  2. @26DIPP The beauty of the UK is that Home Deliveries or the Postie gets through and if not the roads are closed. & it used to be that when Snow Gates were closed 4s4s were allowed through. Those days are over because Police Scotland often have un-suitable vehicles / inappropriate tyres. Snow socks can be just the job for getting out of an icy parking place when inappropriate tyres are fitted. I carry a set just for the use of others that do not prepare for winter conditions.
  3. Hi, My daughter has lived and worked in the french alps for a few winters and throwing chains on takes her less than 5 minutes in thick snow - they had competitions as you do..... She has had the chains on for a week at a time when there was still thick snow in steep terrain. Driving a Superb I have seen threads where people have fitted snow chains to 18" and 19" tyres. You always hope that you do not need them, but I still "practice" to fit mine and sometimes the roads are not cleared as quick as you hope when there is more than 24 hours worth of snow fall. They just cannot clear all the roads at the same time.
  4. Just so you are aware it is probably also worth checking whether any newer vehicles can have a shortcut added to the settings profiles. I've had Peugeot and Nissan hire cars recently that have had this such that one press on a button switched off a number of these mandatory settings.
  5. I tend to use suggested presets in Lightroom to process my images most of which tend to be over processed. Spent a bit of time on the train shot hopefully being a bit more restrained. I’ve also posted the original shot as a comparison. I underexposed the original shot to avoid burning out the sky, then pulling back the detail and shadows when processing. Hope this gives an insight to those interested. I couldn’t resist “tidying up the clouds too. 🤣
  6. They were just a glamour couple doing a little vid for clicks and money. That will be the last i click on to them. Like the dude said, he spent more than £5 for a coffee.(& bought rather expensive petrol @£2.00 a litre.) That is very much the thing. Some people know the cost of everything and the value of nothing. I bought 2 X 200 grams of Tesco De-cafe yesterday with my Club Card Personal prices for £4.90 and got 55 pence discount. I reckon that is about enough for the next 3,000 miles worth of when i am filling a flask.
  7. Hi everyone, I’m looking for some advice. I have a Columbus RNS-510 radio and am experiencing the following issue: If I connect the radio via the CANbus connector, it starts up normally using the power button; however, if I turn off the car using the key, I can't turn the radio back on with the button the next day. I have to disconnect and reconnect the CANbus connector, and then the radio works again for a while. I was recommended a firmware update by "josi"—which automatically includes a Gateway fix. Could someone please confirm if this is the case? Also, does anyone happen to have this firmware? I’m attaching a photo of the radio's label. Skoda Octavia II 2008 Laurin a Klement. Thanks a lot, David.
  8. dejvic started following Firmware 6276 source
  9. An ice car running out of fuel can do damage to the fuel system with pump cavitation etc. Expect they did the ice car from fuel light coming on, put in the £5 of fuel and then recorded when fuel light came on. 40 miles was quite good but that was but that was sweltering with no aircon as I struggle to think of any ICE car with a heat pump. Even my £20k Renault 5 has a heat pump and running with aircon hardly affects the range it seems to me. Still to test my 40 / 43 kwh R5 past 0% SoC to compare to Bjorn Nyland getting 46 kms in the 52 / 55 kwh R5.
  10. @PWX01 Are you in the UK or elsewhere in Europe? As far as i am concerned, i pretty much like the KISS and pre 2024 first registered cars in the UK. But not all 2024 on are a PITA and in need of switching off or disabling compulsory features. Best thing to do IMO is test drive what it is you plan on buying, and do not assume a near identical vehicle will function or have the identical functions / features.
  11. dejvic joined the community
  12. Thanks for all th suggestions, sorry for late reply, tried soft reset to no avail so did factory reset which worked a treat. After watching him change things again I worked out it was the privacy setting. Once he turned it to private it disappeared again and although I changed it back again neither a soft reset or switching on and off again bought it back. So another factory reset and we are good to go lol. Thanks again for all of your help it was much appreciated.
  13. Think the older skodas were painted better. As said my sons mk1 fabia paintwork and underside is pretty good for a 55plate but both my newer octavias are rusty. Old one under rear and sills/wings plus middle of drivers door panel and newer 1.6tdi under rear,sills,front wings and estate boot lid around nplate and nplate lights. Alasdair
  14. Not so breaking news. Someone who can charge a BEV @ 6.5 pence a kWh can go the same distance as someone paying 65 pence a kWh and for a 10th of the cost. Just have access to a property with a charger and cheap tariff electricity and you are onto a sure fire winner as far as the economics.
  15. T4L4 joined the community
  16. I doubt that for the Video that the ICE Citroen was ever run to empty or the tank drained then £5 worth of petrol added, but hey hoe it is show business and there is no business like show business and vloggers / Image creation.
