Digital Cockpit Display Error
Your automotive controller is no longer synchronizing with the graphics controller, which indicates a timeout issue. Updating or reflashing the same firmware might help. Otherwise, buy a used unit and find someone who can perform a full backup of the automotive controller, transfer the data to the replacement unit, and adjust the mileage.
Cairus started following Digital Cockpit Display Error
infotainment system upgrade
You might want to tell which infotainment system is installed in your car. Perhaps you could also say which model year your Fabia is from?
Eric_DK started following infotainment system upgrade
the truth about electric cars
GevaarlijkeGek joined the community
Change octavia 2024 g-tec standard skin for vrs skin vcds 25.3
Thanks for listening, My octavia 2025 g-tec is not facelift version due to the headlights (I think facelift has SFD2) and I would like my digital cockpit to show the gas range. I tried change skins with vcds 25.3.1 but I couldn't find the vRS skin, I think i need unlock SFD due to VCDID code, see image attached. When going to 17 Instruments > Adaptation and typing "view" into the filter, I activated several views -such as 4, 7, 8, and 9- but I was only able to see a new skin by activating "view 8." I tried typing "Display depiction" into the filter, but whenever I attempt to activate any variant (Variant 1, Variant 2, etc.), it asks for a security code. Do you think this security code implies that I need to purchase an SFD token or is possible unlock security code writing a code in 17 Instruments > 16 Security Access ? Do you know how can I get the vRS skin in my CNG 2024 Octavia?
tton started following Change octavia 2024 g-tec standard skin for vrs skin vcds 25.3
danidani joined the community
Skoda Octavia MK3 Greenline III (1.6 TDI) - cambelt interval
Hi all, Just wondering what the cambelt interval on a 1.6 Greenline III is. I’m seeing conflicting information online. I’ve just bought my old Octavia back and the belt was done before I originally bought it in 2020 at 90,000ish miles. The car has now done 140,000 miles so I’m guessing it’s overdue? It’s been owned by a family member so I know the car hasn’t had the belt done during their ownership. Looking to get it booked in if it is actually due, but just wanted to make sure it definitely is before I shell out. Also what’s the going rate for a cambelt & water pump change at an indie currently?
Toby7243 started following Skoda Octavia MK3 Greenline III (1.6 TDI) - cambelt interval
Amundsen MIB2 Firmware Update
Hello, I feel I am late to the party and haven't updated my firmware since 2017. I believe I am after MST2_EU_SK_ZR_P0480T - (currently on P0468T). Can someone help point me to where I might find it? Thank you.
Rocketeer125 started following Amundsen MIB2 Firmware Update
CD PLAYER
Does the SD card fit in the extra slot in the glovebox unit? I'm a bit of a Luddite when it comes to electonickery, give me an engine to work on any day! Thanks, that looks the very dab.
CD PLAYER
Something like this means you can rip your CDs easily. https://amzn.eu/d/0iICC1YP
- Engine cover
thelee79 joined the community
- 38 mph in 5th gear ?
Skoda News
https://www.skoda-storyboard.com/en/skoda-world/what-was-racing-like-half-a-century-ago-skoda-120-s-rallye-delights-a-champion/
Engine cover
Top Cowling 1.2HTP Škoda 03E103929A ? Need VIN to check properly, but that's what comes up for 2012 CGPA engine. Maybe it had something non-original on it before, if that doesn't look like what you expect. I will message you to ask for VIN. Dirt on the outside of the engine doesn't matter, clean oil inside is much more important
- Engine cover
CD PLAYER
Thanks Dave, that's what I was afraid might be the answer. The problem I have is that my new DELL laptop doesn't have a CD/DVD player built in so unless I can find an inexpensive CD player to plug in, I am stuck with what I have.
- Engine cover
Tomas525 joined the community
- Engine cover
Miastubb started following Engine cover
- Elroq tailgate won't stay closed
Fuel Leak!
Has anyone managed to get a goodwill payment for this fault? My Leon 1.4TSI broke down a couple of weeks ago, fuel leak from the fuel rail, 1 bolt ‘missing’ and others loose. 3rd party warranty would not pay out because it was a bolt issue and bolts aren’t covered!
Shamblerc started following Fuel Leak!
Shamblerc joined the community
Miastubb joined the community
1.9 TDi Timing belt kits
Found similar in cluch kits Bought an LUK kit and it had a valeo clutch disc. I would have thought that as INA are a premium bearing manufacturer they would use their own unless they also now make them for Gates and you got one branded for Gates . Reckon a lot of companies supply each other with parts and are rebranded to suit Alasdair
Chinese rear differential
As with everything, if you know what you’re buying, you’re probably going to get a great deal. If you don’t, then sometimes it’s best to err on the side of caution. As said, the same factory can product different qualities (and, often, you’ll find that the lower quality items end up as different brands - take Hisense and LG, for example). @Cairus I meant to tag you, but clearly don’t seem to have managed it!
CD PLAYER
Been asked several times on here, answer is always the same - this generation of infotainment systems doesn't support a CD player or changer. You need to rip your CDs and copy the MP3 files onto an SD card.
LewisADJ started following Digital Cockpit Display Error
I have a digital cockpit display in my Kodiaq. Part number 565 920 790 C It’s recently turned off mid journey and only comes back on intermittently. There’s not actually anything wrong with the display, it just won’t stay on. It’s just the screen too, the petrol and temp lights are fine, as are the warning symbols. I’m just left with a blank screen and a red warning light. After an extensive search the only solutions for a fix I’ve found are to pull fuse 17, disconnect the battery and reset the infotainment system. All 3 of those haven’t worked. I took it for a VCDS scan which showed a fault (see attached image). Has anyone else had this issue? It’s booked in to have the software / firmware updated this week as a last resort before I have to look at replacing (£2500+) Any advice appreciated
CD PLAYER
Bump to this question.
