Installing Speed Cameras on The Amundsen MIB2 - Free Database and Quite Simple to Do!
Possibly a silly question, but can you install this on the Navigation SD card, or does it need to be on a separate SD card?
  • Replies 488
  • Views 135.4k
  • Latest Updated Speedcams - December, 2022.   It's been a long while but at last here's the latest update of my customised version of EUR Speedcams ( December, 2022). They consist of the full
  • Latest Updated Speedcams - November, 2021.   Here's the latest update of my customised version of EUR Speedcams ( November, 2021). They consist of the full EUROPE speed cameras which I've sp
  • At last and after a long break - here's the latest update of my customised version of EUR Speedcams ( February, 2021). They consist of the full EUROPE speed cameras which I've split up into four conso
@bigade1
Any idea why POI notification doesn't work when I compile my own cameras with my PocketGPS cameras?   If I use your version notification works fine.    The cameras work fine, they just do not "BONG" as I approach them even though the Amundsen is set to notify my own POIs.    Obviously not life and death but just a little bug I would like to fix.  Cheers
5 hours ago, Blisteringblue said:
@bigade1
Depending on the programme that you use to compile the files there's normally a setting to tick to allow an audible alert. I suspect that you may be using the free version of PoiBase and if I remember correctly it also wouldn't work for me when I tried it a year or two ago. Perhaps it's done deliberately to make you pay for the unrestricted version but I'm not certain.
Cheers, I will have another look next time I do an update.   I paid 5 Euro's to unlock PoiBase so will have a look.
On 18/05/2021 at 07:34, rudeboy1971 said:
Anyone tried to test it on seat? Pls assist....
Works on 2017 Toledo and 2018 Leon (both MIB2)
Hi all, new Octavia VRS owner here :)   I have a 2010 with a Columbus Sat Nav (as pictured).  I have tried bigade1's files (thanks for this) and followed the instructions. (I do also have a pocketgpsworld sub)  But can't see to get the files to be able to load.  I have no "manage memory option".  Is my Columbus too old to support the files please? Many thanks in advance.
  • 3 months later...
Cheers! Much appreciated.
Not wise to have this in France.
Or any other European country e,g. Germany, Turkey, Switzerland etc. that has restrictions on displaying speedcams on satnav devices but thankfully you can turn the speedcam display and audible alerts off in the device settings before entering any affected countries. That is the official advice given by the manufacturer TomTom to their particular device owners. Obviously, the onus is on anyone driving in a foreign country to make themselves aware of any motoring rules and regulations before driving there.
Last I heard because we left the EU if you’re caught speeding they can’t request our details to forward on the fine now, result.
Won’t help if you’re pulled over though
Or if they are waiting for your next visit with the data at the port.
Hi guys. Newbie to the forum. Do these work for the MIB1?
tried downloading latest set, putting the PersonalPOI folder on and a different metadata2 file from page 2(?) earlier in thread, to no avail yet
error
Edited by vRSG60
  • 5 months later...
Thanks for this. Is there any further updates available?
  • 6 months later...
Thanks for the update on your absence Bigade....and thanks again for the speedcam update👌
Many thanks - much appreciated.
As usual, not at home, so will download and install in a couple of days.
Edited by BionicJohn
Spelling
I am having a problem updating when I put the card in the SD slot it seems to read it OK as it says Software update is available.
But when I try to update it searches, then gives me  following Error : no data available. Please insert a source with software update or check the source
I have extracted the files and copied the PersonalPOI folder,
I note that there are subfolders MIB2HIGH and MIB2STD and both of these have personalpoi folders, so I tried copying the contents of these in to a personal poi folder and still get the same messages.
What I am I doing wrong?
Could it be because I am using the latest VW map update 2010?
I deleted the previous my personal poi on the system, these were the previous updates you posted.
Edited by BHughes
15 minutes ago, BHughes said:
OOps the two subfolders are MIB2 and MIB2STD.
MIB2 has a subfolder MIB2HIGH
Sorted now.
Many thanks for this !!
Edited by DBSurrey
Great stuff bigade1 - really appreciate your efforts and making them available!
Thanks, bigade1 for the update and all your hard work.
