Amundsen MIB2 Firmware Update
Hello! There is any update for it?
5Q0035840B
SW 0367
thank you!
  • Replies 4.7k
  • Views 898.3k
I don't have any... others pls check your PMs.
Well unfortunately and after updating my AMUNDSEN2 no improvement or even worse, a real fault with my screen which has become far too dark and with too low a brightness (even fully in the settings)
I can hardly see what is displayed in the middle of the day and, almost nothing in the event of the sun = I am sad and disappointed. 😔
Is there a way to go back please? 🤔
13 minutes ago, Flipou said:
Bon malheureusement et après mise à jour de mon AMUNDSEN2 aucune amélioration voire pire, un vrai défaut avec mon écran qui est devenu beaucoup trop sombre et avec une luminosité trop faible (même à fond dans les réglages)
Je vois à peine ce qui s'affiche en milieu de journée et, presque rien en cas de soleil = je suis triste et déçu. ??
Y a-t-il un moyen de revenir en arrière s'il vous plaît ? ??
EDIT: error on my part, the screen brightness is in a mneu which is not concerned with "mood lighting" but by the "screen" menu so I was wrong, and I finally managed to set my screen correctly (sorry double post but not found how edited the first one) good evening
Hello, I would really appreciate the updated firmware for my unit.
Thank you very much.
Hello! After update to 0480 i lost my gps maps on. It cant load navi. Do you have any idea?
Based on my experience, update to 0480 for Amundsen units seems to remove patch for using non original SD card for maps. No other issues noticed.
Do you have original Skoda SD card or not? If not, you need to get one to have navi back working or patch the unit again. If you have original card, no quick hint.
patch the unit? downgrade?
Nope. I mean apply the same patch you did in the past to skip original SD card check.
As far as I know it can be done via MIB2 Toolbox or some other way..?
Happy New Year to all here. Really nice to see such an active community of Skoda owners/drivers and support here.
Looking if there is an update available for my system. It seems that @pab567is a real expert and specialist.
Pls see attached
Thanks in advance
Pls post the list if installed FEC/SWaP codes
@PvD check your PM
Edited by pab567
@PvD check your PM
Was this unit factory installed or retrofitted?
Factory
Hi there @pab567. Is there any update for this?
I am struggling with updating my NAVI with new map. Could it be because the SW i FW is old?
Cheers
I don't think so... download link on PM
Is the SD card original? hae you unpacked files directly to the root of SD?
The card is not original. Trying it on a regular Sandisk SD card. I've put the files on the card like they are on the original. Using MacOS.
Should I erase the original card and then put the files on it?
You need an original SD card for a factory/stock Amundsen to load the nav data :)
It checks the CID and if that doesn't match, it won't work. There are a few SD cards where you can change the CID to match an original card but there are quite rare, it's certainly easier to grab the correct card.
I have the original one, will try to erase and put the new data on it. Hopefully it works :)
Before you erase it copy the data onto your PC as a backup :thumbup:
Hi @pab567:
Do you know if there is a newer firmware for the following combination:
Device part number: 5Q0035840C
HW: H41
SW: 0468
Thank you in advance.
Ofcourse. Hopefully I'll don't need it, but you never know.
Will post the update of SW and maps if I manage it :)
@dsdd PM
Happy new year everyone!
@pab567 I'm looking for a new FM for the following MIB2:
Device part number: 5Q0035874A
HW: H24
SW: 0245
Thank you very much in advance!
PM
