KamilM joined the community
Can anyone help identify these hoses/parts
@Binx1310 can confirm you have the right part in your post, mine above was wrong. I ended up replacing because it was actually broken in two places and it basically came off completely in my hand. The 3M 24 self adhesive electrical tape is very good for that sort of thing if you can patch up though.
2.0TDI 184hv coolant issue
So I have problem with my 2015 octavia 2.0tdi 184hv. I can drive the car normally for how long ever I want, but when I floor it a couple of times, the coolant reservior is empty. Some of the coolant is outside the reservior, but most of it comes back to reservior when I open the cap. Already done: changed reservior cap, changed main waterpump, changed thermostat, checked for combustion gasses in reservior with combustion test, not the liquid one and there was no combustion gasses in reservior. I think it should not be the headgasket, because in normal drive there is no problems. Could egr cooler only give pressure to the system when I floor the car or could it be some waterpump, glogged radiator or leaking intercooler. I did pressure test while it was cool and there was no leakage. Also put 1 bar pressure to turbo and pressuretester on reservior and the pressure on reservior didn't go up. Should I just buy the egr cooler or is there some test I should do first
Joni5629 started following 2.0TDI 184hv coolant issue
- Felicia MPI: Strange Front-End Noise – Brakes & Bearings Replaced
Mood lighting, good but not good enough
Thanks David, but I already realised that. It's individual OR driving mode, but I really want both. Red for sport mode, and my very tasteful purple and blue individual colours for the rest of the time with my individual driving profile. I'll just have to add it to my list of annoyances...
Skoda News
Some good news. https://www.skoda-storyboard.com/en/press-releases/skoda-auto-in-the-first-nine-months-of-2026-strong-results-and-second-best-selling-brand-in-europe/
Timing stuck at 38
On the 1.9tdi BXE the camshaft pulley has three bolts in oval holes. When I did mine I had to loosen and adjust slightly. First I used locking tool kit and fitted belt then removed kit and rotated engine by hand but after a full rotation I had to adjust bolts slightlyt to get timing locking tools in again. Wasnt much probably 1mm but it may be enough to affect timing. Think they will run if only one tooth out but would be very noticeable. If its just slightly out by 1mm it may explain your problem. Alasdair
Alasdair1 started following Timing stuck at 38
1.5tsi put put sound on tickover diagnosis
https://www.skoda-parts.com/spare-part/05e133366dt-ventilation-pipe-with-akf-valve-skoda-46956.html Found it on Skoda parts. But also found another post where @imart143 said that he used 3m self amalgamating tape to repair it so I will give that a go before spending £170!
I think I’ve found it but will definitely try the tape at that price! https://www.skoda-parts.com/spare-part/05e133366dt-ventilation-pipe-with-akf-valve-skoda-46956.html
1.5 TSi - engine mods - intake / exhaust etc
Thank you. I will message them and see what they say!
Pretty sure the res delete has a subtle but noticeable effect. Note what JRRS said - anti-drone res delete. There is a closed-end tube added to the delete pipe which basically helps offset motorway drone. Probably same principle as noice cancelling - bouncing sound waves to a certain length so they’re coming back and offset the sound at fixed revs. Just an absolute guess mind you. RPM is based in Norfolk - pretty small outfit that do it all in-house. When I spoke and told him what year/engine the car was, he knew enough to ask me to look under the car and check as they had removed the res on some other models - sure enough, nothing there so I trust he has a bit of experience with the brand etc.
This is the same as I have on our 1.5 tsi. Just posted about it. Can you let me know part number please and I can investigate options.
Binx1310 started following 1.5tsi put put sound on tickover diagnosis and Can anyone help identify these hoses/parts
Thanks for the reply Probably best of going down the custom exhaust route then, to stop any issues with fitment. I’m not sure what I want to do Sounds ok being standard Nice to have a quiet caR.