  17. Today
  18. I reckon that using chains is a "last gasp" activity, involving getting numb fingers and hands, using lots of time to fit, then finding somewhere to pull over and remove when conditions dictate that. I've only ever used snow chains on one car, a 1979 Ford Escort 1.6 Ghia and they were used with "normal tyres" - they served their purpose, but I never ever bought new ones for later cars. Winter tyres on "one size down" tends to be the smart solution for people that think that they might end up in trouble, or want to attempt to stay in control - typically if you need to resort to using snow chains, your probably attempting to drive on unploughed snow covered roads, and eventually the underside of the car is going to make contact with the snow and so slow you down or stop you, and now you've blocked the road for snow clearing teams and emergency vehicles. Would Snocks ie snow socks not be a better idea?
  19. I charge on a Gridserve charger on Thursday. Think it was about 87p per kwh. Had done 200 miles from Worcester to Dartmoor and was just getting a part charge to get me back to Worcester. Yes expensive compared to other chargers but very good site, good cgarging speed of about 100 KW, went from 25% to 90% in half an hour, M&S on site, still waiting to see the bill, Gridserve took a tenner deposit and still waiting 4 days later for the actual amount to appear which should be a £35. I have been ripping up petrol receipts over 5 years old and rarely are they for less than £50 and that is for Fabias and Octavias and they have quite small tanks. Running EVs is saving me and the family hundreds of pounds a montn I reckon.
  20. So they got 4 times the range and they 'might' be able to get the charge costs down to a quarter meaning it would be even Stevens... Anything less and the EV would be more expensive.
  21. Ah... Only a BSc... That explains it (as you might have said) 🤣
  22. Doing this will only be a first look at the system especially while it is running under load, you should be able to check for typical running (high side) pressure for the fridge gas in your system, online - ambient temperature dependent.
  23. Is it a tariff when they pay you? So many ways both with home and public charges to get the headline costs to half, third, quarter or less, something one cannot do with fossil fuels. Not rocket science, just a little planning with great financial rewards. More money to spend on other things.
  24. They should do it again starting at a Gridserve or Applegreen charger
  25. I used to have a dog that would lock the back doors, when they had a button to push down
  26. You can read AC system pressure with OBD eleven, I did it last week to confirm I have a partially depleted system.
  27. Indeed but only for those with home chargers and the right tariff. Those public charger costs you mentioned would have evened thing up and possibly even swung the answer the other way.
  28. See my answer above. Could have been done much cheaper the Inogen Bhogal (BSc Hons) quoted ie free or even got paid £5 for what she used if on an even better Octopus tariff !
  29. You mention one side of the coin but there are plenty of other factors on the other side of the coin. More homes, those without drives, are getting approval to have cable channels through the pavement and the install grant has now been upped to £500 from £350 I gather.... https://www.birminghammail.co.uk/motoring/motoring-news/uk-households-without-driveways-handed-34073227 You may be a bit more limited in low population density areas like Northern Scotland but there are plenty of Public charging places where you can charge for less 65p a KWh. MFG are currently doing 59p per Kwh for the next 2 months, BE.EV is oft at 49p a KWh, sadly Southern Scotland is a close as they get to Northern Scotland, TESLA BRUM are charging 23p a KWh for much of the time at Frankley, M5 J3 Brum. The 3p a mile, when it comes in in 20 months time, looks like it will not be onerous. if one under estimates the mileage one does and only catches up when the annual reporting is done, has the money in a savings count to cover when due, pays on a credit card as some government sites allow and get some kick back. definitely get me to check my tyres more to check inflation and replace at 3mm tread to maximise rolling radius. Also, as I mentioned before, I and I suspect other EVs will choose the shorter routes through villages and towns to bring down the mileage rather than go the slightly quicker long way way round on the A roads and motorways. I think the mileage policy could backfire badly. Imogen Bhogal, BSC Hons, charged on a Octopus GO or IOG tariff it looks like so the 52 KWh R5 battery could be charged for a £5. I charge our R5, Scenic and Mini on the cheapest going rate on Octopus Agile which is sometimes, oft this summer, less than the Octopus GO or IOG, rate, sometimes about 5p a KWH, sometime about zero P per KWh and sometimes as low as minus 10 p per KWh so the Lincoln to Exeter I would have been paid £5 for the electricity used in that journey. Balcony / Plug in solar, especially when linked to upcoming home batteries, from Octopus-CATL, can mean most doing some charging from solar via home batteries. looking forward to the zero rating of home electricity in 58 days but frightened just much diesel, gas and petrol will cost and effect cost of living. Need to look more in to Heat Pump.
  30. No surprise there given ait was effectively a rigged test using cheap overnight charging compared to full cost liquid fuel. And ONLY achievable in that scenario.
