Amundsen MIB2 Firmware Update
Hello.
I buy a new hardware, the screen is 5E0919605N and the module is 5q0035840B.
There is a new firmware for this???
Thank you.
Note: It doesn't the rear camera and I don't know how coding the hardware with the ODBELEVEN for it works.
Regards.
  • Replies 4.7k
  • Views 905k
Hi pab567. Please can you provide the latest software update available for my device?
Device Part Number: 565035864
Hardware: H41
Software: 0478
Thanks in advance!
Hello pab567, hello all
Octavia MKIII
If is possible to provide me latest software update for
Device part number: 5Q0035864C
Hardware:H41
Software:0456
Thank you
Hello @pab567
Are there any software updates for my system or do I have the latest already?
DPN 5Q0035874C
Hardware:H41
SW VER 0468
Thankyou
@pab567 Hello, I don’t know if you have some new software to update mine, please.
You’re making lots of happy people here. 👍
Device Part Number: 5Q0035864C
Hardware: H41
Software: 0475
Thank you.
Hi @pab567,
Could you tell me if my cars software is up to date?
It would be good to confirm that my car is up to date so the dealership can't use it as an excuse to charge me for a warranty issue.
Z góry dziękuję
PM
Successfully updated (thanks pab!)
And cleared resulting error check code😁
Hehe, what's next....
Unfortunately I am experiencing poor DAB+ received. The device has been replaced and worked well, I tried some updates but the system say is too old for update.
@pab567Could you please please please tell me and give me the next versionto update? I think I need some version between...
Thanks!
I'm sorry but you already have the most recent version available for your unit 😞
Thanks anyway ! I will try a pre-amplified antenna.
f9_BerEct3_tFWLpusI4sVjSFcAQN7nfXVlhgmm2lBIT6H4jlMlLJvxeS4ohDC_AVVubO3twIXBfOjE1Xz6eR_-YRCweeo_iByUx9fn6lb33a4muqPz_6Dlg8CdQy28dpqV83Tl75HPlkU7s9t5Jj-5GYFXLJpJjozNaxyFiD7VYXs0Q8cmakhusL7oGTG8-Agj2mfCP71Pq1DQ3VXK3IuyW72cTQD8zcQ_2hF4M2vgaB4NPBAjkYZ-pliRO-G8PEVHRhW210DO86kPr-h55jekixfTEt6JlR3SU7r7S5mmqI4ziS5FNenG8yXRfdYXcy-HS8jwZrH48ul4r9MYpEpRJb-gCJ4m6uTlITi5VMJmiVWPT2hNSU-G6efEjpt4cgnMnnSAFl_R1Uqik-eWICAZAj8EvmCzdao0vreYz_NgQ9OdcBDUfocj5u6zx4nwvPH9izoDZSw0PRt_0zTu5PMqnqpvbBeu9qC_NJ9Qij_Sn6GzNJ05qy1iKhuB6mM64-x3FGgvGlMjXbcKx2v7EZKRCgZXxgdNPKas08PYl6EExZN3ZOBNRewi493eH6Uy7jYjb8aPRpikbvaMn8_OwJYIMrlTLtGxODP14kZcR9puOFMNZZWmRKSTUNq-sFNMykpv2bk1INmDFsHJjEFO3o6yLyG0bxaLaoXsuoyMqU3NoQ_wtzYsjO6X-ysMVpeOWfOO0Ahyg_4hIgFYDHKVMT9c__g=w2215-h1661-no?authuser=0
Nice unit
I was struggling to get my system to work with my new phone as it kept looking for the old one so I did a factory reset but now I can hardly get any DAB stations, do I need to update it?
Phone works OK though
device number 5Q0035874C
Hardware H41
Software 0456
Nav database 5L0051236BF
1310
ECE1 2020
Shield 2016-44 (build309)
Any help really appreciated
Hello,
I have a problem with Skoda Connect. It works (both form MySkoda application and browser) , but... every time I start the engine, it delivers me a dialog box with confirmation of the main user. It is very annoying and I cannot get rid of it.
I tried 3 times to reset MIB  to factory setting , erase everything, etc. but no success until now.
Anyone have a solution to this problem? if there is a quick fix, without upgrade the software?
I have Amundsen
Device part 5Q0035864C
Hardware H41
Software 0456
Nav database 5L0051236AH
1030
ECE1 2018/19
SHIELD 2016-44 build 309
Thank you very much!
Hi!
Looking for an update for the following system (what's currently the most up-to-date version number?):
Hardware: H41
Software: 0475
Media codec: 4101.0.0.0
I'm currently unable to connect to any online service on my car, selecting either the "Skoda Connect" or "Online Update" end up getting stuck at the "Online configuration wizard - checking online services, this may take few minutes...". I contacted Skoda and their proposal was to remove the infotainment related fuses for 15mins (plus resetting the infotainment itself by pressing the power-button for 15 seconds). This however this did not solve the problem for me, and this more or less lead to this forum looking for an update to the system if that could fix the issue. Anyone else experienced similar problems, or is there a thread on the forum regarding this I'm unaware of?
I get exactly the same, give up trying now. I imagine ultimately it's not worth the effort in spending a third day scratching my head.
Hi everyone,
I picked up a 2017 Octy vRS a few days ago (to replace my poor old 2006 vRS that was written off when someone pulled out on me 😪).
So far loving it, and starting to not be so upset about losing my old vRS.
However today I had a 'component protection active' notice. It went away after switching ignition on and off a couple of times. Is this something that is a firmware issue?
Current system information:
5Q0035874C
H41
0456
...also, what is 'Shield'?  mine is 2016-44 (build 309)
Hi
there is any chance to have the latest firmware for my 2017 Octavia Scout infotainment unit?
At the moment this is the firmware installed on my unit.
System information
Device part number: 500035874B
Hardware: H30
Software: 0359
Navigation database:
5L0051236CD
7510
ECE AS 2021
SHIELD: SHIELD 2016-03 (build 020)
thanks
5Q0035874A
H24
0241
Any links for newest FW ?
On 22/02/2022 at 04:57, pab567 said:
Nice unit
Device part number: 5Q0035874C
Hardware: H24
Software: 0245
is there any new firmware for it?
thanks, you are super!
All check your PM
Hi pab567,
Device Part Number: 5Q0035840A
Hardware: H25
Software: 0245
Media codec: 2101.0.0.10
Thanks in advance!
I need the actual Ammundsen Software Update Thank you 🙂 (Superb 3)
Hello, please help me with the files needed for firmware update and any other software that is available for my infotainment system on Skoda Octavia 3 Combi. In the gloves compartment i have 2 SD slots. Slot no.1 holds OEM Skoda SD navigation ( i updated this already).
Thank you.
IMG_8774.thumb.JPEG.661e1522c7c9cfed30d2623704b7777b.JPEGIMG_8772.thumb.JPEG.6d6c111ef068d4e2235e5408a0602372.JPEGIMG_8773.thumb.JPEG.43ba7ed9be86d45d2e73e837476e5175.JPEGIMG_8806.thumb.JPEG.e7989e8c264265b2cc896df29054ae8c.JPEGIMG_8805.thumb.JPEG.08343c3a6bd0a51e95a89138a4f811e2.JPEG
