  2. I have the same issue. I'm living with it for now, but it's not ideal.
  3. Im not to sure i had to bring the car to a skoda main dealer to flash the long code off there diagnostics and they also changed the brake fluid as they were working on the abs module but got the issue sorted.
  4. Today
  5. Radoxx joined the community
  6. Change/Edit Car Immo Data
  7. I think you'd struggle to get part-worn linglongs for £100 all round!
  8. I've spent over £1000 with these guys over the last few years (replacement caliper, washer motor, suspension parts, steering parts, trim pieces, body pieces, wheel bolts and endless little bits). They are all 100% genuine, and come well-packaged in the original VW bags/boxes. Absolutely top service, every time. If you ever need help, before or after an order, email [email protected] and ask for Jan - he's their UK representative. VAT is included. There are no import fees (I've ordered in excess of £400 for a single delivery). Unless I'm in an insane hurry for parts, I always use these guys. The only issue I've ever had was on a recent order, where FedEx farmed out local delivery to InPost, for some reason. The order arrived a day later, without issue - and, of course, it's not Skoda-Parts' fault.
  9. Yesterday
  10. As soon as you drive the car it will sense that it needs to put back into the battery the energy used for starting. That is normal but more noticable in cold weather as the battery capacity is less.
  11. From @andyvee in the MK3 adaptations, tried and tested thread: "Changing the number of flashes of the comfort (lane change) indicator Controller 09 - Central Electronics 16 - Security Access - enter 31347 10 - Adaptations (2)-Turn signal control-Komfortblinken Blinkzyklen - change the value from the default of 3. I think the range is 2-5. [screenshot to follow] Edit: You may need to set your lights back to factory default in the infotainment unit before this change takes effect Edited 12 yr by andyvee" This worked perfectly on mine, thanks @andyvee .. as you suggested I had to do factory settings in the infotainment menu. Then a few days ago I did the thing that brings on rear lights (two bulbs each side, anyway) with DRLs, something that really all cars should have been set up for imho. That adaptation worked great, but the flash number retuned to 3. Looking in VCDS the setting of 4 was still there but the actual flashes only numbered 3. Another factory settings reset and it's back to 4, now with rear lights on with DRLs. Excellent! I saw there's an option to have clocks lit up or not with the DRLs, I went for not lit in order to save confusion: clock lights are only on when 'proper' lights are shining. Onwards and upwards! 🙂
  12. Yea, I got one from an s3 Audi after a few months looking around. part nos matched
  13. I change the module.. And found this..
  14. Nope, still not sorted. I pushed the pin down but it barely spreads the prongs. It still just falls out, genuine Skoda part as well. I’m thinking there’s something underneath it clips into.
  15. Hi, I've got the same problem with my 2014 MK3 Tour De France. And yes, it is proving very difficult to find a replacement. Although I have been quoted £7500 to repair 🤯🤯🤯 My garage said cheaper/easier to get a 'new' axle with haldex already fitted and swap it over. Did you find a solution to the problem?
  16. Mark1974 started following Haldex versions
  17. The time arrived for the ‘proper test drive’ I alluded to a couple of posts ago. I was, as expected, properly nervous at the prospect of the Caddy letting me down again. Worst case scenario I would find myself stuck in traffic in a dead pick-up that still had an undiagnosed fault. That scenario would likely lead to the Caddy being left broken on the driveway for a period whilst it awaited the rekindling of my enthusiasm. I had so little faith that I even considered asking my son to follow me in his car, but eventually I put my big boy pants on and set off unchaperoned. Caution was not thrown entirely to the wind, however, as I drove in ever-increasing circles centred on my house, and avoiding all roads where a breakdown would leave me with no scope to get myself out of the way. The target for the test was 30 miles, involving a cautious start and a gradual increase in speed and boost. It ran faultlessly. After 20 miles I was relaxing into the likelihood of success, and I started to enjoy the drive. Although I can claim mission accomplished, I will not be so bold as to re-wrap the ECU looms just yet. The plan is now to use the Caddy for a bit, and if it continues to demonstrate reliability then I will either re-wrap the looms, or embark on the next stage of under-bonnet electrical housekeeping.
  18. can you get the long code with only the vin number??
  19. Match pp62d dsp with they sub isnt bad. ive got the pp62 for speakers and use the rca from there to a Ml Power amp 2 pcs mps300 s4. of curse i have ground and +
  20. AGFalco replied to Nimrod2's topic in Škoda Kamiq
    Week not Month. Look for 4 blocks of numbers/letters starting DOT xxxx xxxx #### Thanks. AG Falco
  21. AGFalco started following Model help
  22. 2023 2.0 TDI what are the common symptoms on these cars? It has done extremely high miles as well.
  23. Has anyone fitted a Rieger diffuser? I know there are several posts on them, but most of the posters haven’t been around in a few years.
  24. truck's birthday evidently came around..
  25. I'm a bit late to the party here but are you sure it's the servo? I remember not long after I got my mk1 the vacuum hose that's connected to the servo had split which resulted in a complete loss of servo assistance.
  26. My Karoq is out of warranty for about a month now. Been holding out hoping for an All In offer but doesn't look like it's happening - just keep seeing adverts saying service plan prices have been frozen for the rest of the year 😒
  27. JXR started following All in servicing
  28. Actually €120 off, from €860 (including mounting and balancing of the 4 wheels). It's ~€190-195 each before the bargain, so ~160-165€ each in the end (without mounting etc.).
  29. Probably yes, cuz UK is not in EU anymore 😕 Okay i will keep diggin 😎
  30. I did consider it but I am not certain of how the dimming function works as if is a top layer on the glass it could get damaged. Didn’t want to risk it having sourced the mirror WITH dimming/heated glass for less than £50!
  31. Didn't you think to scrap the mirror with a razor blade (of course with slow movements, to avoid bouncing into the plastic trim all around) ? Very efficient on our induction cooktop and never scratched it...
  32. Texter joined the community
  33. Another diagnostic tool to add to your collection? What can this one do that your others can’t?
