S3 owners - electric tailgate / hatch closing from inside
Would you pay for the rear hatch / tailgate to close from the button inside the car? 134 members have voted
  1. 1. Would you pay for the rear hatch / tailgate to close from the button inside the car?
    • Yes, I live in Kent and would be happy to travel to Folkestone and pay for this to be enabled
      18%
    • I don’t live in Kent but would still be happy to travel to Folkestone and pay for this to be enabled
      72%
    • No, I live in Kent but this doesn’t interest me
      9%
  2. 2. How much would you be prepared to pay for this?
Please sign in or register to vote in this poll.
1 hour ago, ile7 said:
Easly done with carscanner, didn't had to choose other dataset version, just changed interior button option to allow open and close while ignition on and off. Closing with button pressed, opening tap button
Glad it worked ok. I’ve seen it work fine for some and others it won’t even read the module. I think it’s very dependent on what hardware you’re starting with!
  • Replies 235
  • Views 111.8k
  • seriousness aside -  a number of supercars deploy rear wing spoilers at high speeds for increased downforce/stability. bugatti, amongst others also use the rear spoilers as air-brakes too.
  • I've done 450 miles this week so far with another 330 to do tomorrow. Happy to drive to you. Happy to pay for it. Will bring you a pork pie and a decent bottle of melton red ale as a cultural exchange
  • As a disabled driver, I would happily pay a reasonable amount for this.  The non availability drives me bloody mad.  Who in their right mind would design a facility to open the tailgate from inside, o
On 01/08/2021 at 06:12, AlVal said:
Select the right module for the bootlid controller (6d), on the list on the right it's 'data transfer', and send the parent xml file (the one called "arbeits"), it will send any children files also
Hi, do you open the file and just use arbeits file? Thanks in advance Al
Hi @AlVal do you just send the parent file not the whole downloaded file?
Hi. I have a problem configuring the trunk lid closing function using the button located next to the DSG shifter. My control module is 5Q0959107L. During the attempt, the error shown in the attachment appears. “Odśwież” means “refresh.”
Facelift model?
5 minutes ago, defsix said:
Facelift model?
No, 2016.
It seems very hit and miss as to if it works with carscanner. Perhaps try a hard reset in the relevant long coding section?
Thank you for your reply. Could you explain to me how to do it? I’m a beginner.
@Dawid93 check in 6D module Adaptation, line Activation using rear lid remote unlocking switch-Tap function for closing
Do you have this visible?
Unfortunately not.
Go to long coding, boot lid and then scroll to bottom and select hard reset.
Long coding
6D bootlid
Hard reset
  • 5 months later...
Can you help me please how does it work on facelift model? (Mine is a 2021 L&K)
I’m pretty sure this isn’t possible on facelift models.
Hey everyone! 👋
I’m wondering if anyone has found a solution for enabling remote tailgate closing on the newer 6D modules used in Škoda models from 2021 onwards.
My Škoda Superb Combi (2021) has the following 6D (Trunk Electronics / J605) module:
  • Software number: 5WB 959 107
  • Software version: 0430
  • Hardware version: H04
I’ve been trying to activate tailgate closing from both the interior button and the remote key using OBDeleven. However, my module doesn’t have the adaptation options available on older 6D versions, such as “Activation using rear lid remote unlocking switch – Tap function for closing.”
Has anyone managed to enable this feature on the newer 5WB 959 107 module? Is it possible through coding or adaptations, or would it require modifying the dataset?
Any help, suggestions, or successful experiences would be greatly appreciated! 🙏
Thanks in advance! 🚗
As far as I’m aware this is not possible on the newer facelift models.
Hi @Binx1310
Even with the changing of Dataset it is not possible?
Hello
So I have tried many times yesterday
Don’t work at all.
I got obd2 as follow
Vgate vLinker MC+ Bluetooth 4.0 OBD2 Car Diagnostic Scanner
Also
MUCAR BT200 Max Automotive OBD2 Code Reader Lifetime Free AI Diagnostic Scanner
also vcds
I know vcds won’t work
But with above every time try do something saying’s that my obd2 are faulty
They are genuine btw.
Also im using car scanner pro ( paid for full version)
Anyone able please direct me in the right direction?
I have read all 9 pages but would love someone go through again perhaps some more new updates etc
Thank you in advance
On 28/03/2026 at 14:41, Gizmo said:
No I sold my VCP a few years ago
Hello @Gizmo
Will it be the only one able to sort coding?
Any links recommendation please?
My 2 obd2 not able to do and showing faulty wondering cos car not able to do no matter what as showings my diagnostic tool faulty
Please read my new respond in here
On 12/10/2026 at 15:15, Oleks said:
Hi @Binx1310
Are you able if so change dataset and what with?
I have seen this before. It seems to be very hit and miss for coding this. I tried exactly the same as I did on @AL2772 's car using my module and app and it just kept saying bad OBD2 module. I think it is very dependent on your OEM dataset version.
Does carscanner and your module work for other coding ok?
Yes able do other coding but not all if that make sesne. Wonder why sayings faulty etc especially both of them genuine too. Very frustrating…
@Binx1310 do you know what that means?
If I change as on this photo you reckon will I be able to do successful coding of closing via button inside?
Edited by Tom1214u
Added photo
Also meaning of soft/hard reset and what will it change please
You cannot do it by long coding. It has to be done with datasets. Soft and hard reset restarts the modules.
It says bad elm obd module when it can’t read or write data. Doesn’t mean your device is bad.
Have a look at this post. If it doesn’t work it cannot be done.
Can you please elaborate
