math8888 joined the community
the truth about electric cars
Here in Chelmsford, we had lovely sunshine right the way through it all, not a cloud in the sky.
Retro Side Assistent
Die Steuergeräte sind komplett, der Kabelbaum auch. Der erste Außenspiegel komplett zerlegt Die anderen Teile für OEM Retrofit in den Außenspiegel sind im Zulauf. Gestern habe ich am Tisch die Steuergeräte aufgebaut. Firmware sauber neu geflasht auf beiden und einen für mich vermutlich passenden Datensatz aufgespielt. Der Octavia 3 hatte nie die 2Q0 Steuergeräte verbaut, dadurch gibt es keinen originalen 2Q0 Datensatz dafür. The control units are complete, as is the wiring harness. The first exterior mirror is completely disassembled. The other parts for the OEM retrofit in the exterior mirrors are on their way. Yesterday, I assembled the control units on the workbench. I cleanly reflashed the firmware on both and installed what I believe to be a suitable data set. The Octavia 3 never had the 2Q0 control units installed, so there is no original 2Q0 data set for it.
Skoda Yéti (2015 Manufacture Date) Infotainment Latest Firmware
Take Firmware 253
Cairus started following Skoda Yéti (2015 Manufacture Date) Infotainment Latest Firmware
- Yesterday
vRS Owners, cars with a VAQ front diff, a question on the servicing and what you are being told at Skoda Main Dealerships?
Officially, in the UK, it is 30,000 miles or 3 years - whatever arrives sooner. This isn’t the thread I was thinking of @Evolution13 - I might have a dig for it. It wasn’t this old, and there was definitely an argument of some sort 😂 I do remember grabbing screenshots and quotes from various places.
I tried to use less than normal but I use very little in daytime as I am mainly using solar. App says it is calculating so don't know if I am judged as using less, presumabky find out tomorrow or Saturday. On Agile Saturdays half hours are predicted to be about 11p per kwh whereas Sunday is close to 20p per kwh so an hour of zero cost leckybwould be welcome. Here in Worcester eclipse was covered by dark cloud. It got dark early ie from about 7 pm and did not recover until morning sunrise. Bit of a loss of solar generation but I don't count on much after 1900 BST / 1800 GMT anyways when one is nearly 2 months from the summer solstice.
Rim protection 18" Gemini vrs alloys
I have the PS5s on the car now - I can’t say the carcass appears to be any different to the PS4s they replaced. I think I had Rimblades on my first car, but I haven’t kerbed a wheel since I was learning to drive. I’d rather spend the extra time parking, even if I look like a fool, than chunk my tyre or wheel. Not practical advice in this instance, though. The Gemini has a very proud outer lip - I think it looks quite good, but it is more vulnerable to damage. Nothing is going to protect it from being clobbered. I do think something like Rimblades will help but, as @vRSAnt says, they aren’t miracle workers - they do also need to be applied properly to a smooth, fresh surface. I can’t imagine they’ll adhere well to a chunked alloy. I suppose you could put a 235 on there? That is on the limit, though.
Final Drive Service?
5E is the model code for the Mk3, while NX is for the Mk4 (MQB Evo) variant. The reason you’re seeing the two for 2020 is that there was a crossover in generations. OPs car, like mine, is a MY2019 car, registered in 2020. For all intents and purposes, stick 2019 into parts finders and the like. IIRC both cars have the same differential, but the Mk4 adds the Vehicle Dynamics Manager in the mix - slightly different part numbers and slightly different software (control, calibration, etc), I would imagine. I can’t see the physical parts being much/any different. Someone else will know more. As far as OP is concerned, just let the guys use whatever. IIRC they only use VW kits for the differential stuff (but can use Millers for other stuff, if you don’t want Castrol).
Rimblades I think are a total waste of time. Expensive and then when it comes to a smack don't REALLY save the wheel from opinions I've seen and then trap crap behind them which spoils them anyway -but I've never actually bothered to own any to give a first hand verdict, just what I heard. Just refurbed mine before and then more careful ( and wife doesn't want to drive it anyway!) plus rim prot. You can definitely get a bit of rim protection with some tyres like one I mentioned. It wasn't Gemini tho it was the L+K mirror polished style octy ones on with the Conti's just fitted, same tyre size as vRS tho. Goodyear eagle f1 definitely offer a bit of rim protection. Contis about the same (LK alloy) a fair chunk of rubber at least . Uniroyals, somewhat considerably less if at all anything ( my back tyres )
TalatCan joined the community
BradleyRushforth joined the community
Karoq Instrument Panel & Servicing Generally
Brake pad wear and therefore lifespan is very much a function of driving style and journey types. I personally find that garages always under estimate how long they will last; partially because they have to err on the side of safety - although this is open to looking like generating extra revenue. I usually change front pads at 72,000 miles, never had rear pads changed even after 162,000 miles in a previous car.
