  2. Yes - the instruction manual probably trumps my 'pre-2020' memories of fitting it. Though I remember spraying it up in matt black IN my flat at the time, within a makeshift 'paint booth' I setup in the hallway using hanging plastic sheeting... whilst my other half was away for a girls' weekend - and managing to get away with it, minus the lingering (but delicious) smell of solvents 😅. It was initially a bit fiddly to fit, but been fine ever since. Even the DIY paint job is still mint, probs due to many layers of primer, black, and clearcoat in my frenzied painting weekend... 😉. Yes, give us a shout if any Qs.
  3. lagerzok joined the community
  4. Plenty have made the same comments over the years on this forum as the op but usually in the Karoq section. And the questions @Warrior193 asked are the common ones to ask.
  5. Today
  6. Jonboy984 changed their profile photo
  7. I am still missing the "headlight range adjustment" adaptation in control unit 09, the BCM.
  8. Loupblanc joined the community
  9. Due to some reduced power issues I am having, my garage, says they have done a smoke test and there is a leak in the metal turbo intake pipe. The garage says it's not a standard pipe but I disagree. I've got the 2007, vRS SE, 1.9PD TDi BLT engine fitted with a GTB2260 turbo. I fitted the turbo and FMIC some 10 years ago and on the inlet, the only additional part I got was an intake pipe coupler, for the larger diameter inlet on the turbo. Does anyone have a part number for the standard/OEM vRS turbo inlet pipe. (Like the one in the picture). Any help appreciated.
  10. Don't get that on my 1.5DSG. It is a powerful FWD though so if you are expecting to simply stamp on the throttle you will get some wheelspin, just like in any FWD car.
  11. @TerryGP When you say yours cannot be switched off how are you trying to do so? Should be able to tap the button on the steering wheel to bring up the various options and untick the Lane Assist option. Can still do that on our Karoq bought new in March.
  12. Yesterday
  13. I don't think you need the app - I just went (on my laptop) to: https://www.skoda.co.uk/apps/manuals ...and picked a Skoda model, and the PDF download link is there too.
  14. Your ABS Wheel speed sensors could be dirty and or broken. Your tires made of harder rubber depending on make and type. Tyres over inflated for the weight of the car. Driving skills? And I don't mean this rudely. If you know the car is powerful enough to spin off the line. Learn to get off the line and immediately short shift to second. Or get accustomed to pulling away cautiously. Does the car do it in the dry, or the wet? Do you have the habit of stamping on the throttle. The car can't change what it does. But the driver can adapt to make sure the car behaves. Its all about experience.
  15. Yes, I have a rear camera and it is clean and working normally.
  16. Graemed15 joined the community
  17. Hello, this is my first post :) I write question about pre-facelift fabia. Is it possible to fit original monte carlo parts to stock fabia? I saw that diffuser fit, but I can't find any information about rest of parts.
  18. Park Distance Control: please clean rear sensors - 2022 Octavia 1.4TSI iV Hi, I am getting this message on the display and NONE of my rear parking sensors are now working. The front sensors are working fine. The scanner fault code is B107B or 13959168 rear parking sensor ice, dirt or environmental influence. It does not appear to be an issue with an individual sensor, if I disconnect any one of the rear sensors the scanner will identify that sensor as being disconnected. I have disconnected and reconnected the battery in the hope it might reset it but no joy. Any idea what my issue is or how I might go about further fault finding it.
  19. Welcome to the forum. What tyres does it have on? Are the tyre pressures correct?
  20. Does vnci 6154 work the same? They’re much cheaper than vas https://www.obd2shop.co.uk/wholesale/vnci-6154a-vag-diagnostic-tool.html?gad_source=1&gad_campaignid=22158049574&gbraid=0AAAAA-tYH4gLXtC0uR2X3OZAFbsqtiakj&gclid=CjwKCAiAlKrYBhBuEiwA4o3xo5msqzdEwPAsN_ww26PdRsjXXdyX_6CI-9_YfBl8LcpqZZGR-IcBlBoCpWwQAvD_BwE
  21. Ok, understandt… regret being so far away from Austria…
  22. Thank you. Does that mean it would work in another car if it had a similar spec or it needs the data from VCDS(?) and sending back to you for it recoding?
  23. Uffe joined the community
  24. Scooch joined the community
  25. Fuse checked same time as the bulbs - all good. Thanks for the fuse layout file. Found hatboyharvey YouTube for lower dash removal. Will attempt fix when weather is better- no garage, ☹️. Thanks again for your help, Richard
  26. @TerryJP Odd that it comes on almost every time and not 'every time'. It musty be broken 2 or is that 3 ways. Coming on at low speed and not being able to disable. Then not always coming on. They do typically activate around 60 km/h / 37-40 mph. Ask Skoda Customer services chat bot and see what the A! tells you.
  27. I might sound like a bit of a killjoy, but I'm inclined to agree.. I called it a day with diesels earlier this year as a result of one problem after another. I've closely watched what was then a 20P per litre gap above Petrol open up to more like 30P in just this year. That gap is manufactured (IMO) and won't be closing at anytime soon.
  28. I have a VW UP 2023 that has lane assist. I do have a switch for lane assist that defaults to on at every start up. I managed to program the car for it to remember the last position the button was in at the next start up. So if left it off, it stayed off, until I wanted to turn it on again. I used OBDEleven. I don't know if there is an option for it to do it with your car. Thanks. AG Falco
