  2. Car is my2020 Nov Battery is 2 weeks old
  3. My 2014 Skoda Fabia will sometimes just crank and not start. If I stop and try again, it usually fires up straight away on the second attempt. It's showing fault code P034100 - Camshaft Position Sensor Circuit Range/Performance, but the timing chain is fine. I've replaced both the camshaft and crankshaft position sensors multiple times, yet the fault keeps returning. The car has also just come back from an auto electrician, who checked all the wiring and confirmed everything is ok and they also they repaired the ecu. Given that the timing chain, sensors, wiring, and ECU have all been checked or replaced, does anyone have any ideas what could be causing the intermittent no-start issue where it only cranks on the first attempt but starts immediately on the second?
  4. Came accross this breaker a while back. They may have something. https://www.trents.co.uk/?gad_source=1&gad_campaignid=23663397992&gbraid=0AAAAADtNLyIBdjzSxEPPw_nyaFnMk4zS_&gclid=CjwKCAiAn4XYBhA-EiwA8176FXmpIF9eo9ch8sgMYKxKD_Cu4lzjo2wrPGh_ejXJBhGGbGl270oeBRoCLdEQAvD_BwE#/ Few on ebay but Europe mainly. Alasdair
  5. Hi everyone, I have a Škoda Octavia 3 1.6 TDI with MIB2 Standard (Bolero, SD card update) and I would like to update the infotainment to the latest official firmware, MST2_EU_SK_ZR_P0369T. Unfortunately mibsolution.one is down and I can't find the package anywhere. My unit details: Part number: 5Q0035840B Hardware: H30 Software train: MST2_EU_SK_ZR_P0363T MU version: 0363 Software version: H28.28.185_STD2Plus_EU Media codec: 3141.0.0.1 I'm looking for the original firmware package (not a patch), to install via SD card with the standard update procedure. Could someone please share a download link, or send it by PM? I'd also appreciate any advice on whether going from 0363 to 0369 directly is fine on this hardware. Thanks a lot in advance!
  6. SimoneG joined the community
  7. Today
  8. I kept editing my above post as my thoughts developed, may be worth another look.
  9. Thanks both Mmm so i have a couple of possibilities in bcm or led. I don’t have an obd device to do a lamp output test. Is there another way to test if the led actually works?
  10. Possibly, yes.; but I'd imagine that the BCM is the LIN master device, and the alternator and battery monitor control unit both slave devices. Where the voltage is measured to trigger the warning light I don't know. In 'dumb' alternators it is definitely within the BCM, but it could be within the alternator with smart charging capabilities, or most logically perhaps, within the battery monitor control unit. What year is the car and how old is the current battery? LEDs used as indicators (very low power), as opposed to illuminators (higher power), very rarely fail.
  11. Funnily enough, an advertisement for a 7kw diesel generator for about A$1100 about a week before the disaster caught my eye and thinking it could be a useful sort of thing to have around. As it is I have a small 2.4kw gen for the freezer if power goes down for any length of time. Only used it twice in 5 years but it only cost $200.
  12. Not impossible for a led to fail - or a faulty track on the cluster.
  13. So, as the alternator appears to be working, does this indicate a problem on the bcm? A dud led for the battery light is unlikely isn’t it?
  14. And for touring coaches. Went on a Leger Holidays coach trip to Italy this summer and chatting to the driver about all sorts (remember I used to own a 1950 ex-LT country bus!), he told me the oil had never been changed in 450,000 miles; just checked and topped up (if necessary) at its annual safety check..... Transmission oil doesn't get checked!
  15. Battery is new as a result of these lights and car has not been widely used since. @12.5v with nothing operating.
  16. I don't suppose you've got room to chuck a 5KW genny in the back😁 Oops, missed the PHEV bit!
  17. Apart from the missing 'battery' indicator, the common cause of the others is either low battery SOC - or failing ABS wheel sensor. What voltage readings are you seeing at the battery terminals?
  18. This is fantastic, thanks. There is 1 wire from the 4 way connector and I didn’t notice a splice. I’ll have another look. The bcm is not the same as the ecu is it? Do you know where is may be physically situated?
  19. mumpsim replied to ian-inhome's topic in Skoda Karoq
    This page sets out the scope of the information that can be made available via a smart home app or any other app provided its developer does the necessary work: https://public.api.connect.skoda-auto.cz/docs
  20. Are there two green/yellow wires emerging from pin 1 of that 4-way connector you've called 'engine block plug'? If not, I guess that splice - B549 - where the one green/yellow wire becomes two must be wrapped in the loom somewhere.
  21. Circuit info for the alternator warning lamp (K2) just shows it driven by CAN info from BCM rather than showing actual electrical connectivity. So not hardware linked to alternator.
  22. Good afternoon. Am currently on 89k, chain is at -3.6 degrees via OBDELEVEN. Am thinking of getting it done, preventative only, car runs perfectly. Had a quote for £996 inc vat, without a new cam bridge. Charmers Inverness provided the quote. Anyone used them before? Cheers Graham.
  23. Yeah, my bad. I started to type that in my first post earlier but then was struck by doubt. There is just the one, LIN bus control wire. Alternator right at bottom of this page. BCM right at the top. LIN data comms wire comes from alternator in blue, changes colour at 4-way connector pair to green/yellow then splits off to battery monitor control unit and BCM (Brown 46-way connector pin 26). Green dashed line shows the omitted connectivity between the two boxes labelled 18.
  24. REZT joined the community
  25. Vcp is vag can pro. Pretty sure it uses its own dongle and pc software. Like £300+. If you want to do it you’re better off finding someone with the tool and paying for it to be done.
  26. We have had to defer a long trip with the new car, planned for the coming week, due to violent storms cutting electricity to the area we were to visit. So, I'll wait until we have actually covered some distance before offering any opinions, other than so far we like it. Sounds dumb (probably is) but I have had to do some online research to find out some of the technical details of what we have bought. A lot of it is quite a new experience for me. The 1.4tsi in our 2014 Octavia was a relatively simple 4 cylinder turbo, but gave excellent fuel economy, and/or performance and yet was smoother than most other engines I have driven. I still love it. The 1.5tsi in the Kodiak builds on that and adds Active Cylinder Deactivation (yes, I know some applications of the 1.4tsi had ACT too), the 'remaining active cylinders' can oscillate between Miller and Otto cycles as befits power/economy demands, and a variable blade geometry turbo is fitted. Numerous other changes but I hope they have also upgraded the plastic water pumps that are prone to failure in the earlier models. From what I read in this forum, something that seems important to owning an 'electric' car is the Skoda Connect App. Unfortunately, this is not available in Australia and in fact the equivalent is not on any VAG group car here either. I have just read that Audi are soon to release their version here so hope that the lessons from that are passed onto other members of the group so we can eventually get Skoda Connect 🤞. Remarkably, the Kodiaq iV has a better drag coefficient (0.29) than my 'sleek' mk3 Octavia wagon/estate/combi (0.31) although the frontal area is much larger on the Kodiaq so the total drag will be higher, but still it surprised me. The big difference between the mk3 Octavia and the Kodiaq is the 400kg or so extra bulk of the Kodiaq and that is going to have an effect on handling and economy. More revelations of my ignorance of the technology and my insights into the Australian electrical infrastructure and recharging facilities and costs to come.
  27. Also Does the vcp comes with the own app or I can use car scanner pro app ( paid full version) ? Thank you
  28. There’s only 1 wire from the alternator connector - blue one. Goes to green/yellow from the engine block plug
