  2. Sorry for the late reply! but thank you for your responses Well that's good, seeing some prices online estimate £600-£1500 for a clutch replacement! I'm glad I have time to save up for when it comes around I would have hoped that the VAG specialists would have had a look at that when they inspected it, they did notice that one of the wheels wasn't tightened on properly and I've not been up to 70mph since so I should probably do that to see if its still there. Still, there is a local Kwik Fit that I could ring up and see if they would check the balancing How would I go about checking this? Aha it feels bigger in person, especially on a sunny day. I know its just a cosmetic thing but it would be nice to have it smooth additionally one of the guys I went to offered to give me the remaining bits of the paint mix and dab on the rusty bonnet spots with a cocktail stick. Mechanical fixes are always going to be a priority over it though. Something I didn't even consider!
  3. This headliths calibration can be done using Obd11 or vscd as I posted earlier. That's what I've been told and lad seems to know what he is doing, he's been coding successfully VAG cars for years. Would be helpful if someone more experienced from our forum confirm that it has been done and worked too. Cheers
  4. Today
  5. thanks all for the comments... No idea if it has any factory 'towing prep' apart from stating GVM and towing values. Seems that I can get the euro style towbars that remove/rotate/hide as well as the hayman reese style with the square hitch - which is pretty much the local default, like https://haymanreese.com.au/products/towbar-to-suit-skoda-octavia-11-2013-on-03386rw Yes its a single axle, 5.5m trailer yacht. Is there a transmission temp sensor that can be monitored while driving ? or is it just a warning light that comes on when its too hot ? @Warriror193 - how heavy was your cruiser that you towed ? What did you tow it with ? Was it comfortable or stressful on the car ?
  6. Yes, but what ODIS did also is initiated Headlight basic setting routine and run Acknowledge headlights basic routine. This forces physical matrix shutters to clear their stored calibrations and accept new settings. Without this your headlights will still operates as you've changed nothing.
  7. Yesterday
  8. Cheers for this. Back to the TRC1070 items then. You def called it @JR RS - In my (our) defence there isn’t an AI LLM or retailer who doesn’t list everything MQB as compatible. Started going down a track-width rabbit hole. The TTS track is still thinner (by less) so the OE TTS alloy ones would still be wrong. Only car I could think with a wide track was 8Y RS3. 4mm wider overall so 2mm per side is a fraction of a degree more negative camber. Might be what these Delphi items are for? As now, trying to find OE RS3 is impossible without stumbling across a million items which are apparently compatible with RS3 and everything else (ie not at all). They look a good find though!
  9. It's a pain in... Main issue is that it should work as designed but it doesn't. Tbh now, when it's "fixed" I still don't really use headlights in Auto on motorway. There is to many cars and lights are going crazy. It works much more efficient on smaller roads where I can see them going on and off and nicely cutting out oncoming traffic. But it would be expected from Skoda to fix it, unfortunately its not going to happen...
  10. Hi. Same issue here. Sometimes the one in the boot lid is off at all and sometimes just goes off instead of fading away. That is left one in my case. Right one just fail to go on sometimes. Tapping with the hand solves it for a long time but it is aventually comes back to this problem. It could be wire damaged in the top rubber boot or corroded pin or loose connector at the back of actual lights caused by vibration or slamming boot. Mine is electric but apparently even slow closing could cause this. It's known issue with mk3. I just have to find time to look at this, strip the inner tailgate panel and inspect the problem. Have you managed to solve your lights by any chance? Cheers
  11. My RHD driving on a UK - left hand traffic - motorway cuts the beam at the central reservation and no one gets dazzled in the oncoming traffic and the left hand side of the road is lit up. Driving in right hand traffic with this RHD car it DOES NOT cut the beam at the central reservation - left side - and the oncoming traffic gets blinded. I guess it is the other way round with a LHD in right hand traffic. And this is the flaw of this thread.
  12. I just posted in Mario's post - I would not put those SuperPro LCAs on my Superb
  13. Tis wat I've been saying for a while now - they're too short (width-wise) for the Superb. The camber will b wrong. Delphi TC4442 and TC4443 r a good option suitable for the mk3 Superb. These Audi-spec alloy LCAs r the same width as the Passat/Superb arms, and a Passat owner in Europe recently installed them. Based on the discussions on the golfmk7 forums, these r bigger than all of the alloy Golf Mk7 sized arms available on the market, which is why the Golf guys were looking at using these wider arms to increase wheel track and camber on their track/fast street cars. I'll b changing my LCA to these once the time comes for Gandalf.
