D.FYLAKTOS
  1. The price is very high for an estate item like this: https://www.b-parts.com/auto-parts/engine-transmission/anti-roll-bar-skoda-felicia-i-6u1-1994-1995-1996-1997-1998-4017857 Back in the good old days Eibach sell this for Fellica (i have bought it, i have the 1.3 No ABS-Airbag edition) but now isn't on their catalogue any more.
  2. "As for the record" (practically is for Google search from a Felician) the Skoda sold as an extra a strut brace like the one in the photo. I have it in my Felicia Glx 1300cc.
  3. https://www.briskoda.net/forums/topic/492268-help-getting-my-felicia-13mpi-engine-started/ https://skoda-virt.cz/cz/clanky/elektrika/8248-bmm-spi-felicia-1-3-to-s105-rapid/?gotopost=3057788
  4. You already have and OBD1 (or plain OBD) port in your Felicia which is connencted with your ECU. You want to plug one of those fancy OBD2 devices to that port to read some ECU parameters? You can't.
  5. Me too, i had a sort of ''sponge feel'' (as we say it here) after the mechanic changed a brake pump. I told him but insisted that the pump-bleed-add new brake fluid is ''the New way, much better'' etc so by first chance i went to another repair shop with a stictly order ''i want the old-school method with two persons'' and guess what? When i took my car things were much better then before, by instict i didn't liked the modern method, i wasn't convinced that it can remove completely the air bubbles from the system.
  6. I have heard that in Skoda from year 2000- more aluminium and more metal-recycle materials are involved. Tha same with plastics, hard in touch but durable in older cars, prettier but softer and scratch sensitive in new ones.
  7. Lucky guy! Yes i still have them but after the well known problem the sensor ''reads'' the coolant temperature just before the radiator and it's hard to look in the console while driving especially in Mountain roads. I had in the past a gauge in the plastic column (driver's side) but blocks the vision in parking movements. I have to thing about it. What worries me is that i can not attach a sensor inside the expansion tank for example so i could read the digital numbers easily at a glance.
  8. and don't trust the Skoda parts seller which gives anything is suitable for him at this moment. I lost money in wrong Bosch lambda sensor plus money in gas plus many hours of worry ''what's wrong?"
  9. The best idea is to buy a thermostat with his own housing so no fitting problems. Here are some examples: One , Two , Three plus in ebay.co.uk etc. I have done this few years back (after having problems trying to fit new thermostat to previous housing) and ''case closed''. For Target and Favorit sure but i wouldn't take the risk since there are ''ready to use'' tested solutions for Felicia. https://ukrparts.com.ua/part/115052010/vag/ https://brovacar.ua/en/shop/1979 https://www.niparts.com/OEM/D4A077/VAG/113052060.html
  10. The new NGK Lambda sensor was ''the Master'', without him no matter how i have tried i would have such low Mpg numbers. The programmer insisted than the Bosch wasn't the best choice and he could not guarantee that the signals which was sending to the ECU would be 100% proper. Due to the high temperatures and the climate change here in Greece you can use a motorcycle even at October (!) so the Winter car traffic times will come at least in November.
  11. Cold start measurement: the car has parked in the road and the morning sun could hit it directly so it took only 5 seconds. Fuel consumption: 2 persons, Mountain roads (not high rpm) National road (speed till 100-120 Km, in purpose no more but with medium load of baggages in the trunk) 12th Gas station pump test: 314,4 Km distance, 21,070 ltr fuel which means 6,70 ltr / 100 km or 42,16 Uk mpg which is the personal fuel consumption Record from 2005 till now 2022. 🤩
  12. https://nb.bbend.net/media/news/2021/05/14/1195963/main/dragster-distixima1.jpg https://www.agriniopress.gr/wp-content/uploads/2021/05/7-1.jpg Too many mistakes in that accident. _______________________ As for the foam on base-sides, i have seen in many videos that the extra foam can be glued on the stock foam of the seat so no need to replace the whole thing (less cost).
  13. Some guys at Upholstery repair-shops can replace the base-side factory foam with their own make it look like a Recaro. They also can make a custom cover for this seat.
  14. 2012, a fatal accident here in Greece to a pro-racer. Take a look below the seat, a wrong modification cause it.
  15. Sometimes the frame does not fit and need customization which means money and time plus cutting-welding isn't always the best for safety. We have seen seats detach from their frame with fatal results for the driver. Even without modification the seat has different dimensions (width-height) so in the end you can end-up with seat higher than before and have problems with the seat belt bracket. You have to measure so many things before, it's a risk.
  16. I had the same problem in the past, a new thermostat this type costs about 24 euro. If i was you a would buy a new one but if you look hat part only you can buy a new Vika for 6 euros and use that part only. If you use a used one it's a risk, soon or latter you will have an issue.
  17. One of saddest days in my life with Trusty, 5 years back the return from a beach Cafe turn to be a nightmare. Was the day that the radiator fan motor decide to leave this vanity World.In the beginning i thought was the fuse or the relay or the switch but No. For first time i had to call for Road Assistance and thankfully i wasn't in the country far away from town. I don't want to live a moment like this again.
  18. I would like to see a picture of it, i interested for things like this.
  19. My english are not good and i haven't the Fun model but when we say glove box don't we mean this? You mean the left side of this does not close properly?
  20. Take you time and do not overfill. Try not to pull the cable too much otherwise you will have problem with the white clip inside the dashboard (connects the cable with the back of the factory gauge). Also don't put grease in the end of that square wire rope, let it dry to ''click'' better.
  21. A degrease spray (even a carb cleaner) can help plus some gently knocks (from all sides) with a hammer like this will help for more slacking.
  22. I thought that you problem was only the latest part, the teflon gear. Now the photo shows that your problem is ''bigger'' but as i can see it you can try pull it out with a plier after you use a cleaner-spray to remove any dirt around it and slack it gently.
  23. You mean this white in the end? https://a.d-cd.net/wiAAAgEL7-A-960.jpg I think it's from Teflon, too hard to be smashed and go to the drain plug in small pieces. ''Dropped plastic in transmission" https://www.vwvortex.com/threads/anyone-ever-dropped-a-speedo-gear-into-their-transmission.1429523/ https://www.thesamba.com/vw/forum/archive/index.php/o-t--t-572677--.html https://www.corvetteforum.com/forums/c1-and-c2-corvettes/3809741-help-dropped-my-speedometer-drive-gear-into-the-transmission.html and https://www.3si.org/threads/help-please-plastic-fell-into-transmission.536770/ https://forum.miata.net/vb/showthread.php?t=512484