thamestrader started following Karoq Instrument Panel & Servicing Generally
rje99 joined the community
Slugish up slight incline
I was having random misfire without any warning on the cluster even vcds didn’t show anything, after replacing ignition lead (for the updated one with the heat shield around each ignition lead) and the spark plugs the misfire was still present after replacing the ignition coil the misfire went away, from the outside it wasn’t presenting anything wrong so if is still the original try to replace it
Jack25 started following Slugish up slight incline
Glowplug prices - having a laugh
I just noticed pim (link above) are also doing 10% off with code HEAT10. £86 is pretty good from a reputable supplier.
ECP prices for parts, I've found that at least for some parts, you should check the Halfords price, I don't have anything other than the free "motoring" membership, and many times I've found Halfords to be much cheaper than ECP - which is where Halfords use to supply their ordered car parts. Maybe not in this case though, but always worth checking before placing an order. Edit:- not many places tend to match or beat PIM for genuine OEM parts - plus very fast despatch/delivery.
I've just remembered that the "safety data ref" on the labelling of both these products are different, so must be a significant "chemical makeup" between them.
It definitely isn’t every 2 years in NZ. I want to say 45,000km but don’t quote me. I have the prepaid servicing for 5 years. It’s included in that but not in the 3 year one from memory
Just replaced cylinder 4 with a £13 Bosch 0250403009 direct from Amazon. It was a Bosch 0250403007 that came out. Looks like Beru (another OEM) go for around £100 on ebay for the pressure sensing one. Bosch seem to be around £135. I find ECP expensive these days, even with an essential code/deal. https://www.ebay.co.uk/itm/336472172965 Bosch seem to be around £135, but I see a full mixed set for £140: https://www.ebay.co.uk/itm/286741811628 I soaked it in wd40 for a few days then got the engine to temp at removal. I might just have been lucky, but once it cracked, it was finger tight.
8755 Software Update - Skoda Fabia 2019 Carplay Issue
FYI: If you're updating a MEN2 unit and the firmware SD card is being rejected with an "SD/card reader error", try starting the update from the extended setup/service menu instead of using the normal "Update software" option under Setup. On my 2019 Skoda Fabia with MEN2_EU_SKGPx_P7381L / MU 8740 / HW 690, the SD card worked perfectly for playing MP3 files, but the normal software update menu kept reporting an SD/card reader error. The solution was to press and hold the SETUP button for about 5 seconds to enter the extended setup menu and start the firmware update from there. The exact same SD card and firmware files were then detected correctly, and the update to MEN2_EU_SKGPx_P0080L / MU 8755 completed successfully. The update also appears to have fixed my CarPlay audio crackling/distortion, which previously started after about 30–40 seconds of playback. Hopefully this saves someone else from repeatedly reformatting SD cards or assuming their card reader is faulty.
Silencing the loud spoken traffic congestion warnings
I believe traffication is subscription service, free for first year. If I recall correctly I think it cost £4.50 per year and you pay for it through the ŠKODA app. Look under PROFILE -> PAID SERVICES
- Codes 00883 and 00668 Octavia 2007
Jonnytange joined the community
Skoda Superb iV - Factory paint thickness specifications / tolerances?
- Adblu reducdant sensor
Search for adblue delete. Not sure where in the country you are but this was the first hit on google. Not a recommendation. Skoda AdBlue Delete | NOx Delete | SCR Delete | LeicesterSkoda Adblue Removal Specialist in Leicester. We offer custom Adblue / NOx / SCR Delete Services for Skoda Octavia, Fabia, Yeti, Rapid and others. P20EE, P20E8 When I bought mine it had already been done.- Radio change incompatibility
00883 is I think is an ignition switch problem. it could be the switch behind the barrel that has failed. Read that there is part of the switch that senses when key is in ignition that is prone to failing. It could also be loose bad connection at switch. Check the fuses near battery for corrosion/loosness as well. AlasdairAlasdair1 started following Codes 00883 and 00668 Octavia 2007- Adblu reducdant sensor
Thanks for the tip but how do I go about doing that?- Final Drive Service?
I guess I'll let the experts work it out when I take it to them thanks for all the advice.- Hi all: Is anyone able to do a VAG Service history report for me please (Skoda Superb 3)?
PM'ed to you. Thanks. AG Falco - Adblu reducdant sensor
