pab567
FREEDOMTech
Everything posted by pab567
  1. I believe you have BT module that connects to your mobile in RSAP mode and you have PIN enabled in settings. Pls share model number of your BT module (I think in RHD cars it's located under driver's seat) and disable PIN in your mobile's settings.
  2. Glove box unit must be replaced, from approx. 200 GBP up for fully reworked (unlocked and activated) unit.
  3. Pls share your VIN so I can decode.
  4. First of all - this is UK forum so pls use English (even if both of us are Poles). It's possible but due to safety and security reasons I don't do it remotely.
  5. Well, all you need to replace it with OEM is torx T20 screwdriver and removal keys, the rest is Plug&Play. I have a manual prepared for Fabia, in case of your car it will work the same way (just screw locations might be different).
  6. Basically this is possible but requires unit to be hacked. Also after upgrading from 02xx to 03xx or 04xx left and right channels are swapped.
  7. Indeed, you need new glove box, glove box unit, display unit, USB, extension cables set and GPS antenna (assuming you get unit with OEM navigation).
  8. The answer is YES, it's just the question of your "must have" features and budget.
  9. I missed that you have CANTON - indeed, amplifier must be exchanged too 😞
  10. You need to replace display unit, glove box unit and USB
  11. 2012 Skoda Superb so I guess this is Columbus RNS510. Pls remove the unit and post a picture of upper cover label so I can let you know how to proceed further.
  12. I will check if I have any NAD module from scrapped unit and let you know.
  13. You must have your Swing replaced with MIB2 Bolero, Amundsen or Columbus - depending on your needs and budget. You need glove box, display unit, glove box unit, USB and extra harness. You can contact me on PW for details if you are interested.
  14. Received and replied Bolero MIB2, glove box unit 5Q0035842B, display unit 5E0919605H.
  15. Looks like Bolero, either MIB1 (5.8") or MIB2 (6.5"). Send me VIN on PM and I will reply with SW update file download link and let you know model number of your both display and glove box units.
  16. This looks to me like a normal 3D view. Change to 2D if you don't like it.
  17. These module are not sold separately, you can get some broken second hand unit and have it replaced
  18. As this is posted in Superb Mk II section I beleive it's Columbus (RNS510) or Amundsen+ (RNS315). Unfortunately for none of them fresh map updates are available 😞 The solution is to retrofit your unit with MIB STD PQ one
  19. This is typical problem of NAND overstack. You can try to reflash the unit, if doesn't help then NAND must be formatted which requires special tools, either SW (SetConfig) or HW (flash programmer).
