26 minutes ago, jeffl said:
Bit of an AliExpress spending spree for me. Bought a wireless Android Auto/Car play dongle as I was bored of plugging the phone in for short journeys. Works fine and well worth the £12 I paid.
Also got a reversing camera that someone on the Octy 3 forum mentioned. For £40 can't complain. No coding required, but routing the cable was a bit of a ball ache.
OG Octy 3 thread and a useful video on cable routing for the estate Superb.
https://www.briskoda.net/forums/topic/485897-how-to-reverse-camera-fitting-guide/
https://m.youtube.com/watch?v=kAndR7pgjcM&pp=ugUEEgJlbg%3D%3D
They’re the same changes I did. Had them both for nearly a year and performed perfectly. Well worth it.
I also added a MagSafe charging pad. Ideal for short journeys but tends to get a bit warm on longer ones.
  • Replies 5.5k
  • Views 713k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
Spent the evening connected to @pab567 in an attempt to revive my failed MIB 2 to 2.5 upgrade. Unfortunately it’s not in a state to be recovered remotely so the MIB unit is off on holiday to Poland for some TLC.
Was the old screen bad well? I managed to get mine done remotely with a lot of hacking and me buying a UART board and a very helpful bloke in Telegram. I spent a few days beforehand driving around listening to a Bluetooth speaker in the car and hoped I wouldn't have to access anything on the screen
Screen seems to be good as far as I can tell. Old unit as MIB 2 worked perfectly. Some kind of issue during the upgrade corrupted the eeprom. Spent the last week learning about uart and PAB connected remotely this evening to try to fix it. But it can’t be written to or read through the terminal. Needs a physical connection to the eeprom directly to reflash it unfortunately. I have a friend who is an electronics engineer and he offered to have a look but we would both be learning what’s needed and winging it whereas I can send it to an expert and get a plug and play unit back.
This is the last thing I do to the car. Essential maintenance only from here on in!
Famous last words
23 minutes ago, tombee said:
Famous last words
After the issues with the radio it’s more than my marriage is worth to be spending more money on “pointless upgrades”!
Mine is booked in for a Service and MOT next week, service is part of the plan from the dealer, so will see how that goes.
Then fingers crossed no issue's I will be fitting the wheel spacers and performance replacement top to the air box etc
Edited by tombee
After months, last time was 25th of June before the car went in to Skoda for warranty work.
I washed the car today, been putting it off but after France/Belgium, Devon/Cornwall in the summer and then some other trips the car was filthy, more the wheels than anything
Wash it twice due to only buckets!!
Got mine given a quick once over yesterday too. Makes it look so much better. Won’t last long I think!
It’s already spitting with rain haha
Grindy grindy noises last night. Have ordered overrun pulley for alternator along with tensioner and new aux belt this morning. 63k so about right for failure timing. Ordered INA parts for over run and tensioner kit with belt.
I had ordered wrong front wipers set Bosch A638S so I removed the rubber from them and put it on the OEM ones I had from the factory. You can call me a "cheap guy" but I didn't want to throwaway 40 euros D
The rear one fit like a glove on the Scouty - Bosch A405H.
You did well there, I’ve a set wrongly ordered and I’m well stumped on how to get the rubbers out…….?
The rubber stoppers at the end of the wiper(either OEM or Bosch) weren't glued. Turn the wiper upside down, so the rubber part faces you, then using a small screwdriver carefully lift the metal clips holding the plastic stopper. In the same time try to wiggle and pull the plastic stopper.
Don't use much force when lifting the metal clips with the screwdriver, but you may need when pulling the stopper because it's usually stuck from the accumulated dirt.
Both Bosch and OEM had different type of plastic stoppers, but when you wiggle the specific stopper a little and push and pull gently, you'll see what blocks the stopper to be removed and so which parts need to be lifted.
Edited by fr1nklyn
Managed to finish the upgrade of MIB2 to MIB 2.5 today having managed to completely brick my original MIB. Thanks to @pab567 for providing a replacement plug and play unit. Cannot fault the service!
Just returned from a 2,000 mile loop to Prague and back. Spent £158 on a full tank of petrol in Germany, £102 for the same amount in the Czech Republic. So, move to Prague!
MOT/service on Wednesday. Picked up a small crack in the windscreen - wondering if it's enough to fail me...
You’re allowed a Max 10mm crack within the width of steering wheel the height of the screen, and max 40mm outside that area. I’ve got 2 or 3 small chips in a few places. Expecting them to become large cracks at the first frost!
You should get auto glass to fix the chips, they done that on mine but it didn’t last long, so got an official Skoda replacement
Discovered a line of dead pixels in my new mib2.5 screen today. Luckily there was one day left to return it to eBay! Replacement ordered.
This must have been one of the first 9.2" displays in terms of production. The same issue also occurs with the Virtual Cockpit; it’s a stress fracture directly within the LCD—essentially a manufacturing defect.
