Past hour
Wiper blades for 2022 Karoq
I’ve also used Bosch aerotwin on other cars too, including Skoda Octavia & Fabia, & had trouble with fitting on one & ended up going to the local dealer for wipers & couldn’t get the twin pack to work & had to get two individual blades, I seem to remember that they have part numbers on the blades which I’ll have to look at
Today
Our 2016 Vrs TDI came with an AGM battery as standard and we never had any issues, our 2019 Kodiaq came with an EFB which died after 3 years, replaced with a Yuasa AGM, recoded with OBDELEVEN all working perfectly. Our new Scala also came with EFB which had to be replaced after 3 months under warranty the replacement lasted another 3 months. Turned out the ECU was somehow killing the batteries. ECU replaced under warranty and a new AGM battery fitted all good after that. Think it's a bit of pot luck with the quality of some of the batteries Skoda fit as standard.
Considering getting rid of my 2020 SE L in favour of a 2023 VRS...
The car in question is diesel and an automatic, as opposed to my manual petrol SE L. If I was to go for it, it would be the first time I'd ever owned a diesel car in 30 years of driving, and the first auto I'd ever owned too. Just wondering for those with experience, if there's anything in particular I should look out for or be wary of? It's a fairly low mileage example with a supposed full service history, so in theory everything should be in good shape... Although as we all know, when it comes to the Mk4 any kind of theorem is little more than just a guess Appreciate any input, it's just an idea at present but interested in people's thoughts
L&K Front Fog light Bulb access?
Yeah mine are just on or off.
My late 2015 (MY16) Octavia had the battery (AGM) and alternator replaced under warranty in mid 2016, the EFB fitted then currently tests as 89% health at 82% charge (DIN) with internal res. of 4.61 milliohms. Due to frequent short trips, I use external charging when SS stops operating consistently - usually around 2-monthly during winter.
Change details.
Go to top right and click on your avatar/user name. ( EJB ) Go down to Account settings. Go down to email address and on the right click the 'change' tab. HTH. Thanks. AG Falco
AGFalco started following Change details.
The LEDs won't dim like the normal bulbs did in the foglights.
Don't know yet. Not had the car out on the road since I replaced the fogs.
Top mount
Only had my superb a few weeks. Yesterday it started making a horrendous twang. I suspected a spring , turns out the o/s top mount has left the chat. So I wanted to ask, is it a pretty straightforward DIY job. And what's a decent replacement brand to use. Its a 2016 superb estate L&K 4x4 2.0tdi 190. Many thanks
Octavia 2.0tdi engine swap - DTTA in DSUS car?
Hi. If you have any issues with insurance at all for a change of engine then please feel free to drop me a line. Regards, Dan.
DAN@ADRIAN FLUX started following Octavia 2.0tdi engine swap - DTTA in DSUS car?
Suspect engine oil leak
No.
Hi Pete. Found this on the Rapid Guides on here, Is this what you are meaning ? 1.2TSI Crankcase Breather Hose One Way Valve Replacement Guide (by Mintyfresh)
- Infotainment Firmware update MK3 2018/19
Dashcam Switched Power
Nothing the dealer can do about it. That is how the dash cameras automatically switch on and off is by detecting the actual voltage being fed to it. If it drops below a certain point, the camera switches off. When the car starter kicks in, there is a large drop in voltage everywhere in the car at the same time, so it is just as likely to do the same even if it is plugged into the power socket. At least with the camera wired up so it wakes up when the ignition is switched on, it removes the chance of you forgetting to plug it in, leaving you without any video protection in the event of an accident. If the voltage gets to a critical point when it is plugged into the 12V socket, the camera switches itself off to prevent it from draining your battery even lower. So wiring it in will prevent it being forgotten to be plugged in when driving and also prevent it from being forgotten to be unplugged when you aren't driving the car. For the small cost of an OBDII scanner tool, you can ensure that you can never forget to switch off the stop/start by tweaking the point in which it cuts in, all the way to disabling it completely, and also alter the way other things operate, and also enable some options that aren't operational unless you have a range topper car model.
SimonDinsdale started following Ambient air temp sensor on the wonk
Hello all, long time lurker, 1st time poster. I'm having trouble with the (external) ambient air temp sensor. When I start the car in the morning (2010 CFGB TDI 4x4 estate) the sensor works fine, when I return to the car initially the sensor works and then it starts shutting down ---- on the MFD and then occasionally reads 58C then ticks down to the the actual outside temp and then shuts down. I have a Carly scanner and I get fault codes for the circuit being too low, too high, with the addition of 'sensor for outside temp, resistance too small" at the instrument cluster. I also get a faults for the air quality sensor, and the glow plug controller/relay and wonder if they're all connected? Also I get error messages on MFD for various bulbs being out I.e DRL, side lights etc but, no fault codes stored so wonder if this is also connected? So far I've replaced the external air temp sensor with a OEM part from DSD, replaced the plug and 100mm of the cable. I'm wondering where the sensor draws power and that perhaps there's something wrong with the wire in, I've chased it back to where the two cable meet with the rest of the loom that serves the engine bay and goes through the firewall seemly to the instrument cluster. I'm all out of ideas part from unwrapping the loom to see if there's a break in the cables or whipping out the clocks to see if there's an issue behind them. I'm hoping that someone has experienced the above and can help me solve this conundrum because it's causing mayhem with the HVAC system
Adiwez joined the community
Hi Pete. I will definitely give that test a go to see if it is possibly the fault you have described re. the breather diaphragm. Thanks for the heads up on that. Will keep you posted. Hi Alistair. Yes, that is the problem, tracing the source of the leak. I am sure I have pretty well eliminated steering (electronic) and brake fluid as there is no drop in the reservoir level. I am going to look into what Breezy Pete has suggested above and see where we go from there.
If it’s the same as the 24 model go into gateway and type battery in to the search and tick it. You’ll then get a list of the battery parameters.
Timotej started following Infotainment Firmware update MK3 2018/19
Skoda Superb Combi 3V539Z suspencion
For the Superb MK3 4x4 with increased ride height and without DCC (electronic damping control), one option for shock absorbers is Bilstein B6 from the VW Passat B8 Alltrack. The VW Passat B8 Alltrack has increased ride height and four wheel drive. Bilstein B6 and Bilstein B8 have a mono-tube design which is better than the twin-tube design on standard shock absorbers such as Bilstein B4. Bilstein B6 35-273806 front shock absorber (without DCC) (VW Passat B8 Alltrack) https://www.autodoc.co.uk/bilstein/9612727 Bilstein B6 24-267137 rear shock absorber (without DCC) (VW Passat B8 Alltrack) https://www.autodoc.co.uk/bilstein/9350571
- Dashcam Switched Power
Do your leds dim? Think most just turn off
- Skoda Superb Combi 3V539Z suspencion
12V low, can I charge it up with a charger?
Thank you.
I turned I turned off my stop/start by raising the threshold of the voltage at which point it comes into play. The car now behaves as if is not fitted with the system. The minute amount of fuel it uses is way cheaper than the cost of replacing the battery, starter motor and alternator, which work harder with the system activated, and the camera switches off and on all the time. This is a better solution I think, especially if you drive in a town or city a lot as it exposes you to a higher risk of not video evidence at times of increased risk.
