Space Saver Spare Wheel
What profile tyre is fitted?
I wish I had rang them for their advice, I went with the 17" wheel and the circumference is way smaller than my 17" wheels. I will definitely only be putting it on the rear.
Kamiq navigation
A restart may be all you need. Also try tapping on the HOME button and then swiping left or right to the view you want. Nav full screen should be available by tapping the NAV button.
Aldfort started following Kamiq navigation
- skoda felicia pickup 1.9D HANDBRAKE
Oil Change
I will look at this next time thanks, price considered.
Oil Change
Quick update, oil change completed. Easy enough job just the undertray a bit fiddly needing 4 different tools to remove. I went with Castrol EDGE 0W-20 LL IV Advanced Full Synthetic Engine Oil in the end. Thanks for all the replies and if your thinking of having a go at it yourself.....do it.
Are both cables are too short now and you cannot catch nuts on the thread even if hanbrake is maximum down in zero positon? If cables seems too short now you need to push back self adjusters up with pliers or screwdriver. It will relase more cable to the cabin and you be able to put nuts on the thread.|You dont need to remove drums. You can do it with screwdriver through the lug bolt hole but it is tricki for the first time.
PR Code request
Is there no sticker in boot near spare wheel or sometimes in owners book/glove box? Alasdair
Alasdair1 started following PR Code request
Cruise Control Gateway Swap solution
I have a friend who wants to retrofit cruise control to his Skoda Scala. He only has speed limiter. His current bcm (and gateway combo) is 2q0937087D. He is also looking at retrofitting 090 with 3q0 external gateway if it somehow helps. If someone has a solution for the missing swap code it would be amazing.
SUBZER0 started following Cruise Control Gateway Swap solution
the truth about electric cars
Please read my post again; I said that you're NOT a green warrior, but you still misunderstand what I'm saying. I'm like you; I doubt I'll be around by the time ICE is banned, but then again, I could be. My mum never passed until reaching 92, so I could be. As to whether I'd still be driving, who knows that answer? I don't, and neither do you. But, like that professor told me, as an engineer, I have an inquisitive mind, and I'll never give up trying to preserve our rights to have a choice. As I have said before, when those at the top of the tree start proving their green credentials and actively do what they want us all to do, then maybe they might get somewhere. Like the lockdown when BJ was having parties and others were having police raids, they just keep on demonstrating how it's one rule for us and another for them and their wealthy backers.
- Super Estate Tailgate Problems
Binx1310 started following Super Estate Tailgate Problems
kokosal started following skoda felicia pickup 1.9D HANDBRAKE
Vapos retractable towbar retrofit
Why electric? They're just so prone to failure. Just get a detachable one and you're done. ^^
Cairus started following Vapos retractable towbar retrofit
I would be interested in the answer to this too.
Binx1310 started following Vapos retractable towbar retrofit
Skoda Felicia 1.6 fuel pump problem
To be honest I cant hear relay ON click because is masked by turning ignition. I can hear OFF only. What if you remove relay and try to turn the key to the ignition position? Still pump works without relay? If yes I would check cable from relay output to pump. Maybe there is just another jumper cable from lighter to pump.
Radio / telephone problems
Correction.. part number is 5Q0 035 842 B
Hi. My 2016 Fabia Radio went completely dead I changed the glove box unit with a second hand one. Got Component Protection removed at a Skoda dealer. Radio and most functions all ok, but Telephone not available message shows when selecting telephone. Part number is exactly same as old unit, 5Q0 035 842N. Any ideas on my best course of action ? Thanks.
AlanKP started following Radio / telephone problems
@Graham Butcher I have a BEV & 2 ICE vehicles. I am no green warrior. I am just raging against the machine. Or being a rebel without a cause. We are where we are and the motor manufacturers are where they are. No matter how much there is mumping and moaning from those that have not and what not a BEV they will still be getting built and purchased. I doubt i will be driving in 5 years so really could not give a monkeys what the UK government does. I am only here for the banter and to read some of the crap posted. PS. Please show any post ever from me where i say or imply that BEV,s are the only way to clean things up. You are making up your own story there.
Kcha started following skoda felicia pickup 1.9D HANDBRAKE
Faulty "Faulty Light" detector
Today I learned... ... My Fabia has TWO off-side rear side light bulbs!!! 😒 Having nothing better to do today (well, nothing vitally important, anyway) I decided to check all the connectors to see if there were any loose wires or corrosion on the pins etc that might be causing extra resistance, since each light cluster was showing a working bulb. Thankfully I started on off-side rear, because, after removing the light cluster and separating the connector, I used a multimeter to check continuity. I looked at the different colours going to the bulbs and saw one that had black and brown wires, which I checked and they were OK. Then I happened to notice that there was another bulb with black and brown wires. I took that one out and, lo and behold, the bulb was blown!! I have no idea why I didn't spot this before when I was checking them, the only thing I can think of is that, having checked one (which was OK), I simply didn't consider the fact that there might be another one. Anyway, I replaced the blown bulb and, Huzzah!, I stopped getting the faulty light warning. So if anyone ever has this issue again and finds this thread, check BOTH bulbs...! 😳
