Karoq gearbox doesn't creep?
my DSG used to move if you took your foot off the brake whilst in d or R for parking without a problem. I have a feeling you have "Autohold" set on. which puts the the brakes on when you press the foot brake when stopped it then requires the accelerator to be pressed to move. If you turn the auto hold off whilst maneuvering you may find it better.
Octavia Elegance 1.4 TSI - Very interested - Advice needed
@Alasdair1 it could simply be injectors sound. A lot of feedback is suggesting it’s completely normal and I guess I’m not familiar with this engine. I’ve only really worked with 1.2HTP, 1.4AZQ and 1.4BBZ Fabia engines. Generally speaking the car did drive great. I did read somewhere it does a kangaroo thing on gear one but I didn’t experience that. Being a CATN all service records were gone but they did have a print out of some service records which seemed good. I don’t think the sellers actually knew it was CAT N and it seems like they’re only selling due to a change of circumstances and not trying to dump the car. I’ve asked for them to MOT it and I’ll pay. And if there’s any issues either reduce the price or fix it and I’ll pay closer to asking price. I would request a mechanic to inspect it but it’s far from where I live and I’m not sure I’m willing to spend extra before buying the car.
- Elroq: Who else has ordered?
Sounds normal to me. Engine looks very clean as well. Have a good look for signs of oil leaks incase its been cleaned to cover any up. Might be worth getting a independent to have a look as warrior said. From memory AA do a basic one for around £100 or ask the garage you normally use if the car is local. Alasdair
What you have is actually an automated manual gearbox - which, as you are finding, is very different to a TC transmission.
If in doubt, ask vendor if they would be happy for you to comission an independent engineers report on the vehicle.
the truth about electric cars
@Stonekeeper Unbelievable, but when you hear how much the monthly cost of storage is and the length of time the cars have been there, you have to wonder if the storage costs almost equal the final value after x years.
That engine sound does not appear particularly unusual to me.
protective case for Octavia III 'Kessy' key fob?
An issue with that case may be that it's an RFID shield - OP sounds to primarily use KESSY without physically taking key out of bag. I was thinking more along the lines of a small, hard plastic case.
LED daytime running light (DRL) failing/flickering - 2022 Fabia
So I've managed to dig out the Fabia service manual I've downloaded back when Erwin for regular citizens was still a thing. Headlight "Low": Headlight "High": ... So the "Low" headlight definitely has no replaceable DRL LED modules or Control units of any sort. But what is also interesting is that for the "High" headlight DRL LED module it says "Part of the headlight, not a spare part". And indeed the module itself has no label with a VW part number. So I'm guessing that if this thing went bad then an official Skoda garage wouldn't want to replace it since they cannot order the thing without ordering the whole headlight. So much for repairability...
I think it's called hiding in plain sight 😉 You would be surprised what people who live in a different world than us do
Engine sound please advise
- LED daytime running light (DRL) failing/flickering - 2022 Fabia
Upgrade oil cooler
Others have suggested an upgraded radiator too from a 190 model. Does anyone know if thats a straight purchase and fit to my mk3 150 tdi please?
Well....the do say that a fool and his money are easily parted. You could also equally say that if a person has that much disposable cash, do they really need a good investment???
1.5 Tsi Power Cutting Out
T think that it is only the 130PS version of the 1.5TSI that is a Miller cycle engine.
Not so sure, there will only ever be one "first" produced so it should be a good investment or an excellent tax liability mitigation. I doubt it will be driven far if at all. It was in aid of Ferrari's charity
TYres - any comments on wear patterns?
Do you have a lot of speed cushions on the roads you drive? That sort of wear, if it's just in the inside shoulders as it appears to be, is characteristic of tyres that have regularly been rubbed on speed bumps when you straddle them.
SteveMcK started following TYres - any comments on wear patterns?
Your tyre pressures are far too low... Hence the wear. I'd also suggest you get the tracking looked at if that wear was on the inside edge as it suggests a slightly toe out setting at the moment However, the key problem will be the pressures your using IMHO.
Fabia Mk3 1.0 TSI 110HP Spring like noise coming from brake pedal
Brake light switch on cars of this age is just a Hall Effect device bolted into the end of the primary cylinder ("master" does not seem to be very PC these days) - there may well be another mechanical switch on the pedal to let the car's other controllers know that the brake pedal has been pressed - check to find out and spray with a suitable lub - without getting it on the pedal though! Edit:- the brake servo will have spring inside it, just a thought.
There are clearly some very rich fools about if they are happy to spend 40 times over the odds for something that ugly (IMHO of course)
EV PoweredFirst Ferrari Luce sells for $40m, almost 40 times its es...The first Ferrari Luce has sold for $40m at RM Sotheby's Monterey auction, almost 40 times its estimate, with every dollar of the price going to charity.
freddyuk started following TYres - any comments on wear patterns?
I have just replaced all four tyres on my 2018 Superb Estate 2.0i. I do average mileage (I am not a Rep) and mainly on country roads so low average speeds and local journeys. A couple of trips per year across to France and use motorways there. Front set were Nexens which were recommended here. Fitted in January 2024. Mieage not recorded. Rear set were Goodyear fitted in September 2022 - mileage 69889 km Current mileage 139,000 (average mileage??) I was a little shocked to see cords showing through on the Nexens right on the shoulder. This suggests low pressures?? I do run less then recommended due to the harsh ride - maybe 28psi -30psi unless loaded then increase to 30-32psi The Goodyears show very uneven wear from side to side on the same rear axle. What accounts for that? Somethindg seems a bit off. Maybe I will get the tracking checked. I have fitted Yokohams this time.
Amazon sell them. Not sure if will fit https://www.amazon.co.uk/Leather-Shielding-Waterproof-Universal-Protector/dp/B0GXKPQXXC/ref=sr_1_1_sspa?crid=JGAA6RHGL005&dib=eyJ2IjoiMSJ9.WjAjp0G2BbpUKhGkR_VCF0dLxWHseIlPjqhW_f_tEc31CtrIirhozHqjuBYAp7pMflOppOfemVqx9ZDulvRvp1fij9KohDyG2fHPzwjIIB1HIr-N4ObRBHFekfZ022sCBW3babiMkhDaTHXKZN1vOwyt5qz_9ZkzgjqhEdU3QS0Sgbk0M6dJvdfyzMwvwJNfo2AGrXvo8p3-AXTzpLVSy8v4mk0ow1KB0L5NjU86Xo3uo5z82XFB2d9cqHEH55PRjDybMS0IgeQgzZxtOpu0VLcR0VeNYcRw0Zz8jrVgiZg.etK-emoAKBzdEneHJcwMZg5EZx_sVN2WvRHnx44ffK4&dib_tag=se&keywords=skoda%2Bcar%2Bkey%2Brigid%2Bbag&qid=1786873312&sprefix=skoda%2Bcar%2Bkey%2Brigid%2Bbag%2Caps%2C131&sr=8-1-spons&aref=BjaB0naEoF&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