Activating SmartLink on Swing 3
Same issue here, with a cheap Ottocast it does not work. It is, as far as I can see, a compatibility issue. I updated the Ottocast firmware with no solution. My conclusion is VAG MIB units have deep hardware incompatibilities with certain multi-protocol conversion chips. Dedicated single-protocol adapters like AAWireless (which has specific VAG compatibility toggles in its app) could be the solution. For now I choose to use the cable solution as AAWireless is a bit expensive. But xmas is coming...
fuel filer panel
cheers buddy ! just trying to find out which solenoid it is on my car i think it could be 1 of 2 types, thanks kev
glow plugs
yea i have been told that, and that your car wont do a regen if there is a problem with the glow plugs. they do a bigger job than you realise. thanks!
Thanks to a random video that popped up on my instagram feed I’ve found that the put put sound on tickover when warm is a broken ?vacuum? hose. dfe09568-b13e-475d-8d07-4db86c95f743.mov Any pointers as to part number for this?
Fob dead locked out? What if?
Many thanks. I still can't get the thing to open. Ho hum. I have tried pressing down hard as per illustration but the thing won't open. I dare no press and harder in case I damage something.
Enyaq 85 sel 2026 tyre pressures
I contacted the dealer about this and they said they had moved it. I checked around the car again and it is on the rear offsife door wheel arch when you open the door. Seems a strange place to put it, than the usual places.Thanks for all the input on this :).
Be careful when on the look out for parts. Generally Skoda's, aside from the vRS models (and mostly the Octavia out of those), are a bit of an afterthought by tuners; it's more that parts made for other cars in the group are applicable as an afterthought. Also not that although they are all called MQB chassis, that's actually split into 4: MQB A0 - Polo/A1/Fabia MQB A1 - T-Roc/Seat Ateca/Octavia/Karowq MQB A2 - Skoda Kodiaq MQB B - Skoda Superb. Other cars in MQB-B are Passat or Arteon. Point being: some parts fit across the ranges, others don't. Generally, engine stuff will be like for like - EA211 which is yours will be the same; but stuff dictated by chassis size won't always - exhaust comes into this. Downpipe should be fine as the connection to the turbo will be the same (but its a bu66er to change because of the routing above the subframe). But the chassis are different so you may need a custom one or potentially can cobble together bits with extensions clamped up between, bearing in mind checking exhaust hangers and other bits are in the right place.
DGW started following Kodiaq 2017 - Strange 9 errors from nowhere
Spacesaver spare wheel
I've listed below the current five UK-specification Skoda Fabia Mk4 models, showing their possible road-wheel diameters (standard diameter first) SE Edition - 15" or 16" Design Edition - 16" or 17" SE L Edition - 16" or 17" or 18" Monte Carlo Edition - 17" or 18" 130 - 18" For the SE Edition model Skoda offers two spare-wheel options. If the car has 15"-diameter wheels, the spare-wheel option is referred to as being "full size" comprising a 15"-diameter steel wheel with a 185/65 R15 tyre (plus there's a tool-kit in a polystyrene insert that fits inside that wheel). If a SE Edition model has 16"-diameter wheels, the spare-wheel option refers to an "emergency" wheel that is suitable for Fabia Mk4 models that have road-wheels with a diameter of 16" or 17" or 18". This option comprises the same spare-wheel 'package' as the "full size" spare-wheel option for 15" wheels, except the steel wheel carries the labelling shown on this image It will be noticed that, although there is a 50mph/80kph maximum speed limitation, there is no stated limitation on maximum distance (as is normally found on the labelling on space-saver 'skinny' spare wheels). It's possible (as Carlston has said) that the tool-kit's polystyrene insert would sink deeper into the inner part of a wheel with a larger diameter than the standard 15", but there's the spare-wheel's hold-down mechanism beneath the polystyrene insert that might stop this happening. I don't think this is a show-stopper, as it should be easy enough to adjust the height of the insert so that it provided support to the floor of the boot - I'd be more concerned about whether a 16" wheel with a 195/55 R16 tyre would go under the edge of the boot I marked in red above. As RedSkoda2's 2026 Fabia has 16" wheels with 195/55 R16 tyres, if he has the necessary equipment to remove one of them, he would be able to confirm whether or not there's any problem putting that size of wheel/tyre combination in