Amundsen MIB2 Firmware Update
1 minute ago, Zidanesaid said:
Perfect!
You will need to use this screen to perform update, file link via PM in next few moments.
  • Replies 4.7k
  • Views 898.7k
Just wondering if my update went well. I can see little changes on the interface. like map (circled) was green previously and now it is always red. Also functions option were horizontal instead of vertical. Is there any options to revert these changes. i like the way there previously.
hi I got the following, my local Skoda dealer does not offer update services, and dont understand why on earth i would like to do that 😞
The dealer attitude is always to NOT update a working system.
Unless you walked in with a specific complaint, and they checked the TPI document and they got a match, they won't do a thing.
Example "Bluetooth is unstable" and upon checking TPI, this is listed as a symptom.
Anyhow, you have MHI2_ER_SKG13_P4526
Version 1440
Will be sent to you in a few moments
On 13/12/2022 at 23:07, varooom said:
We will cross that bridge once you find answer.
I've sent you some pictures via PM, we'll discuss there 🙂
On 14/12/2022 at 11:20, varooom said:
Perfect!
Should I put Y(yes) on section inic and powerc when I update?
I left all the settings alone, it should check version in the car, and then compare version available in update.... and then it chooses Y/N as needed.
So to also make things safe, leave all values alone (as default)
Could you tell me if there is an update for my system?
17 minutes ago, varooom said:
You will want to press the menu/setup button for about 10 seconds to get the software train inside the engineering menu.
Guys,
Anybody who wants to update the MIB2 firmware, do you know that there will be an error B201A00 in your Multimedia (5f) control unit (if you run the diagnostic) and globe sign in the interface will be red with a lock key underneath. Does anyone know how to fix these issues?
Edited by automass
2 minutes ago, automass said:
Guys,
Mine too was red with key symbol even before I updated it.
I think if you can run the diagnostic, you will see the multimedia has fault code.
14 minutes ago, automass said:
Guys,
When you complete the flash process, it would have asked you if you wish to connect a diagnostic session.
Because you don't have the dealer software, you have to press No/Cancel, so the car stores this Software Version Management code, simply because it was not able to talk to the 'mothership' and get the required handshake it needed.
You can fix this with VCDS offline, and read a challenge value, perform a calculation, and then input this.  Afterwards you can clear the fault.
SVM Clearing
This doesn't affect the operation.
Edited by varooom
That's completely normal after a firmware update and is trivial to fix.
You need to grab a value from the "Confirmation of installation change" channel, XOR it with C9D2 then enter the new value :)
OBDeleven example below and you can use http://mib-helper.com/im-so-xory/ for the XOR calculation...
Thanks guys. What about the red globe sign with key underneath. what is that for? previously it was either green or white.
You need to grab a value from the "Confirmation of installation change" channel, XOR it with C9D2 then enter the new value /cdn-cgi/mirage/7ef2a44b785400d29a8fd15a0e4d5fffe2d9913bfac72229cb253167b445d29b/1280/https://www.briskoda.net/forums/uploads/emoticons/emoticon-0100-smile.gif
I didn’t manage to get my value from the "Confirmation of installation change
Is there an updated firmware for my Octavia VRS MK3 MY2018, which has the following hardware/software versions
Part Number: 5Q0035874C
Software: 0471
Train Version: MST2_EU_SK_ZR_P0471T
If yes, please could someone send me a link and some foolproof instructions on how to update it (can it be done via USB ? SD card ?)
(Pictures attached)
It will be some form of online connection, but I don't use, so not sure how you will fix.
16 minutes ago, Moorwen said:
Software: 0471
(Pictures attached)
/cdn-cgi/mirage/7f3a4109b7c9db5275ba0696e58b3cb7d9ae65c743ad6ace706caf7e66e199cc/1280/https://www.briskoda.net/forums/uploads/monthly_2022_12/IMG_20221215_211700.thumb.jpg.3e2dcae59b8d82741527ca6a1dc73cb5.jpg
/cdn-cgi/mirage/7f3a4109b7c9db5275ba0696e58b3cb7d9ae65c743ad6ace706caf7e66e199cc/1280/https://www.briskoda.net/forums/uploads/monthly_2022_12/IMG_20221214_175339.thumb.jpg.7aabda097b7ca62ba74daf906602eede.jpg
I can send 0480, and some destructions with it.
Firmware & instructions worked great ! Took 15 mins or so.
Thanks a lot !
(Used a microSD with a SD card adapter, the USB while it said it detected an update, did not enable the USB option in the engineering menu.)
You might want to add a little more information...
What diagnostic tool are you using and maybe share some screenshots to show what you've tried :)
What diagnostic tool are you using and maybe share some screenshots to show what you've tried /cdn-cgi/mirage/7ef2a44b785400d29a8fd15a0e4d5fffe2d9913bfac72229cb253167b445d29b/1280/https://www.briskoda.net/forums/uploads/emoticons/emoticon-0100-smile.gif
I’ve not plugged it in since I updated it but I use maxidas ds808. However I’m waiting for obdeleven but 10day wait.
To be honest, value doesn't get changed but adaptation should have said Successful. Then this error code will not appear anymore.
