Amundsen MIB STD2 infotainment system with Android in Superb II
Ah thank you! Have you got a link to the camera you purchased? Tempted to grab one myself. Not sure why I want to volunteer taking all the interior panels off again! :)
  • Replies 399
  • Views 168.7k
  • Navigation works with no issues:   Media Player:   Radio (DAB+)   ANDROID   Smartlink is not active (at least yet) :(   Voice commands work OK   Bluetooth HFP works OK
  • I also considered removal of the WIFE1 component but I found mine was hard-wired to the media selection. It sometimes plays Iron Maiden successfully but reversion to Foo Fighters, Linkin Park and Ramm
  • A short movie
I used this one - great quality & direct fit.
https://www.aliexpress.com/item/32867335459.html?spm=a2g0s.9042311.0.0.721a4c4dIA0n8K
You'll be pleased to know you only need to remove the rear hatch plastic and (depending how you route the RCA cable, I went along the roof lining and down the A-pillar) the side panel on the dash which just pops off! :)
Nice! The link has two options, the 8011 or 8012, which did you grab?
Different plus for switch so you'd need to check your current one.
8012.. to be fair to the seller, he also double checked which one to send:
Hi Tony, Thanks for checking.
Mine is a Skoda Superb 2 with 92mm trunk handle, it has the 15mm electrical connector.
Read
17/09 08:50
Yeah, is 8012, fit. Thank you for your confirmation, we will ship it as soon as possible.
Time to pull my handle and measure up!
So I can't get the  MFSW phone button working correctly with CarPlay. When pressed it just shows the CarPlay info in the MFD (photo attached of result).
I've been in and pulled my VCDS logs for the Amundsen unit on 5F and the car itself. I've checked the coding for byte 16 and the button is enabled. It works correctly for standard phone mode as far as I can tell, pushing it tends to redial the last number.
My basic logs below - the battery regulator fault I believe is because of the car detecting a parasitic draw from my dash cam I was installing at the time (now with parking mode added) which no longer causes issues.
Monday,09,November,2020,12:12:24:51726
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: TMBKJ73T3C9020618   License Plate:
Mileage: 144100km-89539mi   Repair Order:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 61 62 72 77
VIN: TMBKJ73T3C9020618   Mileage: 144100km-89539miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 JJ    HW: 03L 906 023 JH
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number:
   Coding: 00114036032501080000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_ECM16TDI02103L906023JJ 003011
   ROD: GV_ECM16TDI021PQ36.rod
   VCID: 77DBC7E3CE074A3E22-8023
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 863D6016092400FA611106E590210091300000
   Shop #: WSC 33361 790 00077
   VCID: 7BD3DBD3FA2F6E5E46-802F
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000003
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 7CD1D8CFF72169664F-8029
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 R    HW: 1K0 937 087 R
   Component: BCM PQ35  H+  110 0651
   Revision: 00110 AC
   Coding: 48010AB8A05BF1C040080080310081E4437000AE436D81605C81C7000041
   VCID: 40A96C3FD349CD8653-8015
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 30071  26  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 150811 05  54  0403
   Coding: 2730ED
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901122900259
   Coding: 108015
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 334333F39AFF661EDE-8067
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LAU VW10 HI   1918
   Revision: 20014000    Serial number: 003K2PGM33CK
   Coding: 0016725
   VCID: 41AF693B1843C48E5C-8015
   Subsystem 1 - Serial number: 6332MTS615942101
   Subsystem 2 - Serial number: 6342MTS616042101
   Subsystem 3 - Serial number: 6351HTS645EU8AKJ
   Subsystem 4 - Serial number: 6361HTS6GDSU8AKR
   Subsystem 5 - Serial number: 63727TS6NA8C8AKR
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110808301362
   Coding: 108A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79DFC1DBF8135C4E54-802D
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 3T2 920 941 K    HW: 3T2 920 941 K
   Component: KOMBI         H05 0607
   Coding: 411B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 3D5715CBACBBA06E38-8069
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 060811F2001788
   Coding: 359303
   VCID: 375B07E386878A3EE2-8063
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0607
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6AFDEE978DB5E7D6AD-803F
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Revision: --------    Serial number: --------------
   Coding: 011D0220D001001000
   VCID: 4F8B5F031E1722FEDA-801B
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 194    3201
   Revision: 00H20000
   VCID: 344130EF57F16126C7-8061
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4EB54207191D2BF6D1-801B
