Most upset, my V3 L&K written off after a cretin drove into me.
@Tankdave Too I believe…
- 2019 Headlight and windscreen washer faults
Warrior193 started following 2019 Headlight and windscreen washer faults
Reversing light
Good tip BazzY. If anyone goes the LED route, pick ones listed as CANbus/error-free so you don't get a bulb warning on the dash, and check they sit the right way round in the holder so the beam isn't pointing at the back of the lamp.
2013 1.2 TSI exhaust heat shield removal
Thanks Pete, good shout. Worth giving the dealer or parts counter your VIN when ordering it, as the 1.2 TSI had a couple of engine codes around 2013 and you want to be sure you get the one that matches your car.
It is an electric actuator, and is available from Skoda as a spare part, item 2 here: https://www.lllparts.co.uk/catalogs/skoda/CZ/YET/666/1/145/145050
19” vega alloys advice
I do like them! Can you PM me the link
2020 Technology Courtesy Light
Right. All 4 buttons are pushed in. If you let out the one with the car picture on, it turns off the courtesy lights. If you let out any of the others it turns them on individually accordingly. If you let out the others while courtesy button is in, then they get brighter and stay on when courtesy button is released.
Reversing light
Had the same issue with a Golf. Replaced the bulbs with LEDs from ABD.co.uk and it's about 6 times better and brighter - and yes, still white...no canbus errors. Remember when fitting that LEDs often work only one way round so if at first an LED doesn't work take it out and put back in the other way round. Good Luck.
BazzY started following Reversing light
Rubber boot mat - anyone after one!
Moved to Parts for Sale for greater exposure
I’m questioning my memory now. Will check mine!
I'm sure I've tried that but will venture out tomorrow and test it. Thank you
Yeah I think mines kerbed from a pothole since I’ve got it already I know what I fancy Just mega bucks
Reversing light
Thanks for the comparison, that's useful to know. It does suggest the bulb is the weak point on the cars with the halogen cluster. If anyone goes down the LED bulb route there, it needs a CANbus-compatible, error-free bulb so you don't get a bulb warning, and it should stay road-legal: white, not dazzlingly bright and aimed down. A reversing camera is a sensible extra on top, as even a good light only shows a short way behind.
Good to hear Skoda UK have nothing open on it, John. Some side-to-side play in the wastegate arm is common, and worn wastegate bushings causing a rattle is a known issue on these, so play alone doesn't condemn the turbo. If your actuator turns out to be electric, check the connector and wiring first. A smoke test and watching boost in live data should help separate the actuator from the turbo. Good luck with it!
Did they say which bushes?
I used compare the market and you have options to list all the things so then you only get quotes from insurance companies that will cover. Mine is with Hastings and just had to take about 10 photos from all angles. I suspect it now means that any tiny cosmetic change will void insurance and require a £20 admin fee to update as they have photographic evidence! I think it probably helps that I’m not a 17 year old liability with a modified car!
2 things to bear in mind: They weigh a ton Whilst they do look natural, they sit beautifully proud of tyres inviting the most exquisite of lovetaps with any and every kerb. My advice, get something that is a little lighter and also that sits flat or dishes in slightly. Also not a fan of diamond-cut given its propensity to give up the ghost so easily.
Not on socials anymore 🫣
I declared my stage 1 Revo ECU remap (+80bhp) to my insurance company a few years ago & have changed insurer since then a couple of times. No increase. Having said that some insurance company's won't touch anything that's modified these days so best to check before diving in only to find out bad news later on.
Have a browse on instagram. Lots of inspiration… for example https://www.instagram.com/superb_vrs3?srtk=dWZic3NjbmVpYTJr https://www.instagram.com/mk3_superb_grey?dlrf=MWxhbHViejR4MWsxMQ== And @Kosin https://www.instagram.com/danny_superb_3v?cplk=YW1ycnRhbjl2dzli
Check oil level warning - level seems fine
Hi guys so quick update, The oil level is at the correct level it's just below the first slope/line. I will check the wiring on the sensor for and breaks or if there is a connection issue using a multimeter if that seems okay I will get the exact oil level sensor as I have found one with the same part number as the original one which I have confirmed with the vin number . P.s I have pumped up my tyres so that has sort out the tpms light
Problem is. I do car shows with it So also want the most impact to stand out It’s strange driving a standard car 😂
Easiest/cheapest first. Then you don’t feel so bad about spending more money on singular larger mods as you’ve achieved so much already… Make sure you let your insurance know. Just done a renewal and declared everything and had to send photos but no change in premium as nothing is permanence changing.
RogueWagon started following 19” vega alloys advice
My 19” vegas are rough Kerbs, clear coat is flaking, worming Debating a few things Upgrading to 20” vegas Refurbing these, but I don’t know what colour to go for, not a fan of the diamond cut lips etc so would prefer a solid colour over it all Or leaving them and buying aftermarket Advice Anyone fitted 20” vegas?