  14. Yeah that's them...they are mainly for golf. I had them on car for 2.5 years, no issues until now. Just last week i started finding things that failed prematurely because of these arms. They are inch shorter on each side compared to Superb ones. My whiteline droplinks -split, ball joints -split. Got genuine ones fitted today and tomorrow it's going for wheel alignment, next week new droplinks getting fitted (Whiteline) again. I believe you can get Audi TTS bottom arms which are aluminium but I'm done with d*cking around. You can fit them and they work but they will make everything else wear lit quicker. They will also reduce your track width by an inch on each side
  15. Looks very classy to me. I'm sure you will have a great time with her. Mine still surprises me with the performance and boot space. 🏆🏆
  16. Take left front wheel off and loosen front half of wheel arch liner. You can probably see from there.
  17. And the final three. It's been a long wait! Best wishes to everyone on the forum and thank you for all of your advice and support.
  18. Well, we have had an opportunity to do our own personal PDI on Rosie 2. And I am pleased to say that everything looks to be excellent. We had a thoroughly pleasant time at the dealership and collection is scheduled for Monday, 14 September. We are really looking forward to it. I don't want to speak too soon but, so far, I cannot fault the dealership. They have kept in touch, been professional yet personal too, and seem to have done an excellent job preparing our new car. They have treated the paintwork with the Autoglym Cerafuse protection, plus the cabin as a no cost gesture of goodwill - which is more than I expected. Preparation is key to this finish working properly and, insofar as I could tell, the paintwork was smooth to the touch of my fingers. Honestly, fingers and the sense of touch are more telling than eyes. Anyway, so far so good. My insurance with Allianz is just £247 compared to £450 for the Velar. The dealer has ordered the reversible folding boot floor, some door bins and snow chains. They have popped a second umbrella in the passenger door at no cost and they have done an excellent job fitting the Nextbase 522GW camera and rear camera. The cables are out of sight and all the roof lining is perfect, as is the A-pillar. I will need to order my winter 17" rims from Skoda Parts online because the UK importer has stopped selling them. Same for the ski sack. I have a contact there and will speak to him next week because they are EU based. They are UK VAT registered and use FedEx for delivery but they need to take the VAT at the UK rate which means a telephone call because the online portal is set up for a different foreign VAT rate. This also means that they should clear customs properly with no further duty needing to be paid. Ah, Brexit. Here are some pics. I will provide an update next week after collection. Honestly, if only I had received this service with the Range Rover dealership. I spent considerably more, even back in 2017, and subsequently.....and yet a little Skoda dealership beats them hands down! Here's hoping.
  19. i never had ones. but sure stiffer than stock.
  20. on my mk 4 you can tell which sensor it is as the sound in car plays from the relevant speaker, so if it's back left that's where the sound comes from in the car etc. Mind that may only narrow it down to two sensors, not one, I'm unsure
  21. doohut1 started following no live maps
  22. doohut1 posted a topic in Skoda Karoq
    hi everyone im new on the forum, i have a 2018 karoq and been looking through the forum and it looks like to get live maps i need to subscribe to something as my sat nav dosent pick up new roads or closed roads as i have discovered latley, so reading an old answer it seems if i connect my phone with a usb cable will it show google maps on the satnav screen thanks
  23. ser joined the community
  24. No will do that tomorrow. Bit annars to get to ubder the battery
  25. I've had two windscreens replaced, one only lasted 6 weeks before some doughnut in a mini threw up a load of gravel and did two chips and as it's a heated screen it had to be replaced again, this time they put a decent one in. Beware some windscreen replacement companies replace the OEM screen with a thinner & cheaper one, this one is Saint-Gobain and is fine!
  26. doohut1 joined the community
  27. Have you checked the power steering fluid level?
  28. two photes of the driveshaft from above and the stearing gasquet. Its totally dry on driveshaft and above the stearing gasquet. Also the stearing connections are dry. This is opposite side of gearbox. Gearbox side is dry. Third photo is aver the linkarm. Some newly sprayed bodypaint but you can see a section that is oilwet. So the oil is def hitting that area but i cant figure out how. It must be rinning from, most likely, above. I will be giving it to a workshop for fault search. Shall keep you posted :) Thanks help so far.
  29. The driveshaft that's in his second photo looks completely dry to me.
  30. 195/55R15 85V LAUFENN S FIT EQ+ are a sub company of Hankook so should be decent tyres. My sons mk1 fabia is basic but also so far fairly trouble free and relatively cheap to fix. These days the newer the car the more expensive it becomes to repair so I would look after the one you have. Rust is the killer everything else can be sorted Alasdair