the car's spare-wheel well. My own 2023 Fabia Mk4 SE L has 16" alloy wheels with 195/55 R16 tyres and has the Skoda "emergency" spare-wheel option of a steel 15"wheel with a 185/65 R15 tyre. If I had to change a wheel, I'd hope to be able to temporarily store the 16" alloy wheel in the car's spare-wheel well, but it would not break my heart if that was not possible. When I bought the car, one of the first things I did was to remove the spare-wheel and confirm that it would fit OK on the car's front axle (ie. that it would not contact the brake disc/caliper). I could have easily checked at the same time that the 16" alloy wheel with 195/55 R16 tyre would fit in the spare-wheel well, but it never crossed my mind to do so. Before the Fabia, I owned a mild-hybrid 2021 Hyundai 120 SE Connect model that had 16"-diameter alloy wheels with 195/55 R16 tyres . The car had a small 48V lithium battery in the spare-wheel well under the luggage-compartment floor, so no space to carry any sort of spare-wheel there. I'd been caught out abroad a couple of times with punctures, so I wanted to carry a full-size spare-wheel in the i20. I bought a secondhand Hyundai alloy wheel that would fit the car. added exactly the same Michelin tyre as on the four road-wheels and bought a suitable jack. I then found that this wheel/tyre combination was too wide to fit flat in the boot (!!!) so I used to carry it in a storage-bag upright behind the front passenger seat. I only took the Hyundai abroad once, never needed to use the spare-wheel and sold the i20 not long after the trip.
Superb Mk2 2008 Keyfob Part Number
If you message me with the car VIN I can look it up for you later.
Auxiliary Coolant pump
P2B63 on the VAG stuff is "coolant pump 2, blocked" and it's often logged as sporadic. On the 1.0 TSI (EA211) pump 2 is the little electric charge air cooling pump (V188), not the main water pump. It runs a separate low-temperature circuit through the intercooler that's built into the inlet manifold and the turbo, and the ECU runs it in short bursts, including for a few minutes after you switch off, so you sometimes hear it whirring after shutdown. It sits at the front of the engine, low down under the inlet manifold on the oil separator housing. Best access is from underneath with the undertray off. Before buying one: 1. Clear the code and see how quickly it comes back. If it's sporadic and only now and then it can be the plug rather than the pump, so check the connector for green pins or a broken latch. 2. Listen for it running after a drive with the bonnet up. Silent every time points to the pump or its feed. 3. Check the coolant level and look for any leak around the pump and its hoses. Air in that circuit can make the pump labour and log as blocked. If it is the pump, it's one connector, two hose clips and a bolt. Clamp both hoses first. The catch is the circuit has to be bled properly afterwards, either with a vacuum filler or the guided bleed function on a decent diagnostic tool, otherwise it'll throw the code again. Part numbers for that pump are in the 04L 965 567 family with different suffixes, so check against your VIN before ordering rather than going off the engine code alone.
SparePartAlam started following Auxiliary Coolant pump
I've searched Aliexpress with each of these numbers, and nothing. The're probably the references of the individual bits rather than the complete part.
When the car was driving normally, or when the wheel was turned or moved while on a lift, it didn't make any noise. Sometimes it wouldn't even make a noise on the road; for instance, I could go on a 200 km trip and it wouldn't make a sound at all, while other times it would start making noise just ten kilometers into a 200 km journey. In other words, it wasn't a continuous sound. Additionally, the left wheel was removed multiple times, and the hub, bearing, etc., were checked numerous times; because the play was just a fraction of a millimeter, it wasn't very noticeable.
Even by telephone if you say to your mechanic "i listen a Yyyyn" sound when the car rolls in low-mid speed and stops when i brake he will answer "ball bearing". That's the first thing that will do,the sound is characteristic no matter if it's car or motorcycle and there is a specific (funny) slang expression: "this ate it's own bread" which means "his life is finished". Fitting a ball dearing it's a serious task because in case of mistake you need triple work-time to remove it plus the cost,in repair/machine-shops here No newbie employee is allowed to do it. He only carries from the self to the hands of the mechanic,mustn't be dropped down not even thrown to the bench carelessly.
