Amundsen MIB2 Firmware Update
Hi pab567,
Is there a software update available for the below please?
Device Part # - 5Q0035842A
Hardware: H24
Software: 0245
Installed Software Version - MST2_EU_SK_ZR_P0245T
H25.14.78_STD2Plus_EU
Many thanks in advance,
  • Replies 4.6k
  • Views 770k
On 29/4/2020 at 12:26, pab567 said:
Enlace enviado por PM
Hello @ pab567
Could you please also help me with the link to update my 5Q0035840C / H41 with the software 0468 (Amundsen without Navi).
Is there a newer firmware available?
3 minutes ago, David_Alvarez said:
Hola @ pab567
¿Podrían ayudarme también con el enlace para actualizar mi 5Q0035840C / H41 con el software 0468 (Amundsen sin Navi)?
¿Hay un firmware más nuevo disponible?
115960389_10159037909839095_2065820177511124814_n.thumb.jpg.4bfef7680a046d21f36325857e053026.jpg
Check your PMs
Hi, just wondering if there is an update for my system below?
Thanks for the support!
Hey pab567,
i see you are like a Santa Claus, can you help me with a  latest update.
Thank you.
Hola
¿ enlace para actualizar mi 5Q0035864A / H24 con el software 0245 (Amundsen + Navi)?
can I do CarPlay? thanks
could you take a look if there is a newer version for this one?
Thank you!
Hi @pab567 can you check to see if there is an update available for me please?
Hello @pab567, i am having some issues with park pilot randomly saying it is not available and wondering if a firmware update might help. This is a pic of my radioscreen in the 2016 Skoda Rapid Spaceback that I have. I know this is an Octavia forum but would be most grateful if you could let me know if it would still be ok to update. Kind regards Nath
All check your PMs
Is there an update available for my Amundsen?
Has anyone needed to clear loads of fault codes after doing the update?
Just want to be prepared as I've got VCDS on my laptop but I've not actually hooked up my car even though all the software is installed I remember having USB connectivity issues the last time I tried to connect to my laptop to unlock a ton of features that were disabled by the factory such as cornering fogs and traffic sign recognition etc
Normally only one, the one that says a firmware update has been done.
Hi there,
might there be a newer version available?
On 06/08/2020 at 14:30, pab567 said:
All check your PMs
Hi @pab567, can you provide update 0478 for Kodiaq Admunsen? My dealer refuses to update the system after asking them 3 times, its ridiculous I know. Thank you very much.
BTW I'm on 0475
14 hours ago, gerstemann said:
Hi there,
Not this screen - need Device Part Number and Software
All others check your PMs
Hi @pab567 here the right screen! Thanks for your help?
Check your PM
Any luck for mine?
Like everyone else, I'd like to update the firmware if possible.
I have a few questions, firstly I bought this MIB2.5 and retrofit to a Octavia 2015 build date 15/05/2015 from a really helpful guy from Sydney AU. I think the MIB originally came from Bulgaria or Turkey as both countries appear in various menus.
I have recently updated the navigation but had to change some file/folder names to the EU to make it work. Is there a way of changing the country to AU of the MIB unit so I don't have to change other things to "fool" the MIB to thinking it's still in the EU?
@ PAB567, I follow another thread you have written on and commented on that ability to have the colour folders instead of the monochrome carousel and I'm wanting to know how to change this. I have been on youtube to find out about Skins and connected my OBDeleven to see what can be changed but there isn't an explanation of what Skin1,2,3.......8 actually means. Am I looking at the wrong thing?
@bladerara you have the latest SW
@asavvyman check you PM for latest SW. I don't know if your unit has been reworked and with what solution but basically for having AU maps on SD without changing folder name you must recode byte 03 in 5F from 01 to 08. If this doesn't work then additionally license for AU maps shoudl be installed.
To have the colour folders instead of the monochrome carousel is not a piece of cake - it requires hacking of SW download and then updating with hacked 04xx SW.
