Yep, I’ve got one Premier express so that should turn up in a week /a month / three months …. whenever, 😆 i’ve just bought a cheap pack of the rods to pull the cables through or at least pull a cord from the front of the car to the back through the headlining and then I can pull the two cable straight through to the dash cam and then run it down alongside the rest of the cables from the roof headlining/ interior lights down to the glove box
I wasn’t sure about the aerial, so it might have been something stupid like when I called the glovebox unit out to check the model might loosen something, but reading some of the posts seems as problems we walk getting in and the amplifiers in the roof but I’ll have a look at that later … about 2 o’clock in the morning when I get home…. I think this is where I miss some of the steps, cause I’m too bloody knackered for it to all sink in 😜🤪.
  • Replies 5.3k
  • Views 608.1k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
If you want more bass you could always do something like this…
@Binx1310 "Getting there finally. Got a few more fix up jobs and cosmetic thing to do. Then I’m deleting AliExpress app!"
oh I see so you’re gonna be stop because you’ve reached the end of all the bits you think you can do on yours so you’re gonna try and palm me off onto somebody else’s build … 🥹 😜🤪
Yes that. And also the extension on our house is nearly complete so time and funds will be diverted to that!
@Binx1310 ” the extension to my house is nearly complete” 🤔🤔 I can’t remember reading anything about a triple underfloor heated garage ?? 🤔😜
As usual, I didn't do anything to my car but it has done something which means I will need to do something!
Anyway, ESC fault, adaptive cruise, SS, park pilot, etc unavailable warnings came up earlier. Last time it did so (I think more faults than just speed related like this time) was battery.
This time I reckon it is ABS sensor. Will find out with a scan soon!
Sounds about right. Similar situation for me a few weeks ago. Christmas tree of dashboard warning lights turned out to be be 2 x ABS sensors front & back. Expensive bill at independent VAG garage.
I am half contemplating DIY. Or getting my local garage to just do the sensors if I manage to scan it and have confidence it's the sensor problem. Will see. I thought I am in no hurry but then the rear park sensors don't work and I need it....