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H43 1620
   Coding: 030B185A
   VCID: 71CFF9FBA863140EEC-8025
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900180044
1 Fault Found:
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00110001
                    Fault Priority: 7
                    Fault Frequency: 39
                    Reset counter: 206
                    Mileage: 139660 km
                    Time Indication: 0
                    Date: 2015.02.21
                    Time: 02:20:48
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200001001000
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H06 0409
Address 77: Telephone
Cannot be reached
End
                Address 5F: Information Electr.       Labels: 3V0-035-MIB-STD2.CLB
Control Module Part Number: 5L0 035 680 E    HW: 5L0 035 680 E
  Component and/or Version: MU-S-ND-ER    H31 0363
           Software Coding: 03130601FF00000051111201008800002F0100C60120010046
            Work Shop Code: WSC 73430 790 00063
              ASAM Dataset: EV_MUStd4CTSAT 001022 (SK37 *)
                       ROD: EV_MUStd4CTSAT_VW37.rod
                      VCID: 2C71288F47C139E69F-8079
www.Ross-Tech.com
   Revision: 00H31001
   Revision: 00001007
   Coding: 0000000003
   Revision: 00110 AC
   Coding: 00D7B7
   Coding: 2730ED
   Coding: 108015
   Coding: 0016725
   Coding: 108A140000
   Coding: 820000
   Coding: 411B00
   Coding: 359303
   Coding: 000000
Cannot be reached
   Revision: 00H20000
Address 56: Radio
Cannot be reached
   Coding: 030B185A
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 39
                    Reset counter: 206
                    Mileage: 139660 km
                    Time Indication: 0
                    Date: 2015.02.21
                    Time: 02:20:48
Cannot be reached
End
Think that's how it works, at least my t6 transporter does the same if I try and use mfsw phone functions whilst in carPlay.
Oh I would have thought it prompted Siri or the Android equivalent to pop up!
I think you can recode the left roller as a "push-to-talk":
- Go to address 16 (steering wheel) and check byte 1, bit 3.
I can't remember exactly how it works as it's been ages since I had the original MFSW fitted. It might remove the mute function or make a short press mute and a long press voice control?
The other solution is to fit a MK3 style wheel as that has separate voice and phone buttons ;)
Ah I will have a look at codings later. I can grab a mk3 wheel with the next parts purchase, is there a specific part number or car it should come from? I miss my old flat bottom vRS wheel.
might that enable talking to android assistant instead of saying ok google?
I believe so :)
Any MK3 wheel will fit, the buttons are where you need to be careful..,
They need to compatible with PQ platform cars so would have been fitted to a Yeti or MK2 FL Superb. You can switch the buttons easily enough. I used 5E0919719F which have green backlighting and no DSG paddle support.
So tried pressing and holding the +/- roller a couple of days ago and indeed Siri does come to life! Appreciate it's a retrofit so going to operate slightly differently.
Thank you Langers2k and all, I will keep an eye out for a wheel to pop up at the right place, hopefully with an airbag with it!
Need some help on this unit if possible! Got the 5L0035680E and Ive got a 5G0035222F however my Smartlink doesnt work - Android Auto ends up in a Black Screen and Apple Carplay just comes up as Connection Failed - tried a few different cables - still no luck? anything on coding to check?
What have you enabled via VCDS?
There's about three or four options that need to be enabled within the 5F coding module, all pretty self explanatory (mentions Apple Car Play, Premium connectivity etc)
Did USB full in Long coding - made sure in adaptations google_dio, apple_dio and Smartphone interface is activated
Hi guys, I have installed Amundsen in 2006 Octavia II. CP is off and everything works great except bluetooth, when I press wanna connect the phone only what I get is message "Bluetooth not available". Is there any solutions?
5L0035680B
SW was 0245, updated to 0253.
Anyone?
Have you disabled your old Bluetooth module in the car (if you had one)? Has Bluetooth been enabled on the new radio?
There was no bluetooth before in the car, Bluetooth has been enabled but when I press phone there is message "Phone not available".
Have you paired it with the car/radio? May sound like a daft question.
I can't remember if I paired mine using the MFD display or the radio itself.
Edited by Oli
Friend of mine was doing it, he installed dozens of these radios in VW and everything works great. He also installed another one in FL Octavia and there is the same problem HW and SW are the same...
Maybe post an autoscan from VCDS?
A 5L0035680E worked flawlessly in my old FL Octavia and I'm sure @pab567 has sold loads to various Octavia owners too.
This one is 5L0035680B. I will post autoscan tomorrow.
