wait till I check partscats again. I might be getting mixed up. Won't be long....
well, thats strange. My original pump is: 6Q0 423 156 E
If the third number of the part number is a zero then it will fit both LHD and RHD cars, so the original number you said (6Q0 423 156 AB) should be fine :)
Thankyou :)
I like this forum :)
Only the wire to the sensor, pipes and rack are different on LHD, pumps will all be the same.
Update; I changed the pump on my fabia 1,4 2001 ... Changed from the original part 6Q0 423 156 E, to a pump from a 2007 polo with part nr. 6Q0 423 156 AB and it`s working like a charm :clap: :clap: :clap:
  • 9 years later...
Digging the old thread.
Background: I bought an used Fabia Mk1 2003 make in Germany (LHD) few months ago and it was running fine until few weeks back. From the time I bough the car, the steering was little bit hard but not too hard (it is easy to steering when car is running and when car is at standstill or at slow speed one has put extra effort to turn the steering. I assumed that this is normal for cars with hydraulic steering since this is the first time I am driving the car with hydraulic steering.
Issue: Few weeks back, one day when I started the car on a morning and I got the steering wheel faul indicator on dash and from then onwards there is no assistance. I managed the short run by applying extra effort to steer the car. I have OBD11 so did a scan and it showed "00566 - Implausible error". I refer to this forum and did the following checks:
  • Battery voltage while idle ~14V
  • Battery voltage with more load (rear window heater, A/C, high beam): ~13.8V
  • Measured voltage at both ends of fuses on the top the battery: all ok
  • Checked fuses in the dash fuse box: all ok
Then took it to a workshop. The mechanic also checked the error code and the dash fuses and found out one of the dash fuse is gone (not sure how I missed this out). He replaced the fuse and error is gone and PAS was working properly.
Then after few days of driving, the steering fault light up again in dash on a parking lot. Today took it the same workshop. The mechanic checked the fuse and said everything is ok and next step to replace the steering angle sensor and the see whether the error is resolved. But when I checked with OBD11 last time, the steering angle sensor responded while turning the steering so I was skeptical whether sensor would be faulty. Took the car back to home and scanned again using OBD11 and got the error codes as shown in the attached images. Basically it is the same 00566 code with additional ECM codes which are intermittent (may be the mechanic has misplaced the fuses while checking - I have to check the fusebox again).
Please guide me on how to proceed next.
